This is a scheduled maintenance programmed into all of these machines. It pops up when the machine crosses a certain "milage." If your machine is still making nice copies and prints it's nothing to worry about.
If it is only causing an image problem when you copy and not when you print, then there is something wrong with the optics under the glass. Check and see if you have any mirrors out of place or if the scanner looks crooked. If you have the machine set up to scan try and scan to SMB or email to see if it still has the problem. If everything looks correct under the glass and scans to SMB and email look bad like the copies, you may have a bad CCD assembly, or a bad board.
At machine you can select 'monitor'from the bottom of the screen and select the log for copy or print. If you have network access to the machine you can use the RUI, it's much clearer. Just type in the IP address of your machine and the RUI interface will be displayed. You'll find print, scan and copy logs easy to find there and print.
I would reset the Photo conductor unit. It will have a Green drum in it. I would make sure it is set in the machine all the way, and that the drum door opens completly. BLANK copies are and indication the paper has NOT touched the drum to recieve an image.
There are small mirrors on the copy lamp, wipe with a clean dry soft cloth. Remove the drum unit and wipe upper part where the drum unit was and make sure the area is clean.
check the drum is seated well or not,check the drum drive lock, check the drum is rotating freely or not.check the chargin g rollor are seated well or not
finally replace the drum and see the result.
best of luck.
Hi, I have discovered the solution for my problem related before: It was the Gear Drive of the Development Unit.
Now, who can advise me in how to find this spare part in Johannesburg (South Africa).
Thanks!
copy printing machine
copies print on slant
