Question about Compaq Presario Laptop
Missing cdw/dvd I've done everything that is to be done by the computer to get it to reconize this drive but nothing seems to work it keep saying that it is missing and that there's an error code 39 of done all the troubleshooting updating there is to do for it but it still appears in the device manager with a yellow !.... please help i would like to watch my dvd and listen to my cds again.... I even tryed restoring anything i removed but that didn't worked either ... i noticed I may have removed something called athlon 64 processor driver... Please tell me that didn't ruin everything.... Please help!!! thank you
    Problem Solver:
  • 10 Answers
I had this same issue with my Toshiba laptop, i was able to fix it by a registry entry.
If this is a Vista machine, your'e in luck, follow the instructions below.
Click Start then Run and type regedit...click "Ok"
In the left pane, expand (click +) HKEY_LOCAL_MACHINE, then SYSTEM, then CurrentControlSet, then Control, then Class, and click on {4D36E965-E325-11CE-BFC1-08002BE10318} In the right pane, are UpperFilters and/or LowerFilters listed? If so follow the steps below:
Right click on {4D36E965-E325-11CE-BFC1-08002BE10318} and choose "Export"...name this file filters and save it to the desktop.
Right click on LowerFilters and choose "Delete"...do the same for UpperFilters. Log off Windows and then back on. Check the drives.
Posted on Jun 04, 2008
I cannot get my Gateway zx6961 out of safe mode, I've tried pressing f12 like it says,and going to c drive and doing a system scan on reboot but nothing I've done has worked yet. Need help,
Boot with a Win 7 disc, and choose Repair Your Computer. Then use Startup Repair option.
If this does not work, use the Re-install Windows option. This should install on top and not wipe out.
A free legal Windows image can be downloaded. Check the MS Product Key sticker for what version your system came with. You may have to use your key. IT MUST BE THE SAME VERSION
Windows 7 Home Premium SP1 64bit.
http://www.mydigitallife.info/windows-7-sp1-binary-patch-files-for-iso-image-edition-converterchanger/
Windows 7 Home Premium 64bit.
http://msft-dnl.digitalrivercontent.net/msvista/pub/X15-65733/X15-65733.iso
Download correct version and burn onto DVD to use.
Oct 07, 2012 | Gateway ZX6961 All-in-One Computer - Intel...
Sylvania (SRD3900) DVD Player / VCR Combo i can't seem to plug in the red/white/yellow cables into the right places directly to my old toshiba tv to play either tapes or dvds. can you instruct me? thanks.
Greetings - It's very simple so I'll show you how and then I think it may be another problem (nothing broken).
You need to plug the corresponding color cables into to outputs on your player I've circled above and then into the corresponding inputs on the TV. You've probably done this correctly.
PLUS - You have to, using the remote for the player, set the source to either DVD or VCR and then you have to, finally, on your TV set the input (with the remote) to what is called probably VIDEO or VIDEO1. If there is still nothing on the screen keep (with the DVD or Tape playing) hitting the TV remote input button until you see an image or you've come around to where you started.
Unless something is broken (unlikely) you should be able to watch DVD's or Tapes depending on what input you select on the player.
If it's not working you've somehow missed a step or the Video input on the TV is called something else. If that happens come back here and give the player AND TV brand/model info and someone will be able resolve your problem.
Good Luck and thanks for using Fix Ya.
Mikeywaf
Apr 21, 2011 | Sylvania (SRDD495) DVD Player/VCR
Dell Inspiron 4100 won't play dvd, but will play cd's
You have problem with your cd-drive's lens.
May 20, 2017 | Dell DVD-rom DVD Drive
DVD/CDROM NOT WORKING
Hi, it appears that CDW/DVDRAM is only detected in BIOS but in normal windows. This is a known issue from Microsoft eventhough you are using Windows Xp or Vista the CDW/DVDROM is not detected and does not appear in My computer icon. This can be easily fixed by a registry tweaks.
Please click on this link http://support.microsoft.com/kb/929461/en-us and then delete the upper/lowerfilters which is blocking the CDW/DVDROM to appear on your windows.
Hope this helps!!!
Thanks
Sep 11, 2008 | Computers & Internet
DVD/CD rom drive issues
Hi, it appears that CDW/DVDROM is only detected in BIOS but in normal windows. This is a known issue from Microsoft eventhough you are using Windows Xp or Vista the CDW/DVDROM is not detected and does not appear in My computer icon. This can be easily fixed by a registry tweaks.
Hope this helps!!!
Thanks
Sep 05, 2008 | Compaq Computers & Internet
I have a Sony Vaio desktop with Windows Home Premium and my CD/DVD drive does not work anymore. There is an error message which says "Windows cannot load the device driver for this hardware. The...
Your DVD/CD Drive laser reader head is not working as it will show this message when ever you insert a cd/dvd disc - Try to replace it with a new one even head assembly can be also replaced
Aug 12, 2008 | Computers & Internet
DVD Disc in my Toshiba Laptop Corrupted
make uninstall driver for CDW/DVD then re-boot.
Install the driver for CDW/DVD and use. It will fix your problem.
Thanks
Iqbal
Apr 13, 2008 | Computers & Internet
Install dvd benq dw1620 in dell 2300 xp
you have to remember to set the Jumpers on the drive to assigh it Master or Slave,  if this is not done it will conflict with the other drive on the IDE cable, (you would usually match the setting of the drive you removed)
This setting is assigned using a jumper on a block of six pins which is usually located next to the 40 pin IDE connector.
Oct 28, 2007 | BenQ 1620PRO DVD±RW Dual Layer...
Matshita drivers on toshiba notebook
Code 39 loadTOCNode(2, 'moreinformation'); Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Recommended resolution loadTOCNode(3, 'moreinformation');
Reasons for this error include a driver that is not present; a binary file that is corrupted; a file I/O problem, or a driver that references an entry point in another binary file that could not be loaded.
Uninstall the driver, and then click Scan for hardware changes to reinstall or upgrade the driver.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Keep me posted.
Oct 13, 2007 | Toshiba Style Bay DVD-RAM Drive Kit...
Compaq Presario Laptop Logo
26 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
