Question about Dell Dimension 4600 PC Desktop
Reloading windows xp
I have a dell deminsion 8300 with big virus problem. I made new partition and formated with OS disc. everything is real slow and drivers are not loading. can virus or worm embed past hard drive? Also does Best Buy have a replacement drive form thyis machine?
    Sergeant:
  • 458 Answers
Replacement Drive? If you are talking about a Hard Drive the answer is: You can buy any hard drive as long as it is the same type from any computer store. Take your Hard Drive to the store and tell the sales person that you want another hard drive like that one. You can get another Brand or a bigger size if you want to. Your best bet is to completely reload that hard drive and wipe everything off of it and start all over. You can still buy another Hard Drive (Internal or External) to keep your files backed up. That hard drive could have also went bad.
I am going to give you a lot of things that you can do. Like I said this is a lot of information so you might want to print it out and also copy it to a disk for the future. These things will explain how to check your Hard Drive and also tell you how to keep your system running smooth.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future.
Turn the system restore off. System restore keeps everything in restore. Meaning......... If you have spyware or a virus, it will stay in your system. Run Spybot S&D (This program is free and is better than using msconfig as long as you go through the settings and change everything to the highest settings.) Then do the same with Adaware 2008 (sounds stupid to use 2 things for spyware, but one catches what the other one does not.). I have links on my website (tandnfamilyelectronics-online.com). These links go directly to the download so you will not get the run around. You would do good to try a program called Window Washer (http://www.download.com/Free-Internet-Window-Washer/3000-2144_4-10436825.html?cdlPid=10731707). This is a great program that completely cleans anything in your computer that you do not need. It will not clean out anything that you have to have. I have used this for years to clean out my customers computers and have cleaned as much as 3 gigs of trash out. If you contact me I will give you some tools that I have for free that will do a great job on your computer. I have them ready to download and I will give you the link. (dean@tandnfamilyelectronics-online.com)
Send me the complete specs of your system and I can help you more. I hope that this helps you. There is no reason the really buy a program for spyware when there are free things to use that work great. Free AVG is a great Antivirus and yes it is also free. It will check your e-mail coming and going. It will also let your friends now that the E-mail does not have a virus. It also has a spyware program that is free. This day and time with all of the spyware out on the net you can never have too many programs for spyware. I would not run all of them at the same time though. Make sure that you do not use your computer during any scan. Defrag is also something to do after you do everything else. Some people will tell you that should not reload your computer. If nothing seems to work then sometimes that is the only good way to get it repaired right. Most of the programs that come pre-installed on a store bought computer is useless and most are even trail software that causes problems when they expire. Let me know if this helps at all. Please rate me if it helps.
HARD DRIVE PROBLEM
This sounds like a bad hard drive. What make of hard drive is in it?
Figure out what brand hard drive it is first. Then go to the website of the manufacturer.
While you are on the site look for software for hard drive repair. It could be listed in many ways. Download the windows version if you have another computer to test this in. If you do not have another computer to test this in you will have to use the Dos version. The instructions will come with the siftware.
Then you will go through these steps.
Do you have another computer that you can use to check the hard drive? If you have another computer or access to another computer you can download a hard drive utility that can diagnose and possible repair the hard drive. Is it a SATA hard drive? If it is a SATA hard drive you can plug it directly into another computer that has a SATA cable. If it is not SATA you will need to buy a converter so that you can hook it up to the other computer. This will be an external slim hard drive enclosure. A desktop hard drive can be put in another desktop and used as a slave drive. Just make sure that you look at the back of the Hard Drive and make put the jumper on the slave pins. Then you can run the test through the other computer to test the Hard Drive. The test will let you know if the Hard Drive is bad or not. If you can see your files on the drive you might want to back them up before you start the test. If it comes back as good go to the next step.
FIX BOOT
You can boot it up with the recovery CD and run through it as if you were doing a setup and then when the second repaircomes up..... hit repair. This should repair any problem with the operating system. If you want to try the simple way... use the first repair that comes up. When the screen comes up with a blinking curser hit the number 1 then Enter........ When it ask you for a password hit enter. There should not be a password unless someone has put one in it. If there is a password it should be your master password.
Then type fixmbr and hit enter. This will fix your master boot record. If that does not work use the second repair. Sounds complicated but it is not.
CDROM PROBLEMS / Hard Drive Problems
Check your IDE cable inside that plugs into it. This will be the wide cable. Does it light up? Your power supply could be going bad. Unplug them one at a time and see if they work. Look at the jumpers and make sure the last one on the cable is on Master and the other one is slave. Sounds like a bad cable or connection if you swap the cable and see if it works.
Posted on Jun 04, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Did you try what I told you to do? I will still help you, but you need to tell me what you have done.
How to update after a restore?
this link for xp IE9....http://en.softonic.com/s/free-update-internet-explorer-10-windows-xp.
Jan 19, 2014 | Dell Dimension 8300 PC Desktop
Two O.S.
put the windows xp cd into ur dvd writer ... restart the machine... then after showing the dell logo... it will say "press any key to boot from cd.."
press any key.. wait until a blue screen appears...
there will be three options
choose "press esc for a clean install"
it will show the partitions of installed windows
delete the partition of your choice....
create a new partition on the unallocated space...
press f3 to quit...
machine will restart ...
wait upto the blue screen...now choose
"press R for recovery console"
press R
type fixboot | enter
type fixmbr | enter
restart the machine
whoa...your are good to go..
Dec 19, 2009 | Dell Vostro 1510 Notebook
Having Trouble Reinstalling XP on my Dell Dimension 3000
Here's what I would do. Download and burn any Linux disk. Install Linux and delete all partitions while doing so. After that, initiate the Windows XP installation and see if that works.
This will take care of two things:
If you can install Linux, then the hard drive is good and the partition that was previously on there will be deleted (I suspect the partition is locked which can be caused by a virus or the software used to scrub hard drive).
Check your CDs for Windows (for scratches) or it could be your actual CD drive is out (laser) which would make the installation fail. If the CDrom cannot read the disk, it locks up like that during installation...even if it read before.
Sep 22, 2009 | Dell Dimension 3000 PC Desktop
Windows XP freezes up when trying to reinstall on my Dell
You need to copy the restore partitions to a cd for back up.the wipe the drive using drivescrubber.also have a start up disc for back up.wiping the drive from back to front should keep the basic files for dos.its easy and there is a free version.
Sep 20, 2009 | Dell Dimension 3000® Pentium® 4...
Installing new OS
If you chose delete partition, ensure that you have saved your data, this will delete all data and format the hard drive to install your new system.
It is the est way to get rid of viruses, bue it will delete everything from hard disk.
If you chose delete partition, chose create new partition afterward, and then format. That is the way it works.
May 11, 2009 | HP Pavilion a1610n PC Desktop
I have windows xp media center. my computer has been infected with some kind of virus. i have tried to reinstall my os but apparently the recovery partition is also infected and it will not let me...
You will need a bootable antivirus solution to clean the viruses off of the machine if it's that bad, or at least that is the easiest way I know of.
Look, here is the real deal, your PC when booted to the hard drive into windows OS has what are called OS protected files. That means that even the best scanner will not remove it totally from the machine while booted in Windows OS.
When you use a bootable AV solution it runs the OS from the CD, then when you are scanning the drive for those little nasties, it can be remove, because the OS on the drive is not protecting them.
However be aware when using this method, that any files can and will be removed!!! The way I look at it, if it's a virus I don't want it on my hard drive! period! Then once the virus is removed format and reinstall the OS. Sorry to hear about your Recovery Partition!
There are ways to make these yourself, but if you don't know what your doing, relax Bart has you covered!
Check that out, that should fix you up. Yeah I know this is not a free solution, but one I know will work!
Mar 10, 2009 | eMachines T5048 PC Desktop
Slowing computer
I came across this forum which I think could be of some use to you. Read through the discussion
http://forums.cnet.com/5208-6122_102-0.html?forumID=44&threadID=201192&messageID=2158097
I hope this helps you resolve your problem
Feb 11, 2009 | Dell OptiPlex GX280 PC Desktop
Reformating my gateway E 4100
reformatting a drive is a big undertaking, formating the drive will erase everything, including viruses, before you format you need to make sure you have all the discs including the windows disc, driver discs, and a factory restore disc, also you make check the documentation on your system because alot of the gaetway, dell, emachines systems have restore partitions installed on the drive. Also youll need alot of coffee and alot of time, most importantly aside from the windows disc youll need a driver disc for any ethernet or wireless card you have installed. without this you will not have access to the internet most likely and donloading updated drivers is very helpful. This is a time consuming proccess unless there is a restore partition on the harddrive, the documentation will tell you how toaccess it if it exists, if not a restore disc will be nice.
Dec 13, 2008 | Gateway E-4100 PC Desktop
Dell Dimension 4600 PC Desktop Logo
164 people viewed this question
Alun Cox
