Question about Xerox Phaser 8200 Laser Printer
Paper is printing but top edge of paper is creased and torn
Our Phaser is printing and we are not receiving errors but the pages print with a large crinkle (crease/fold) at the top and have oil stains on them and are really beaten up. After printing the page, it sounds like its making a sudden stop rather than it's normal sound. Occasionally the page doesn't even print and gets stuck right before the final feeder.
The printer is also making strange, deep adjusting/mechancial noises it doesn't normally make that last about 4 seconds. This problem started happening out of the blue on Monday morning and we haven't gotten decent response from Xerox yet as to why it is occuring.
ANY HELP IS GREATLY APPRECIATED!
  • 3 Answers
Replace the fuser (part of the maintenance kit)
I have had countless printers start ripping/tearing the top edge of pages and the fuser is almost always the culprit.
Posted on Sep 10, 2008
    President:
  • 2,072 Answers
It sounds like your maintenance kit is defective.
The excess oil leads me to believe that.
Posted on Jun 05, 2008
How to disassemble a Kodak ESP C110 printer?
Hello Edward,
There really is no reason to take it apart fully as the printer is showing classic signs of a paper jam. Usually it is a small piece of paper that has torn off and is lodged in the printer's paper path, it also could be something small such as a paper clip. Yours obviously is located on the side that the crease appears. The paper feeds in and then it hits the stuck object, then jams. Look very carefully at the leading edge of the paper near the crease and it may show the exact location of the foreign object. in the paper path. Remove the object and you should be all set!
Good Luck!
Rich Lilja
Mar 01, 2015 | Kodak Office Equipment & Supplies
How do I clean toner from machine?
Probably it's the jammed paper that might caused the error. I suggest have it serviced by the technician. Be aware of the paper handling capacity of your machine to minimize jamming:
3300MFPV_X
Phaser 3300MFPV/X, Copy/Print/Colour Scan/Fax, B&W, 28 ppm, A4, 1200 dpi, 50-sheet ADF, 250-sheet Paper Tray, 50-sheet Multipurpose tray, 150-sheet Output Tray, 96 MB, Automatic 2-sided printing, USB/Ethernet, PCL/PS3, Scanning software, 220 V
Apr 28, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Can I print to the edge with Phaser 7400
No this is phisically impossible, try a larger sheet of paper and cut it
Mar 17, 2013 | Xerox Phaser 7400DN Laser Printer
I have the Phaser 6180MFP. Every envelope that we print is creased all along the trailing edge (the last part of the envelope through the printer). Is there an adjustment or is this a problem with the...
You can try to select the type of paper to thick card stock. This will do that the printer will apply different fuser pressure.
You also can simply not setup anything on the printer and on the driver and feed the paper with long edge first. But after each print job the printer will request for A4/Letter paper and you will need to cancel this message.
Oct 05, 2010 | Office Equipment & Supplies
Phaser 8200 Smears on Linen Paper
Your maintenance kit is running low on oil and needs to be replaced. Since the image drum is not getting enough lubrication, some of the ink from the previous page is sticking to the drum and carried over onto the next page. Also, try to match the printer paper type to the paper you are using. It will adjust speed, temperature, etc. to optimize print.
Mar 24, 2009 | Xerox Phaser 8200 Laser Printer
Pinstripes in image after print (phaser 8560)
Appropriate cleaning procedures, as listed in the following tables, should be
performed when specific print-quality or paper transport problems occur.
All cleaning procedures are detailed in the printer’s Phaser 8400 Reference Guide or
the Phaser 8500/8550 User’s Guide.
Light Stripes or Missing Colors
Problem type Solution
Missing or light-colored
stripes on prints.
Select the automated procedure Eliminate Light Stripes from
the Control Panel.
Ink Smears, Oil Spots, or Random Ink Streaks
Ink smears on the front,
back, or edges of a page.
Select the automated procedure Remove Print Smears from
the Control Panel.
Check the maintenance kit for ink and paper-dust build-up on
the wiper blade.
Oil (drum fluid) on top edge
of print.
the Control Panel.
Hope this helps
pdouglasss
Nov 24, 2008 | Xerox Phaser 8560DN Laser Printer
Hp laserjet 1200 paper jam
Please Follow the instructions in an attempt to resolve the issue you are facing:
  • Turn off the printer and remove all paper from the paper tray & disconnect it from the computer.
  • With the printer off, check for any obstructions such as torn paper or foreign objects.
  • Turn on the printer (still disconnected from the computer) and check the lights / lcd screen.
Still getting the same error ? Go for Warranty or Service.
Else,
  • Place 20-30 sheets of paper in the printer, ensuring none of the paper is torn or creased.
  • Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
  • Try to feed paper manually (using the paper feed button).
If you still get the error let me know for further troubleshooting,
Dont vote till you find it is Helpful or FixYa.
Thanks,
Scott
Nov 14, 2008 | HP LaserJet 1200n Printer
Xerox phaser 7700 having problems printing transparencies and accumulator belt problems
Hi xander4265:
I
Streaks in direction of paper travel
There are dark lines running along
the page in the direction of paper
travel from the leading edge to the
trailing edge (B-size print shown).
The printer displays no error code.
Note A-size prints are processed
through the printer with the short
edge of the print parallel to the
direction of the paper path --
making horizontal print artifacts
parallel to the shot edge of the
print.
B-size prints are processed
through the printer with the long
paper path -- making horizontal
artifacts parallel to the long axis
of the print.
1. Check the end of life for each of
the consumables by printing the
supplies usage page. From the front panel’s Printable Pages Menu, select
Print Supplies Page.
2. Run the solid fill test pages; From the front panel’s Printable Pages Menu,
select Service Pages, then select Print Solid Fill Pages. If the missing bands
only occur in a single primary color, replace the print cartridge of the affected
color.
3. Swap print cartridges and run another test print.
Note Under some circumstances, streaking may occur in the margin of
SRA3-size paper. This is due to the edges of the paper extending
beyond the end of the imaging components. print-quality in the
margins of SRA3 paper is not guaranteed.
4. Inspect the Accumulator Belt cleaner; replace the cleaner, if necessary.
5. Run the Remove Print Smears routine. From the front panel’s Support Menu,
select Improve Print-Quality?, then select Remove Print Smears.
6. Replace the Developer Housing Assembly (RRP 27, on page 7-171).
7. Remove the print cartridge and (with a flashlight) check for debris along the
edge of the developer housing.
3041-42
Leading Edge
hope that this will help you.
Sep 18, 2008 | Xerox Phaser 7700 Laser Printer
Epson 1280 Will Not Take Paper through to print?
Follow the instructions below in an attempt to resolve the issue you are experiencing.
1) Turn off the printer and remove all paper from the paper tray.
2) With the printer off, check for any obstructions such as torn paper or foreign objects.
3) Place 20-30 sheets of paper in the printer, ensuring none of the paper is torn or creased.
4) Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
5) Attempt printing.
Apr 19, 2008 | Epson Stylus Photo 1280 InkJet Printer
Xerox Phaser 8200 Laser Printer Logo
157 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
