Question about Whirlpool Washing Machines
My front loading washer is not draining. F02 code keeps coming up. I cleaned the drain hose wondering if there is anything else beyond the drain hose that I can clean.
  • 413 Answers
Remove the bottom access panel. There you will find a pump filter that you can unscrew and remove debris. UNSCREW AND DRAIN SLOWLY as there will be lots of water to catch..
Posted on Jun 04, 2008
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F 02 WARNING KEEPS COMING UP.. i FOLLOW THE MANUAL AND HIT THE CANCEL BUTTON TWICE AND UNPLUG THE MACHINE. I CHECK TO SEE IF THE LINE IS CLOGGED AND I CANT FIND ANYTHING.. THEN AFTER A WHILE IT STARTS BUT...
F02 is a drain error in your whirlpool Duet washer, if the unit is unable to drain then after 4 minutes it will display sud and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Feb 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F02
The f02 error code is caused when the unit control thinks there is still water in the tub after it has tried to drain. If the washer is full of soap suds it will also display an f02 error code. You will need to use only name brand HE detergent. If your washer is not draining the water out you will need to clean the pump filter. I have provided the instructions below. Run the washer in a drain and spin to ensure the pump is running. If the washer has no water and no suds the problem will be either the pressure switch or a plugged pressure hose. To check the pressure hose you will need to remove the top and remove the hose from the pressure switch.
Jan 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F2 code keeps appearing and then beep occurs and washer stops during random cycles. Have had washer repaired numerous times.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
cleaning a drain pump Check drain pump for foreign objects
• If the above does not correct the problem replace the pump
Oct 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f02 comes up
The f02 error code is caused when the unit control thinks there is still water in the tub after it has tried to drain. If the washer is full of soap suds it will also display an f02 error code. You will need to use only name brand HE detergent. If your washer is not draining the water out you will need to clean the pump filter. I have provided the instructions below. Run the washer in a drain and spin to ensure the pump is running. If the washer has no water and no suds the problem will be either the pressure switch or a plugged pressure hose. To check the pressure hose you will need to remove the top and remove the hose from the pressure switch. Ensure the hose is clear by blowing into it. If the hose is clear I recommend replacing the pressure switch.
Mar 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I keep getting an error code that flashes F02
"F02" is a Long Drain error code. The following link explains how to troubleshoot:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
The majority of the time, all you have to do to correct this problem is to clean out the drain pump reservoir or drain hoses. Follow the advice in the link provided. If all preliminary checks do not solve your problem, the manufacturer recommends replacing the drain pump. If you have questions, please let me know. I hope this helps you.
Jul 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error codes
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain pump filter for foreign objects
Feb 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE flashing code F02...not draining. help.
no noeed to clean that justyet, i would imagine that the blockageis in the pump housing itself, you can gain acess to this by removing the lower panel of washer and unscrewing the "button trap"
Jan 26, 2009 | Kenmore 42822 Front Load Washer
F-02
Please read the following link. This explains what to do if you get the "F02" error code.
If cleaning the drain hose is not clearing the problem for you, then you need to check the drain pump and/or the drain hose from the wash tub to the pump. These areas are notorious for clogging with debris.
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal De
