Question about HP Deskjet 3915 InkJet Printer
Cable? i have a black cable that doesnt connect to the back of my printer...
    Genius:
  • 1,601 Answers
Did you figure this out?
Posted on Aug 07, 2008
Blinking error light
the printer driver converts computer speak to printer speak. The computer port, printer cable and printer port provide the connection, The printer gives status back to the computer.
SO, depending on what "recognize" means, the printer driver may be corrupt, or the wrong one. The printer connection might be bad, or the printer interface may be bad.
uninstall the printer, reset everything, reinstall a fresh printer driver and try again. If same, check or replace cable and connectors.
If same try connecting the same PC port to another device. If that works it is probably internal to the printer.
Aug 11, 2014 | Star Micronics TSP 100 Thermal Printer
Fax sending does not want to dial out
Please make sure all cable connections (especially the phone cable) is properly connected and secured on the back of the printer and into the phone jack in the wall. You may unplug and re-plug both ends of the phone cable just to make sure.
Make sure that the printer is connected to the right phone jack in the wall for faxing.
Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
Should the problem continue, please don't hesitate to contact Lexmark Technical Support Center for additional assistance.
Feb 09, 2012 | Lexmark X6170 All-In-One InkJet Printer
My printer won't turn on
Hi
Either the power source has issues or the power jack on printer has gone bad or printer's main board has issues.
Verify that the electrical connections and outlet are functioning:-
Unplug the power cable or power module from the electrical outlet.Unplug the power cable or power module cable from any power strips or surge suppressors.If the product uses a power module with a detachable power cord, unplug the cord from the power module, and then plug it back into the power module.Unplug the power cable or power module from the back of the product.Wait at least 30 seconds, and then plug in the power cable or power module into the electrical outlet.Plug the power cable or power module back into the product.Turn the product on.
If this doesnt help, take the printer to another room and plug it in another power source.
If this doesnt help, use a multimeter to check if adapter is giving out right voltage.
If adapter and power source are fine, then your printer has a hardware issue and needs to be repaired by Canon.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 06, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Had paper jam then the sreen said i was not connected to pc i replaced cable with one that worked on another printer and it still says usb cable not connected
Hmm. Lets try and reset the printer..
Hold down the power button on the printer, Then, unplug the printer.
Still holding the power button down, plug the printer back in.
The printer should start again.
Now, cut the printer off and on normally. And see if the computer can see it.
If this doesnt help, let us know!
Please remember to rate my solution if it helped you at all and leave some feedback. Thanks!
Jan 04, 2011 | Kodak Office Equipment & Supplies
IT WON'T PRINT DO i NEED A USB CABLE IF SO WERE DO i PLUG IT INTO ON PRINTER? THANK YOU ALSO DO i NEED A BLACK INK CARTRIDGE?
Hello Grannie,
You will need a printer USB cable to connect the printer to your computer. These cables a standard for all printers and look something like thispatzky.jpg.
You should find a square like opening on the back of the printer to connect the cable.
As for the ink cartridges, I believe lexmark only requires either a color cartridge or a black cartridge to be installed. Use one of the two and the printer should work.
Thanks,
Pat
Nov 07, 2010 | Lexmark Z2300 InkJet Printer
Printer tells me black cartridge is missing
Please remove your printer and uninstall the software from the PC. then reinstall the software and tehn connect back your printer to be detected and installed once again. I hope you have the software of the printer which came along with the set. This must get your printer back to action. I hope this helps . Good day
Jul 07, 2010 | Dell 966 All-In-One InkJet Printer
Black ink cartridge.
the printer only prints with all ink cartridge inside, back and color (use only original ink spares)
Dec 29, 2009 | Canon PIXMA iP1200 Photo Printer
The scanner suddenly stopped working - the error
try turning it off and on, if this doesnt help un plug cable and restart PC.
then plug cable back and and see if the PC will detect it then try again.
if the PC doesnt detect it then try different cable and if this doesnt help you will need to contact manufacturer.
Oct 31, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
PRINTER WILL PRINT COPY OF SOMETHING BUT WANT PRINT SOMETHING OFF COMPUTER.
This problem sounds like the printer is not set up properly on the computer. Have you installed the software that came with it? If so, look for the printer under control panel and then try a test page. If the test page doesnt work, how is the printer connected to the computer, by USB cable? If it is connected by usb, try shutting the computer down, unplugging the usb cable, restarting the computer and once it is fully started, plug the usb cable for the printer back in. Do you hear a tone after the printer is plugged in? If so try to print again.
Aug 11, 2009 | Office Equipment & Supplies
Connection of the cable wire to the circuit block at the back of the stove
3 wires BLACK(110v), WHITE(nuetral), RED(110v). doesnt matter black or red,left or rigth so long as white is in middle..
Mar 07, 2008 | Kitchen Ranges
HP Deskjet 3915 InkJet Printer Logo
18 people viewed this question
Ben Johnson
