Question about SMC Barricade 7004VWBR Wireless Router
Cannot connect Blackberry Curve (8320) Wifi phone to router
Trying to use Blackberry Curve (8320) Wifi phone through SMC Wireless BArricade 7004vwbr. It can locate the wifi point but cannot obtain an IP address. Have checked all obvious causes. PLenty of IP addresses not assigned and available, Dynaic IP assignment turned on. MAC address is registered, but same result whether MAC filtering is turned on or not. Same result with firewall on or off. WEP not in use. Works fine with a variety of other wifi points
  • jslms Jan 14, 2009
    same exact problem - ATT says they dont know - was on the phone with RIM but got disconnected - anybody have a fix?
    btw - its with all wifi - open or closed - different routers too -
  • 139 Answers
SOURCE: Intermitent signal strength
It is not unusual for the radio transmitters to fail in wireless routers after a year or two of use, especially if they're used in a location with poor ventilation or dust buildup. "Kaput" is probably a good term for it, but it would be worth finding someone with another laptop to try connecting through your router...just to verify that it's really a problem in the router and not in the wireless adapter in your computer.
Posted on Jan 11, 2008
ayamaya
  • 143 Answers
SOURCE: SMC Barricade 2804WBR.
just hardwired a computer to the router and open a web browser. on the address bar of the web browser type http://192.168.2.1 (default ip address of the router) and you will be prompted with the login screen. by default you don't need to type anything on the password field. now you will prompted with the router's page and from there you can set it up.
click here for the manual.
hope this'll help you
ciao
Posted on Oct 07, 2008
  • 104 Answers
SOURCE: Secure wireless connection to the internet.
Hello Peter, I'll try and help if I can. I'm assuming you're using Windows XP.
First, when enabling security on your router, it is best to connect using a wired, rather than wireless connection.
Open your web browser, as if about to view a web page, but instead type the address of your router in the address bar. I think this is http://192.168.2.1 (Note there is no 'www'.)
If successful, you should see a screen asking for a password. The default is set as blank, so just click 'login'.
You should see a home page. Click the option for 'Advanced Setup'. Then click the left hand menu item, 'System', then 'Password Settings'.
You should see a screen where you can change your current (blank) password to a password of your choice, and then confirm the choice (it should have 3 to 12 characters, letters and/or numbers). Click 'Apply' to save the settings.
To secure your router, there are a couple more steps to follow. Click the 'Wireless' option on the left hand menu. Under 'Channel and SSID', you should see a screen which shows your SSID (a name for the router)....It is a good security idea to change this to another name - anything you like, as long as you can remember it! Click 'Apply' to confirm the new setting.
Then select 'Encryption' from the Wireless menu. Select 128 bit WEP encryption. You should see a box asking for a 'passphrase'. Enter any phrase, made up from letters and numbers, with no spaces, and click 'Generate'.
I hope you will then see a series of numbers split into boxes. Write down the numbers in sequence (or maybe you could print the screen?). This is your encryption key. Click 'Apply' to save the settings.
You can then exit from this screen.
The last thing to do is set up your wireless adapter connection (eg, a laptop, or whichever computer has the wireless connection). When your wireless connection tries to access the internet, you should see your router with its new name come up in the 'available networks'. Click to connect, then enter your WEP key when prompted.
I hope this helps you. I'm not a pro, just lending a hand, so please come back to Fixya if anything is not clear, or doesn't work as expected! All the best.
Posted on Dec 10, 2008
  • 192 Answers
SOURCE: won't assign IP address
Try tuning the router off and back on and do the same with the computer.
Posted on Jan 08, 2009
etaf
  • 779 Answers
SOURCE: I have forgotten my password
I assume this is your wireless KEY
The user manual is here http://www.smc.com/index.cfm?event=downloads.doSearchCriteria&localeCode=EN_GBR&knowsPartNumber=false&productCategory=1&modelNumber=955&partNumber=3552&downloadType=8&os=0
you can choose the exact model from here http://www.smc.com/index.cfm?event=downloads.searchCriteria&localeCode=EN_GBR&knowsPartNumber=false&productCategory=1&downloadType=0&os=0
You should be able to see how to view or reset the wireless password.
Connect your PC to the Router with a LAN cable:- You will need to login to your router- you do this by typing a number into a web browser, Internet explorer, is best as some routers do not work with other browsers The way to log into the router is usually to use the IP address, thats a number which will be in the manual - Page 29 on the manual (33 on pdf screen) To access the Wireless Barricade’s management interface, enter the Wireless Barricade IP address in your Web browser http://192.168.2.1. Then click LOGIN. (By default, there is no password.) Goto the wireless section - secruity and you should be able to see the KEY - IF its all * - the you can type in a newone
I would also remove the wireless profile from your PC - to do this have a read of this link. Remove the wireless profiles from your PC http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Posted on Mar 25, 2010
Hi I have an SMC baracade g wireless router and want to connect my samsung galaxy 580 phone to it wirelessly. My computer connection is working. The phone detects it fine and can see that it has WPA/WPA2...
Hi
Try to unplug the power cable of your router for a minute or 2 to re-establish its connection to server. Then try reconnecting to your home network.
Hope this helps
Dec 09, 2010 | SMC Barricade 7004VWBR Wireless Router
I cannot do the set-up of my router
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAN settings and configure as your internet service provider settings then click on wireless settings enable wireless .If you want to secure wifi then click on wireless security then enable WEP then enter password it is your password to connect wifi. . Let me know if you need further assistance. Thanks for using FixYa.
Aug 18, 2010 | SMC Barricade 7004VWBR Wireless Router
I have forgotten my password on my smc 7004vwbr and need help to reset
Mar 25, 2010 | SMC Barricade 7004VWBR Wireless Router
SMC Barricade SMC7004VWBR not found by Wifi toys
good day,
hope this link below will solve your problem.
routers
Feb 12, 2010 | SMC Barricade 7004VWBR Wireless Router
Need password for log in to SMC Barricade 7004 VWBR Router
The username could be: admin
and the password could be: passoword
the password could be: admin
Jan 01, 2010 | SMC Barricade 7004VWBR Wireless Router
BlackBerry Curve 8320 will not connect with HS-100W
If it's any consolation. My BB 8820 connects to my Zyxel NBG-460N, but after a few minutes the connection just dies (the BB still shows its connected to the WiFi, tries to use it and can in fact send packets out, but it does not receive anything any more). The router has gone through 3 firmware upgrades so far and no solution. It's also causing trouble with some USB WiFi sticks when the SSID hiding is enabled.
In short: I believe ZyXEL's WLAN support is simply broken, and you'll have to buy a WLAN AP from another manufacturer.
Oct 04, 2009 | Zyxel HomeSafe HS-100W Wireless Router...
Linking my smc 7004 wireless router to ipod touch
I will advise you to configure the WEP encryption using your router before connecting using your IPOD.
Note: IPOD support WEP encryption. Check the network connection if the Internet is working properly.
Mar 26, 2009 | SMC Barricade 7004VWBR Wireless Router
Can't connect Blackberry Curve 8320 to 2wire wifi
W002 - Wi-Fi Connection Failed
Means The phone cannot get an IP Address from the Server.
Common issues are
The signal is to weak to make a reliable connection
WEP is configured incorrectly or WPA
DHCP may be disabled, it needs to be enabled on the router
There are other more technical issues to this but without more information this should be a good start.
Dec 25, 2008 | RIM BlackBerry Pearl 8100
SMC 7004 VWBR router
enable wireless in router and connect threw xbox
Apr 08, 2008 | SMC Barricade 7004VWBR Wireless Router
Jan 11, 2008 | SMC Barricade 7004VWBR Wireless Router
SMC Barricade 7004VWBR Wireless Router Logo
341 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
