Question about Vodavi Starplus SP7314-08 Corded Phone
Phone doesn't ring at station
When we receive a phone call, it rings on another phone, but not the one at my desk. I am told the 19th button (next to last on the bottom row) is for the ringer and should show a green light. When I press this, my phone rings once and the display says VA-HF mode and the light stays on, but I still get no ring here. Is that even applicable to my problem - VA-HF = voice announce - hands free? Any help is appreciated. Peace.
Sounds like your station (phone) is set to not ring. You need to check your ring assignment.
Feat # *
Enter password (default is 000000)
Press the soft key under "show"
Press the soft key under "next" until 1. STATION appears in the display.
Press the soft key under "show" SHOW STA:_ appears.
Enter your station number and press the show soft key
Press the "next" soft key until RING ASSIGNMENT shows on the display.
Press the "show" soft key. You will see CO LINE 1 : followed by NONE or DAY or NITE or BOTH.
If it says NONE, your phone never rings for an incoming call. If DAY or NIGHT your phone rings depending on the time of day and the time definitions for DAY and NIGHT programmed into the KEY unit. If it says BOTH, your phone should ring all the time.
If you need to change the setting, press the "chg" soft key until the desired setting comes up.
When you're done with LINE 1, press the "next" soft key to move to the next line. Repeat the process for all your active lines. Obvisously changing settings on lines with no CO connection will have no affect.
While your in the mode, check your RECEIVE ASSIGNM as well to make sure your phone is configured to receive incoming call. It was the station feature just before the RING ASSIGNMENT feature.
Hope this helps.
Posted on Oct 29, 2008
Desk phone external speaker
Here are a couple of options, 1) go to a wirless headset so you can hear the phone even if your not at the phone. I'm not sure how old this phone/station is but if it doesn't have a headset button option, you can get a cradle that picks up the phone when you push a button on the headset. 2) You can contact your phone system tech (whoever sold you the Norstar) and ask they install an external horn/ringer. This is very common in warehouses and manuafactor floors, etc.
May 16, 2012 | NorStar M7310 Corded Phone
I just got the Jabra GO 6470: The desk phone doesn't ring in the headset, so if you're not within hearing distance of the desk phone (but within the 300 foot range of the base) you don't know...
what i gather from what you have said is that the headset doesn't ring at all. this would indicate to me that the headset is not paired with the base.
normally when pairing devices the base station will look for the device but at the same time you will have to hold the headset power button for at least 5 seconds for that the other device can capture the signal.
i will look into this for you but try this method if applicable but the bluetooth devices do have to be paired in order to work.
Jun 15, 2011 | Jabra GO 6470 Wireless Headset with Touch...
When calls come into the office ext. 10 rings. It's the receptionist's desk. However ext. 29 rings too. How can I stop ext. 29 from ringing on all incoming calls?
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Central telephone Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Oct 26, 2010 | AT&T Lucent MLS-12D Phone
My new job has a Lucent phone and it does not ring at my desk. The only phone I hear ringing is two doors down from my office. Please help me program my phone to ring at my desk. I all ready tried the...
1.) Are you refering to outside lines ringing?
2.) What if someone dials you on intercom does it ring then?
If #1 the phone SYSTEM usually has an option that you have to program and add you to the ring pool for the outside lines.
If #2 does not ring it is also a function to disallow ring, but it very well could be the phone. Since the line is all that matters and NOT the phone, you could try another phone at your location and see if the same happens. If it does, you will need to program the SYSTEM from either Ext. 10 or 11 to add you to the ring pool and allow ring.
Apr 28, 2010 | Lucent PARTNER18 Corded Phone
Line 5 doesn't ring on one phone
That is done thru config programming, you need to add line 5, appearance and ring to station. This will automatically put the line on your next line button.
f** config
Aug 06, 2009 | NorStar M7324 Telephone
Stations don't ring even though day ring and night ring enabled.
Sounds like the ring assignmet programming has defaulted.( all lines ring at station 4 only)
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
repeat for each line
Jul 20, 2009 | Samsung Prostar 816 Phone
I only want my Panasonic KX-T7453 desk phone to ring when, . . .
press the mode button 5 times and then use the jog dial to get the * down to nothing.
your phone should no longer ring.
Jun 11, 2009 | Panasonic KX-T7453 Corded Phone
Intertel GLX phone rings busy unless unplugged
You could have a bad phone try to swap it with a working one. If that does not work there could be a problem with the port in the system or cabling. Move to a new port or new cable
Jan 05, 2009 | Inter-Tel Intertel 6123300 GLX Executive...
I need my phone to ring at my desk
Turn the program toggle switch on (right side of KSU), go to the phone to be programmed and press the # button, then press the line button to ring, then pick up and then hang up handset. You should hear a confirmation tone. This will affect all line buttons, even the ones not pressed. Any line buttons not pressed will not ring. Do this at each phone.
Dec 30, 2008 | Inter-Tel Intertel 6123300 GLX Executive...
Trying to Transfer a Line to Ring at anothers desk after 4 rings.
When my boss is on the phone she wants all incoming calls to bounce to my line. or ring so she knows an incoming call is coming. what can we do?
Aug 29, 2008 | Mitel Superset 4025 Corded Phone...
Vodavi Starplus SP7314-08 Corded Phone Logo
1,148 people viewed this question
Top Vodavi Lands Phones Experts
Oloyede Monsuru
ray gallant
vince
Are you a Vodavi Lands Phone Expert? Answer questions, earn points and help others
