Question about Maytag Dryers
Cylinder seal i have a new seal to put in my dryer but i have no clue in how to do it ...could someone please tell me how it is done ...thank you
  • 550 Answers
For most dryers,
Go buy HiTemperature silicone adhesive (tube)
tools required couple pairs locking pliers/visegrips screwdrivers
Unplug dryer
remove the front cover, either
  • couple screws at the bottom and spring clips to pop off with a screw driver OR
  • couple of spring clips to hold the top lid on, then screws top and bottom of both sides
    examine the case to find the exact mounting
unclip cables from door switch
set front panel aside
unhook drive belt from tensioner pulley
pull drum forward and out
remove old felt
scrape off old adhesive
put adhesive per instructions (some 2 surfaces some 1) on drum/felt
clip felt in place on drum with visegrip at 1 point
stretch felt around drum, gluing and clipping in place with vicegrips as you go
allow glue to set
reassemble in reverse order
wow took longer to type than it actually takes to do it
Posted on Jun 05, 2008
A friend asked my to look at his bike. He blew it up and replaced piston... ran for 5 weeks and blew again. Got another piston and ring and it had NO compression . Long story short.. I ordered a NEW...
Hi,,ok that is a lot of wasted money spent,,the power valve plays little role in compression,,the FIRST thing to do is remove the flywheel and check the crank seal,,the compression has to be going somewhere,,,and the stator side crank seal is almost allways to blame(blows engines real fast,,sucks air,motor runs lean and bang!)
good luck
Mar 28, 2011 | 2003 Suzuki RM 125
Has a smell of burnig oil after driving for just a short time, heads, timing belt and spark plugs are all new... can you help me????
Do you have any evidence of oil leaks?
These engines are notorious for leaking oil, both the V6 and the 4 cylinder.
On the V6 the rear valve cover gasket and cam seals are both regular leaks, and typically last about 60k miles each before leaking again.
On 4 cylinders the distributor o-ring or distributor plug for DIS models is a heavy leaker as well.
I understand you have a lot of new parts, but some of these things are known to fail on installation when done by someone not extensively familiar with the product. If you need further assistance, please ask and I will do by best to assist you.
Thanks for using Fixya
Oct 22, 2009 | 1996 Toyota Camry
Door seal for WDB 1074T
Hi Edward, unfortunately I don't know. But PLEASE can you tell me how to work the dryer I have just been given the same model but can't work out how to dry.
PLEASE Veronica
Feb 17, 2009 | Hotpoint Aquarius WD640 Front Load...
Kenmore Dryer won't work after changing belt.
thanks for the question when it sparked it could have blown a fuse or breaker make sure you have240 volts at dryer. that should solve the problem thanks the appliance doc
Sep 15, 2008 | Kenmore Dryers
Rubber door seal
Try here: http://www.searspartsdirect.com
Jul 12, 2008 | Hoover HDV7FM Electric Dryer
FITTING NEW DOOR SEAL ON WHIRLPOOL AWM5125
this is a complex repair and the machine complet frount has to be removed
May 10, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
HOW DO I ?
You probably need to thread the new belt over the drum by removing the circular rubber front seal temporarily. After putting the seal back on, ease the belt into the correct position and thread over the pulley on the motor. You will probably find it easier to put it over the pulley wheel of the motor first, with the belt partially off the drum. Then rotate the drum manually whilst easing the belt over it.
Mar 24, 2008 | Dryers
Help with Dryer Seal Installation
check at sears parts department they can brig it up on the cnnputer for you
Dec 12, 2007 | Kenmore Elite HE4 Electric Dryer
Amana Dryer belt instalation
Remove the power to the unit and the bottom access panel. Remove the front bulkhhead where the drum sits on by undoing four screws one for each corner.Verify felt seal on exhaust fan cover is airtight on flange of duct. If seal is installed improperly air flow will be restricted which can cause poor dryer performance.Belt must be positioned around cylinder between center and rear bafflescrews with the ribbed surface against the cylinder. You gotta push up on the spring loaded idler pulley the easily slip on the belt to the motor shaft. make sure that the ribbed part of the belt wraps around the drum and motor shaft and not kinked.
Jul 31, 2007 | Amana DLE330RAW Electric Dryer
Dryers Logo
115 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
