We have just recived our prints and my partners head has been cut off we are not happy with them very dissapointed and are wanting either a freepost address to return them to or a prepaid enverlope sent out when u get them back if you could send some more out corrected and p&p free has we have already paid postage once we cant understand how it happened because the original print on the computor is fine can u sort this out as soon as possible we only have 30 days to return them back to yourselfs and dont intend on keeping damaged goods address 20 chinook highwoods colchester essex co49rn
  • 114 Answers
This cannot be solved here at FixYa.com
Posted on Jun 12, 2008
Which types treats can i arrange on my birthday party?
You can arrange pizza food. I think it is the good food for arrange in birthday party.Its good food.But you needs to get good quality pizza.You can arrange drinks beside pizza Its a good idea.To get know more about that try this site
BBQ chicken pizza recipe
Feb 06, 2014 | Sleeping Partners Set of 6 Felt...
Carburator removal partner k 750
Remove the covers and the air filter, the screw heads are Torq 27, with the covers removed, insert a Torq 27 tool through the small hole in the black air filter housing ( close to the back of the cylinder ) and undo the screw that goes into the cylinder, now grab the air filter housing and pull firmly toward the back of the machine, it will come away as an assembly along with the carb, lift up far enough to un clip the throttle rod from the trigger, un hook the fuel hose from the carb, you will now have the assembly away from the machine.
Jun 04, 2012 | Husqvarna Partner Gas Powered Cut Off Saw...
When I push the button on my head set to answer a call the lift thing lifts the reciver cut i cant hear anything, it stays on intercom and does not let me hear a line....
Wireless units using a handset lifter need to connect to the phone through the handset jack of the phone. That's one thing to check. Also, you want to make sure the round compatibility dial on the left side of the base is set correctly (normally #1 at the 3 o'clock setting to match indicator ridge).
Good luck from Headsets Direct - 800-914-7996.
Aug 24, 2011 | Plantronics Radio Communications
Have two Brother DCP-145C printers and use compatible inks. Now the yellow won't print in either machine. Despite trying cleaning cycles and replacing the yellow cartridges, the test print will not show...
100% you need to replace the print head,in the future use only original cartrige brother not refill or compatible cartridge.If you want to replace the print head you need to take care is difficult to change the print head,you must to unzip the all printer.If a have been useful please give me a vote.
Mar 22, 2011 | Brother DCP 130C All-In-One InkJet Printer
My gtalk get freeze while chatting in vista
windows vista is well know OS mistake. every app on vista runs slow, or gives unreasonable errors. i suggest you to install other os like windows xp professional or windows 7. try with win 7. you won't be dissapointed. it offers a lot of new features. it's faster and much preetier.
Jul 03, 2010 | Google Talk
When i recive fax or when i print it just it prints empty page
If the fax is acting like it is printing (print head moving back and fourth) then it sounds like the ink cartridge is clogged. Remove the cartridge and clean with cotton swab and rubbing alcohol. If this helps a little or not at all replace the ink cartridge. If it still prints blank, the print head could be the problem (this is where the ink cartridge goes). At this point it would be cheaper to replace the fax.
May 14, 2010 | HP J3680 Officejet All In One Printer
My printer seems to have lines throughout the entire job i've tried everything to no avail, could it be the head is damaged or could it be the cutting strip platten
in the printer properties use the cleaning option there to clean the print head.If this fails you might want to try some Kleanex to clean the print head.
Good luck
Nov 14, 2009 | Office Equipment & Supplies
Ink not working
Assuming that all your cartridges are clean. Then the next step is remove your print head and clean it. If you haven't done this before, it is very easy. First printer's remove your cartridges and life the lever on the upper right hand side of the print head. If you have done this, skip the next paragraph.
Gently remove the print head and put it in a container, and fill it with hot water. I usualy empty the contents of a small bottle of ink jet cartridge cleaner into the tub as well. You should see the ink literally seep out of your print head. It's best to leave it for a few hours, but if you can't wait, leave it for several minutes, and gently press a folded paper towel against the print head base. It should make a clean impression. Dry it and put it back in your printer. Test print.
If your inks are clean, and you have cleaned the head. It's unlikely, but there is an outside chance that the contacts at the back of the print head carriage could be dirty. Gently clean them with a cotton bud dipped in ink jet cleaning fluid.
If it still dosen't work, then it looks likely that your print head is damaged and will need to be replaced. You can buy replacement print heads on the internet for about £50 pounds. (UK)
However, with the price of printers falling, it might be better to cut your losses and buy a new printer. I would pay a bit more and go for the Canon IP4600 which is the nearest replacement model to the IP3000. It also has separate ink tanks and significantly a removable print head. The down side is that the inks are chipped, so if you plan to refill them, you will need to plan to buy a Canon cartridge ink resetter to keep your printer happy. (About £20)
Hope it helps.
Aug 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Ink well cleaners
There is a design reason why the print heads are changed when you change an ink cartridge is changed. The print head isn't made to be reused and the quality of your print will suffer at some point if you reuse the same print head 6 or 7 times. I would get new cartridges and be happy with the print quality that a new cartridges will bring.
Nov 10, 2008 | Brother MFC-5860CN InkJet Printer
Brother DCP 115C
Yes, another suggestion is to give it back to the dealer or a service partner which can be found on the homepage of brother. If the printer is 3 months old you are in guarantee time. Its a common problem with the printheads that one color (M or Y) is lost somehow sometime...! (Valveproblem within the printhead) You cant fix it yourself (May need a new printhead).
Sep 27, 2007 | Brother DCP-110C All-In-One InkJet Printer
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
