Question about Hitachi 61HDX98B 61" Rear Projection Television
No sound I inherited this TV and had dish network out for satellite hookup. There is no sound coming from the speakers but the picture is fine. Help! The sound on the TV no longer works. Plugged the 3 monitor ports A/V into my surround sound video 3. It worked fine for a year now no sound comes out of the surround sound or tv when watching tv/DISH. Video is fine. Note: The other audio ports work fine for my dvd and vcr on that tv. Tried swapping video and audio ports as well as cables. Everything tested fine. The problem seems to point to the L and R audio ports on my monitor feed on the back of the tv. Strange thing is that it worked for 5 minutes yesterday but after turning it off for a minute and turning it back on, the audio again quit. Please help.
  • 304 Answers
This might be configuration problem. Some TV Audio and AUX Ports we have to manually select from remote. Please check the configuration settings or else please refer the TV manual for Audio settings.
Hope soon you will rectify the problem.,
Bye...
Posted on Jun 04, 2008
  • 2,296 Answers
Check in your audio settings and make sure that the external speakers are OFF.
If they are OFF, is more likely a defective audio amplifier IC that will need to be replace or you could also have a loose connection in the speakers wiring inside the TV.
    Master:
  • 555 Answers
Sounds like a loose connection that has finally failed in the audio out circuit
  • Matt Jurach
    Matt Jurach Jun 04, 2008
    Do you have any other audio-out ports, like S/PDIF or TOSLINK?
To begin with I have Dish network my TV went off and since then in order to have picture and sound i have hookup HDMI cable and also video cable to have picture and sound
You need to set up the dish box for the correct resolution ie 720/1080 etc.
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Jan 05, 2017 | DISH Network Televison & Video
The picture goes off on occasion. We turn the TV off and in a few seconds it works. tonight, the tv went off but the sound did not come back. Dish network is working. We get sound in the speakers if...
I would check the cabling coming from your receiver to the TV. If the cabling is connected firmly try replacing it.
Daniel Busa
DISH Network Customer Service
Feb 06, 2011 | Samsung HL-S6187W 61 in. HDTV
Unhooked all lines in back of tv cant remember to rehook up have2
granmabj,
There are common connections to each receiver but there are unique connections also depending on the receiver. Solo receivers have a coax cable coming from the Dish outside connected to Satellite In. Duo receivers and DVR HD receivers have the coax cable that comes from the dish outside that connects to Satellite 1 and Satellite 2 using a splitter. There is also a cable (coax, RCA (yellow, white, red) or component (green, blue, red - video, white, red - audio) or an HDMI if HD) connected from the receiver to the TV 1. For a duo receiver TV 2 may be backfed on the cable coming from the dish outside using diplexers. This may sound confusing but you can call 1-800-333-3474 for assistance.
Ray Calo
DISH Network
Jul 23, 2010 | DISH Network DVR-625 DTV Receiver /...
Satellite Receiver to Yamaha Receiver
I've just experienced the same thing with a new Pioneer VSX-820-K receiver
May 10, 2010 | DISH Network ViP 612
Toshiba CN36X81 television.. NO Sound... Great Picture. Using the TV2 output of a DISH Network HD receiver... TV2 output is std def, coax output. Using a different TV I get picture and sound... but not...
IF coming in via, the "Dish" networked receiver, please check that this volume is turned way up, on the TV. and then control the the Volume, with the Dish Remote, often this is a problem, as one is turned down, and the other cannot turn that up, simply try syncing the Volume controls, UP on TV, control the Audio with dish remote. thats all i can think of. Check by feeding a signal IN from an AV, source, ie: Yellow, Video, & Red& White, Audio. Turn TV UP and check, IF it responds to this all is well. If NOT then you do indeed have a fault, with the TV.
Mar 27, 2010 | Toshiba CN36X81 TV
It sounds like either on the 612 or the Yamaha Receiver that the HDMI port is faulty, thus causing the flashing picture. It sounds like the 612 to the TV works fine. I would recommend replacing the Yamaha, and if problem persists then try replacing the 612.
Mar 18, 2010 | DISH Network ViP 612
How do I hook up my Dish Satelite to it?
should go from your satellite to dish box might say sat on bck of box then the next [connection think says tv that should go to tv itsself or dvd vcr whatever ur hooking up to it then from that point hook it to ur tv
Oct 23, 2008 | JVC AV-56WP74 56" Rear Projection...
No sound
Look in the menus for a setting to turn the speakers on and off. Make sure there isn't a switch on the back to turn off the internal speakers.
May 24, 2008 | Hitachi 61HDX98B 61" Rear Projection...
HD Hookup on Dish Network 2nd Location
In order for you to receive HD broadcasting you must have a HD-TV, otherwise you wont get the picture in HD. Also I should point out that you need to make sure that the signal itself is being broadcast in HD.
Apr 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Lost my picture when went to pip
Check your PIP source. I couldnt figure out my LCD pip, and why it wasnt working either until I was able to switch the source. It was automatically using a source that didnt have anything hooked up to, I had to switch mine in order for it to work. Try that and see if that might be the case. let me know. thanks!
Sep 24, 2007 | Mitsubishi VS-55705 55" Rear Projection...
Hitachi 61HDX98B 61" Rear Projection Television Logo
190 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
