Question about Maytag Legacy Series Top Load Washer
Replacement seals whats the best procedure for replacing seals? Can a moderate DIYer accomplish the task w/o going crazy? As long as I'm into it should belt be replaced as well?
  • 3,037 Answers
Washing machines are generally very easy to fix
Instead of typing out directions on how to do it, I found a website with some directions that should work with your machine, and you can always find more, washing machines are pretty simple machines. If the belt looks worn, it wouldn't be a bad time to replace it too. Also, clean everything up as you take it apart and it should be almost like brand new.
here is the link I found with pictures and everything, let me know if you have any questions while doing this, good luck
http://www.kichline.com/chuck/fixit/washer/white.htm
Posted on Jun 04, 2008
The advantages of using marking guidelines and memorandum.and what advice can you give to educators for them to be efficient markers?
  • Best practices: Benefits of using the Moodle Marking Guide ... www.moodlerooms.com/best-practices-benefits-using-moodle-marking-guide ... meet standards, ... Benefits of using the Moodle Marking Guide. Best practices: Benefits of using the Moodle Marking Guide.
  • The Advantages of Rubrics: Part One in a Five-Part Series ... https://www.teachervision.com/teaching-methods-and-management/... The Advantages of Rubrics ... There are many advantages to using rubrics: Teachers can increase the quality of their ... Students have explicit guidelines regarding ...
  • MARKING GUIDELINES: GETTING THEM RIGHT? www.curriculumsupport.education.nsw.gov.au/secondary/hsie/assets/... ... of a rubric and marking guidelines an easier task. Teachers following ... criteria in the marking guidelines for ... own advantages and ...
  • Procedures for implementing the Assessment and Moderation ... www.nwu.ac.za/sites/www.nwu.ac.za/files/files/p-fes/Documents... · PDF file Procedures for implementing the Assessment and Moderation Policy of the NWU ... Procedures for implementing the Assessment and ... memorandum/marking ...
  • WORKING PAPER SERIES - University of Wollongong ro.uow.edu.au/cgi/viewcontent.cgi?article=1003&context=dubaiwp · PDF file WORKING PAPER SERIES Discipline: Management/Education Using Marking Criteria to Improve Learning: An Evaluation of Student Perceptions Swapna Koshy
  • PLANNING & DESIGNING ASSESSMENT - Rubricate PLUS www.rubricate.co.za/Planning&DesigningAssessment-Tools.pdf · PDF file PLANNING & DESIGNING ASSESSMENT ... response test with marking memorandum ... It is a simple tool which itemises standards, skills or
  • What are the benefits of a memorandum of understanding ... www.environment.nsw.gov.au > ... > Aboriginal joint management For schools and educators; ... What are the benefits of a memorandum of understanding? ... Some advantages include:
  • Developing marking guidelines - Board of Studies Teaching ... www.boardofstudies.nsw.edu.au > ... > HSC examination committees Board of Studies Teaching and Educational Standards NSW Australia serves teachers and a million students in both government and non ... Developing marking guidelines;
  • Jul 05, 2016 | The Learning Company Computers & Internet
    RCA HDLP61W151 Light Engine Replacement
    bulb light engine usaly seprate pices if u can open it see what were it is go for it sumtimes these very hard to getto i can try o get u serv manel online
    Jan 19, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
    Tip
    How to replace the door seal on an Ariston or Creda washing machine
    Hi.
    The procedure is quite complicate, because the seal is secured to the front panel, and you will need to remove top panel, detergent drawer and access control assembly
    1. Disconnect appliance from power
    2. Remove the door, held by two screws located on the rear side of the lid.
    3. Lift the top panel, held by two screws at back.
    4. Undo the two screws joining the detergent dispenser to the inlet valve.
    5. Undo the two screws located at the front corners. So to release the fascia and dispenser.
    6. take out fascia and the dispenser alltogether and put it on one side. Take care to not disconnect wiring and do not drop parts.
    7. Release the retaining wire that keep the seal secured to the front panel. Look after it, you will need it again.
    8. Undo the two screws that hold the front pane. They are located on the front side.
    9. Remove the kick panel
    10. Behind the the kick panel you will find the two screws that will release the front panel, remove both of them.
    11. Disconnect the door switch conntector.
    12. Lift the front panel. You may need to help yourself using a putty knife.
    13. Remove the clip with two hooks inside, it is located about postion one o'clock. This will finally release the seal.
    14. Remove the seal and clean the area where you will fit the new seal.
    15. Start mounting the seal from the lower part on the right, at about four o clock. You will notice the seal matching.
    16. Put back the retaining wire usingf long-nose pliers to put the wire in tension.
    17. Reassemble the washer in reverse order.
    Mark connector and keep screws ordered and separate while doing the procedure above. This replacement is suitable for an expert DIYer.
    on Apr 08, 2010 | Ariston Technologies AWD120 13 lb. Washer...
    Can you replace iPad batteries
    It can be done, but Apple has sealed the iPads and DIYer can Google for procedures. This is an "at your own risk" issue because it is very easy to break the bezel or glass trying to do this yourself.
    Aug 08, 2014 | Apple iPad 2
    02 denali rear main seal
    This is a pretty big job for a DIYer. You have to pull the transmission to get to it. If you're up for it I can tell you how. It will probably be a 2 day job if you only have moderate auto knowledge.
    Dec 26, 2012 | 2002 GMC Yukon Denali
    INSTALL 2003 2.7 Dodge intrepid oil pump
    You are not going to like my suggestion. Either go online and search for a maintenance manual for your vehicle and purchase it or go to a local parts store and purchase one there.
    The procedure to do what you are asking is very long, many pages of typing and photos a required to accomplish what you ask and it is different for every vehicle.
    You can also do a search online about doing this and you might get lucky and find a procedure already written up, but I'm betting on you needing the manual in hand to accomplish this task, even with online instructions.
    Or you can pay a mechanic to do it for you and if you do not have all the tools required to pull the oil pan and even possibly the engine from the vehicle, it might be cheaper.
    Good luck.
    Sep 17, 2012 | 2003 Dodge Intrepid
    My gmc envoy xl 2004 wont start and before this it would cut out like it was running out of gas but always had gas also the dash board light will start flashing like crazy on there own
    The first thing I would suspect is the ignition switch, these have been known to cause all kinds of problems when they go bad. If you are handy, it can be replaced by a DIYer. Go to www.trailvoy.com and do a search on ignition switch replacement, for instructions on how to do it.
    Oct 11, 2011 | 2004 GMC Envoy
    How to bleed my hayes 9 hyrdrilici brakes?
    This is a fairly complicated procedure if you have not done it before. You will need the correct replacement oil and some specialty tools, and possible a few parts if they are damaged or seals are in need of replacement. It may be better to take this into your local bike shop and have them do it. Bleeding brakes is a time consuming and challenging task even for seasoned mechanics.
    But if you really want to give it a try here you go.... Instruction manual
    Apr 06, 2011 | Cycling
    HOE TO REPLACE AN ENGINE HEADS
    Since you don't say what the vehicle is, your best bet is to go to your local auto parts store and purchase a VEHICLE SPECIFIC REPAIR MANUAL. This should provide all the necessary info you need to accomplish this task.
    Mar 02, 2011 | Isuzu Trooper Cars & Trucks
    Rust marks from a stainless steel drum?
    If you are talking about brownish colored stains on your clothes, this is actually caused by the drum seal going bad. The drum seal fits around the perimeter of the drum where it meets the rear bulkhead (wall) of the dryer and is a felt type material. One some dryers the drum is reversible and there is a seal on both ends of the drum. When the seal gets old, it becomes brittle and starts to crack and come apart. There's usually a brownish colored pigment that comes off the seal and can get on your clothes. If the seal is worn too much, your clothes could actually be getting caught in the drum between the seal and being dragged. This will also caused brown streaks on your clothes. Now...what causes the seal the wear prematurely are high temperatures. If you do not routinely clean your dryer ducting, your dryer could actually be overheating. This can cause the seal to become too hot and make it brittle over a period of time. Any appliance repair dealer will carry the drum seals for the dryer as it is a common part that requires replacement. If you could post back with your EXACT model number (located around the door opening) I could find a part number and price for you. In addition, I could give you step-by-step instructions on how to replace the seal if you wish to tackle this on your own. It's not a difficult repair and the average consumer should be able to accomplish this task. It will also save you $$ on the long run if you don't want to pay high labor charges of the appliance repair guy. Let me know if I can assist you further.
    Jan 18, 2008 | Kenmore 73952 Gas Dryer
    Washing Machines Logo
    54 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
