Question about Amana RanARG7302 Gas Kitchen Range
Amana Model ARGS7650E Oven Problem
I have an Amana Model ARGS7650E. The top burners and the broiler all work fine. The oven igniter comes on and heats up, but the gas doesn't come on. Even when holding a cigarette lighter to the burner, it doesn't light.
  • Anonymous Dec 08, 2008
    I have the same problem. I am looking into replacing the oven ignitor, but this does glow red and if you tap the gas control the gas comes on for a short time.
No matter that the igniter glows you must measure the current... If the current is less than 3.2 or 3.6 you must change it (this current is for the igniters with rectangular white base).The current to open the valve is the same that passed through the igniter so if it doesn't reach the proper value it will never open (or sometimes open sometimes not).Mine is not opening and the current is 2.9 so I'm going to replace it tomorrow.
Posted on Dec 26, 2008
  • 4 Answers
I was going to guess the gas control and the second persons comment only confirms it for me, but you guys are the ones spending the money on the parts. It is only my best guess.
Posted on Dec 11, 2008
2 Suggested Answers
bestdarngood
  • 3037 Answers
SOURCE: Trouble with an Amana oven
sounds like a bad valve that needs to be replaced. If that doesn't fix it let me know but 90% of the time this is the problem and the fix.
good luck and let me know if you have any other questions with this
Posted on Jun 06, 2008
Jun 06, 2008 | Amana RanARG7302 Gas Kitchen Range
Oven light is on and it is not getting warm...broiler and burners work fine
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Mar 06, 2011 | Amana Ovens
Amana gas oven not working
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
Aug 31, 2009 | Amana ARGS7650SS Gas Kitchen Range
The ignitor may be too weak to open the gas valve. If you have a volt/ohm meter capable of reading AMPS you can hook up to a ignitor wire and turn the oven ON. If you read less than 3.5 amps replace the ignitor. If 3.5 amps or more are read,replace the gas valve.
Aug 30, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana arg7800ww oven will not come up to temperature.
Your gas valve has a thermocouple circuit that will not let gas flow until the ignitor is hot enough. A failed ignitor can still glow but not be hot enough to open the gas valve. Replace your ignitor.
Jan 13, 2009 | Ovens
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
check the door switch
check the termocouple
hamid
hhamidi56@hotmail.com
Jul 26, 2008 | Amana RanARG7302 Gas Kitchen Range
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Amana RanARG7302 Gas Kitchen Range Logo
655 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
