Kenmore 80 series washer
I have a 80 series washer model # 20802990 when i turn it to the hot temp the washer will not work when i put it on cold it washes fine ive checked the hose and the screens but still nothing please help
    Novelist:
  • 177 Answers
Sounds like you need a mixing valve.
double check for water from the source.
Posted on Jun 07, 2008
I have a kenmore ultra fabric care washer heavy duty 80 series with electronic temperature control and I can only get hot water not cold.
If it used to work and now does not, either the valve that controls the water inlet to the hot is bad or the temp sensor in the machine is bad. What is the whole model number?
Mar 22, 2015 | Kenmore Washing Machines
I have a Kenmore 80 Series Washer (Model # 20802990) and it was working fine yesterday, and today it will go through the wash, fill up and go partway through the rinse cycle and then stops. It wont drain...
the lid switch is broken this video will show you exactly how to replace it....
http://youtu.be/MFsvLiuTniU
the part#for the switch is 3949238 you can order it by going to searspartsdirect.com or look in your local phone book and find a parts dist. in your area
Jul 20, 2011 | Kenmore 24032\24036 Top Load Washer
My Kenmore series 80 washer's cold outlet doesn't work
Hi, It does sound like the inlet valve is bad. If the screen inside the inlet vavle is not plugged, you will most likely need to change the valve. If you will send me a model #. I can tell you how to get to the valve for replacement.
Thanks
Vic
Jul 26, 2009 | Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Kenmore 90 series Water pressure turning up and down
it will switch from hot to cold and back and forth trying to regulate the temp. You probrbly have more pressure in your cold water line than your hot or vise versa. This will cause it to seem to pulse. Dave www.washermd.com
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series model #110.26882503 fills slowly
Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
Dec 08, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series will not fill up with water
if your washer will agitate when set to fill but not fill, then your pressure switch is bad.
also you may want to check and see if you are getting both hot and cold to your washer.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Washer produces Hot Water Only
first be sure you are getting a good flow of cold as far as the washer connection..if so ck inside washer connection for a small wire screen be sure it's not plugged if so clean and flish line to remove anything inside hose ..be sure to put screen back in ..if still no cold suspect bad cold section of valve..replace valve..last remote possibility temp switch is bad
Sep 12, 2008 | Kenmore 24902 Top Load Washer
Kenmore 80 series top loader the washer will not fill with cold water only hot water
Yes patrick you can try removing the cold hose from the washer, look inside the valve for a metal screen. If it has sediment blocking it remove screen, clean it and reinstall. If still no water replace inlet valve.
Dec 01, 2007 | Kenmore 24902 Top Load Washer
Washing Machines Logo
105 people viewed this question
Top Washing Machines Experts
