Question about Philips Magnavox 27MS343S 27" TV
Model 42mf231d/17 42" plasma
3/4 of the screen is black and the top is perfect clear picture
tv is about 15 mo old and never had a problem
  • 2 more comments
  • gc51chief Jul 11, 2008
    similar problem with picture and now just black screen with sound...still researching for possible cause and solutions
  • Anonymous Jul 12, 2008
    At first the screen was half black then it went all the way black and now no pictures.
    no steps have been taken. looking for solution.
  • stmetcalf Aug 08, 2008
    Same thing happened to me just today. All of the sudden, the screen on my Magnavox (42mf231d) plasma went black. I still have sound, but no picture (and no on-screen 'indicators' such as volume, menus, and the like). This TV is just over two years old and I don't want to think about replacing it!! Any help would be appreciated!!
  • Anonymous Jan 16, 2009
    My Magnavox 42mf231d had the same problem--no picture but plenty of sound. Shop quoted me $834 to repair. Had another set just like mine in the shop with the same problem. Thanks, Magnavox.
  • 52 Answers
If the loss of picture is either on top half or bottom half of screen. there are y buffer boards that go from top to bottom on left side of screen when looking at back that control those sections. when there is loss of half of picture then buffer associated with that area would be at fault and would need to be replaced. when i see a degrading symptom such as loss of picture on top half or bottom half leading to no picture issue normally you would check heat syncs on y sustain board and if not heating up after a few minutes of being turned on would recommend replacing y main and both y upper and lower y buffer boards as they complete a circuit
Posted on Aug 20, 2008
I HAVE 42 INCH MAGNAVOX PLASMA TV AND THE SOUND WORKS BUT THE TV DOES NOT SHOW A PICTURE AT ALL IT IS JUST ALL BLACK,COULD IT BE THE PICTURE TUBE THAT WENT OUT.
yes...the video card could have gone out but most likely you have a connection that is loose or bad. I would check those first. If you have done so then I would try another video port and verify that it is the screen that is out and not just the port you are in.
Oct 11, 2013 | SNK Magnavox 42MF231D 42 in. Plasma TV
I have a five year old Vizio P50HDTV20. While watching it the other day the center 1/3 of the screen went black from top to bottom. The left third and right third are fine. This condition persists with...
Sorry the problems,ur tv it is having,it can't be repair,the tv Plasma screen panel itself it is shorted and dead,that why the tv plasma screen panel have only a third of the plasma screen panel it have a good clear picture and the other 1/3 of the tv plama screen panel is black and dead.The tv that have a broken or shorted dead plasma screen panel it is not worth repairing,because only way repair it is by replacing the whole entire plasma screen panel itself.The tv plasma screen are about 90% of the cost of the tv and can't buy it anywhere else except the tv corporations dealers themselves.Sorry tv now,only can be salvages for those electronic boards for parts that it.
Apr 08, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
My Magnavox 42MF231D 42" T.V
You may have a weak power supply. This would indicate one or two capacitors that are weak or bad. This model may be about 4 years now and this is a good indicator as these capacitors need replacing. The other problem may be the infared board in the TV that receives the signal from the remote may be a problem as well. I would certainly investigate my first thought. The latter is kind of rare. Thanks for asking and show a few hands of support.
Nov 29, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
Picture is perfect except for the 3" wide black
poor contact in the vedio connector , open the cover and rmove it , clean the connector and reinstall again
Nov 06, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Magnavox plasma tv model 42mf230a/37 sound but ni
Replace lower scan converter PCB, which plugged into Y-Sustainer Board, located to the left of the display if you poke back cover open. There are 2 of them, but in some models might be the one, long PCB.don't wait to fix it! otherwise, you will knock out Y-
Sustainer and upper scan converter. That will cause you to spend few hundreds to fix it.
Good luck,
Alex's TV Service,
Philadelphia,
Pa, 215-806-5980.
Jan 21, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
Magnavox 42MF231D/37 screen went white then black
Alot of times i have noticed that when i have worked on these, it has been the Backlight Inverter. 32 inch televisions had same problem as the 42 inch
Oct 18, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
Magnavox 42MF231D/17, screen just turned black,
power supply or inverter board failing if the power board is the problem it will have blown caps
little cans with puffy tops because the caps have vented if you don't see that then your inverter has died that model id out of production so try shop jimmy. com
Sep 22, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
Tv only has top right corner showing picture
Hello the picture was good 2 days ago.I took a picture of the plasma ..could please help me with some ideas...thank you..
Mar 24, 2009 | Akai PDP42Z5TA 42 in. Plasma Television
Vertical black lines
I want to know the possible cause of tv with 2 black line at the top and bottom of the screen. Is it have the same causes even if the tv model is not the same..thanks
Dec 19, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Philips Magnavox 27MS343S 27" TV Logo
1,457 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
