Question about Linksys Wireless-G WRT54G Router
When I try to listen to anything on my speaker all I get is a snapping sound that drowns out what ever is coming out of my speaker. This was not there before I installed
  • 48 Answers
Speaker connected to your computer? i think the problem is not linked to the router. anyway, what happened if the router is off?
better connect your pc directly to your modem then check if you have the same problem. if the same problem happens then it has something to do with the pc.
Posted on Jun 05, 2008
Connecting 4 ohm speakers
I don't think it has anything to do with the impedance. The amp and speakers are well in the allowed limits. The only time this is a problem is if you connect an amp with a greater impedance then the speakers.
This sounds like something to do with the HK 990. It could have a fault on it. You could try listening with headphones if the HK 990 has a socket for them. If they have low sound, there's an electrical fault in the power amp of the HK 990.
Jun 09, 2012 | Harman Kardon Harman HK 990 Amplifier
I cannot listen to anything
Check that the sound is not muted from audio properties on control panel.
If it is not that you may need to reinstall the driver.
Feb 28, 2009 | Toshiba Satellite Pro 4600 Notebook
Hey, I've got an HP Compaq D530 SFF desktop machine whose sound card uses the SoundMAX drivers. The problem is that when I connect earphones/headphones on the front panel, and try to listen to music or...
if you go to the bios (restart computer and press del to go to setup) you should be able to look around and find the option for internal speaker. Set that option to disable and do not change anything else unless you know your way around. Save it and restart afterwards and it should disable the internal speakers.
May 06, 2011 | HP Compaq Evo d530 PC Desktop
I have just set up skype on my laptop and tried using the echo /sound test. Though my mic seems to be working I do no hear anything. I have checked the sound settings and skype does play sounds through my...
If you are running Windows 7 you can have audio set up to listen to the mic. I would not recommend this though as there is a slight delay from you talking to it coming out of the headphone. This can cause you to stumble on your words. But solely for testing purposes do this if you use Windows 7:
1. RIght click on the speaker icon in the lower right corner of your display and select recording devices.
2. Make sure the microphone you use is highlighted blue then click properties button in lower right corner of the window.
3. Click on the listen tab, then check the box that says listen to this device.wdaexodus.png
Mar 05, 2011 | Cyber Acoustics AC-201 Consumer Headset
No sounds in my speakers and even in my laptop alone... can't even listen to anything...:( please help me with this... ty..!
Reinstall your sound drivers, this should fix the problem.
The sound drivers come with the drivers CD that came with your laptop
Jan 04, 2010 | Computers & Internet
Scratchy sound from cd/dvd combo
sounds like the speakers are either damaged or have gotten water in them and damage the laptop speakers.
Mar 29, 2009 | HP Pavilion Media Center M1090n (PC100A)...
Static noise coming out of speakers
What sort of computer do you have? Is it a laptop or desktop? Many laptops have this problem and it is quite widespread in laptops. The crackling or humming noise could be a result of interference from the mains power signal.
If it's a laptop, try running it on battery alone (take out the mains power cord). My laptop has this kind of noise in speakers when running on mains electrical supply, but it goes away like magic when I run it on battery.
A more long-term solution is to buy a 'Ground Loop Isolator' and insert it between your computer and the speakers/earphones. They are quite cheap and you could get it for under £10. It removes all static noise and you'll hear crystal clear sound.
Jan 01, 2009 | Dell A215 Computer Speakers
Acura legend radio
Sounds like the speaker is blown - factory speakers are usually pretty cheaply made and not very high quality, so even normal listening volumes can destroy them - you don't have to crank the radio to blow them. If the speaker is on the rear deck, it may be accessible from inside the trunk - take a look there and see if it unbolts.
Aug 26, 2008 | 1992 Acura Legend
Computer speakers.
try uninstalling your sound card and installing it again be shure you have instalation cd for your sound card or correct drivers..
Mar 28, 2008 | Audio Players & Recorders
Snap, crackle sound from Sanyo TV
It sounds to me as if possibly ya Main IC Amp Chip & OR the Output Capacitors are failing... Sometimes it is a sign of a power supply on it's way out... Either way it's time for a repair shop quote. Either that or it may be the speakers crossovers... to check this, if you can, try another set of speaker... see if problem is still there. If it IS, then it IS most probably as I said above.. If NOT then it may be one or both of the "Crossover Network" in each speaker...
Sep 01, 2007 | Sanyo AVM-3659S 36" TV
Linksys Wireless-G WRT54G Router Logo
136 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
