Question about Belkin (F5D7230-4) Router (587009)
Cannot connect to internet through my laptop
Hi when i tried to go on my laptop today it wont connect to the internet even though my computer upstairs is running fine i really dont understand what the problem can be
  • 5 more comments
  • lowlyv Jun 04, 2008
    my internet symbol will not turn on
  • natz20 Jun 15, 2008
    i got a belkin router 54g a few weeks back i followed all the instructions and set it up everythinf worked great until last nite my internet just stopped working so i tried reinstalling the belkin and everytime i do it says its sucessful but when i try to connect to the internet wirelessly it wont work i now need to have the cable connected at all times.. it is not showing that i have a wireless network anymore to connect to how do i fix this?
  • AS_179 Aug 26, 2008
    My laptop is the only computer connected to the router, it shows there is local connection, but there is no access to internet. The router is connected to a wimax modem. Not sure what the problem is.
  • srmt25 Aug 30, 2008
    I have the same problem. I have been connected with the router for nearly a year and it seems that in the last 2 months it is getting more and more loss of connectivity. Now i cant even connect with out going straight out of my modem. Whats happening?????
  • PrabhakaranR Oct 09, 2008
    I have two laps with same config, brand and VISTA home premium OS. One is updated with all hotfixes and one is not....
    when i try to conenct the net directly from modem it connects with no problem with two laptops. but when i use to configure benklin 52g router with easy installation guide the laptop without updates can easily detects the router and setsup the password and other things, but the other laptop with all updates and hotfixes says that "no router is detected in any of your network adaptors". I dont find the problem with router as it connects with other laptop and also no problem with network adaptor as it connects directly with modem, then why the router and this laptop are making problems? is it because of updates and hotfixes i have?
    Please do help.
  • Rachel Dixon
    Rachel Dixon May 11, 2010
    What model and OS are you running? Did the above fix work? If not more info needed in order to give you the correct fix
    :0)
  • xCAUSALITYx
    xCAUSALITYx May 11, 2010
    Have you tried retarting the router, belkin routers sometimes lock up.
    Cheers
  • 905 Answers
Unplug the router for a little while ( I have the same router and it does the same thing) then plug back in and you sould be able to connect
Posted on Oct 07, 2008
Acer Laptop top connects to internet. Upstairs Desktop will not
Is the router hard wired to PC?? If not connect it with an ethernet cable.
Sep 11, 2012 | Acer Aspire 5735-6041 Notebook
Very odd situation so bare with me. I have a Sony vpcf 1 and have recently moved into a shared flat which uses a by home hub. It would a peer the Internet crashes have become far more frequent since my...
I have the same problem!!!
I just got the computer yesterday, but the only solution I've figured out is just going to the troubleshooter. It always works! But, if it detects an adapter malfunction repetitively, you have to restart the computer.
Sorry!
Jul 10, 2011 | Computers & Internet
ZyXEL P-330W wireless router
No it will not work you cannot connect a router to another router wirelessly and it will most likely not be detecting each other, routers are built to transmit internet signals from modems if you have a router and a computer but you do not have your own internet connection that will not work conencting to another router you will need USB Wifi Card transmitter/reciever to be able to connect to your friends wireless internet.
but if your friend only has a modem you can lend him your router and get a USB wifi transmitter/reciever to be able to connect to your router that is conencted to your friends modem this will work but will not work if you and you friend will both have a router creating a network.
Jun 20, 2010 | Zyxel Prestige P-330W Wireless Router...
I have an acer aspire 5920 that wont connect to internet even though my wireless is enabled ? its not a problem with the internet as my partner has a laptop an can connect
Try the firewall settings, turn off and if you can connect than thats the problem, failing that then try the security tab and set to lowest and bring up the level until you can't get on then knock back so you can. Also, copy all the settings from the computer that can connect to the one that can't.
Aug 23, 2009 | Acer Aspire 5920 AS5920 Notebook
Internet Applications wont connect - Vista
I am running Windows 7 (the new vista) so I hope I can help. Go to the "Start" button and select "Control Panel". Click on "Network and Internet" and then "Network and Sharing Center". You shouls see something like: Computer =====Network ====== Internet. If there is an "X" on one of the connections, that may help you decide which option further down to try. You can keep me posted if this helps to this point.
May 28, 2009 | Computers & Internet
I cant get on the internet,
Try to set your IP address to automatic then afterwards, go to Run and type "cmd". A command prompt window will appear, type the following commands:
ipconfig -release (press enter)
ipconfig -dnsflush (press enter)
ipconfig - renew (press enter)
after typing these commands, close the window and try to browse the internet. If the same thing happens,restart your computer and try browsing the internet again.
Mar 19, 2009 | Computers & Internet
No connectivity to 2nd desktop or laptop - although worked before
Hello....sudden loss of wireless on two computers, in the same home, may indicate that a powerful source of wireless interference has just arrived (since your wireless router light is still on).
1) Does the signal improve if you move the router, or move the laptop closer to the router?
2) Have you had any success with changing the channel on your router? (Login to router > select Wireless Settings > Channel)
If you have not moved furniture yourself, or installed a device which could interfere with the signal (eg a DECT phone), it's possible a neighbour's new router may be the culprit.
Please come back to Fixya if this does not help.
Jan 11, 2009 | NetGear WGR614 Router
Slow connection
Your slow connection could be affected by poor location wireless router (therefore poor signal strength), electrical interference, or even someone else with a wireless router transmitting on the same channel as your wireless router.
Try relocating your router away from solid walls, and/or move your computer or router to another location.
If your connection speed varies, could be electrical interference with appliance/s in your house, turn off all appliances, test your internet speed connecting then turn on one appliance at a time to determine which appliance is at fault (could have a faulty capacitor in the appliance)
Jul 24, 2008 | NetGear MR814 Wireless Router
Cable modem
Go and buy a router. Plug your existing modem into the WAN port and your computers into the LAN port. You could even get a wireless router and connect your upstairs computer wireless. Be sure to lock down your SSID (Wireless Access Point Broadcast Name) so your neighbors or people driving by don't get on and do bad things on your network.
May 31, 2008 | RCA Cable Modem DCM315R (11603540)
Signal Problems
try to bring another laptop to the location where you are having problem and see if the other laptop will have the same problem. if thats the case the problem is with the router. You can try upgrading the router's firmware or change the wireless channel
Apr 21, 2008 | NetGear WGR614 Wireless Router
Belkin (F5D7230-4) Router (587009) Logo
52 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
