Question about Canon PIXMA MP460 All-In-One InkJet Printer
Paper feeds unevenly
Right side feeds slightly ahead of left, paper skewed.
  • fozybear Jul 05, 2008
    Installed new cartridges and was working fine previously. damaged paperfeed upper tray after unpacking.. when ready for printing the paper feeds from the right and skews and screws it up, leading to a paper jam and no successful feed or printout. Will I need replacement feeder tray and service? if so Where and any other recommendations, Please. I have inspected internally as much as possible and cleaned and cleared any noticed obstructions/dust etc.
    Master:
  • 638 Answers
Your printers gears have got mis-aligned or may be even your paper feeder tray is not availble or not fitted properly, for gears problem u get your printer serviced.wish u success!!
Posted on Jun 04, 2008
Our printer is printing everything off center and skewed to the left so you can't read the amounts. What can we do to fix it?
Sounds like an uneven paper feed. Check the paper path and clean the rollers/wheels with isopropil alcohol and a Q tip. Also check the printing element that it is not catching on the paper.
Jan 25, 2011 | Star Micronics TSP100 Thermal Printer
Tip
My X2250 will not feed the single sheet of paper evenly. When looking at the...
Printer would not feed paper no matter how many sheets were in the bin or how clean the printer. I even cleaned the roller. The issue was I just needed a little more tension on the roller that pulled the paper in.
I removed the rear access door (see manual). Off to the left near the feeder roller you will see a spring. What I did is mover the spring to the END of the plastic arm that it is attached to (if it is missing ..you have a bigger problem). If you have moved your printer around a bit, the spring may have slipped down on to the arm and is no longer sitting at the end. This will extend the spring another 1/16 of an inch ...and that is all all it took for me. My printer will now feed a single sheet of paper with no issues. BTW: I put a drop of glue on it after so it would not slip off.
on Sep 28, 2008 | HP PSC 1610 All-In-One InkJet Printer
Paper is pulled into printer unevenly causing paper jam
Look closely at the "path" that the paper takes through the printer -- you probably have a small piece of paper stuck somewhere, that is causing the paper-feed to get "skewed".
Failing that, take the printer to a qualified technician.
May 26, 2010 | Dell V313w AllInOne InkJet Printer
When I print the image is printed at an angle tipped slightly to the right. It happened after putting in a new ink cartidge and I scanned in the test page. Scews everything printed. HP photosmart C4480
Remove and replace the cartridge again, I wonder if somehow you haven't canted them over somehow? Also check the paper is feeding OK, clean the Rollers, If one roller was just ever so slightly Ahead, from the other one, just a tiny bit, it would ever so slightly "Skew" the page? so check all that out.
Apr 18, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Canon mp190 pulls paper in right side only
Canon support has info regarding this problem for your model. You must be willing to type in the question:
"Paper feeds skewed" and click <Search> button.
Review the top solutions. I recommend that you clean your feed rollers.
Canon MP190 Feeds Skewed
Dec 20, 2009 | Canon PIXMA MP190 All-In-One InkJet...
It appears that the paper is not feeding on one side. The paper will begin to feed and then turn crooked.
First make sure that the left hand paper guide is up tight against the stack of paper in the feed tray.
If it is and the paper is still skewing then something is obstructing the path. This could be an internal part that has come loose, a piece of torn paper or a foreign object like a paperclip or wasp. Use a torch and peer down the feed chute and then look inside , examine the paper path carefully.
For info, the paper only feeds from the right side (as you look at the front of the printer)
Dec 08, 2009 | Canon PIXMA MP470 All-in-One Printer
Paper won't feed evenly
What I understand on this problem, it can be dirty feed wheels on one end.
It might be a paper tray that is bent more on one side, or hanging up on one side.
If it is a large roll that feeds paper, it is uneven presure on the paper causing the paer to go skewed.
If the paper is traveling up in the machine, the rollers in the back maybe the problem or the side door not closed all the way, causing some rollers to drive the papers and other rollers not touching the paper at all.
Oct 15, 2009 | Brother Office Equipment & Supplies
MP830, how to retrieve faxes in memory to my PC
- A margin appears
on printouts.
2 B Paper feed
Improper paper
feeding:
- Multi-feeding
- Skewed paper
feeding
- Paper jam
- Paper feeding from the
ASF
- Plain paper
- Highest print speed
(Custom setting to 5)
- In the high temperature
and high humidity
environment
- In the low temperature
and low humidity
environment
- With the maximum
amount of paper set (13
mm)
and high humidity
environment, paper
becomes wavy; in the
low temperature and
low humidity
environment, paper
curls significantly.
When the maximum
amount of paper is set
in the ASF, and if the
paper-return tab fits in a
wave or curl of the
paper, the tab slips and
does not catch paper
properly, causing paper
feed problems.
- Reduce the amount of
paper set in the ASF to
half (approx. 5 mm
high).
- Multiple sheets of
paper feed at the
same time.
- Paper feeds at an
angle.
- A paper jam
occurs.
3 C Print results
Skewed paper
feeding (at the
level of +/- 1%)
ASF
- Credit Card size
Since coaxial tolerance
between the pinch roller
and the LF roller, which
determines the paper
feed alignment, is
0.2mm, skewed paper
feeding can occur.
However, according to
the field data of current
models, the skewness
level caused by the
coaxial tolerance of
0.2mm is within the
criteria of +/- 1%, thus
the phenomenon is left
as is.
- Align the paper guide to
the paper edge tighter
than usual.
- Paper feeds at an
angle.
- A margin appears
on printouts.
4 A Print results
Soiling on the
back side of paper
(lines or streaks
parallel to the
paper feed
direction)
- After continuous
borderless printing of
small sized paper (such
as 4 x 6), when a larger
sized paper (such as A4)
is printed.
- With Photo Paper Plus
Double Sided or
postcards, the
phenomenon is likely to
be noticeable and to be
complained of by users,
as printing is performed
on both sides of such
paper.
In borderless printing,
printing is performed to
the size slightly larger
than the paper size, and
ink off the paper is
absorbed by the platen's
ink absorber. Absorbed
ink may attach to the
platen rib(s) after
several dozen sheets are
printed, causing soiling
at the leading edge of
paper or on the back
side of paper.
1. Perform Bottom plate
cleaning (from the
MP driver or via the
operation panel) up to
3 times*1.
2. If soiling on the paper
still remains after 3
times of Bottom plate
cleaning, wipe the
platen rib(s) and their
surroundings with a
cotton swab.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
Soiling on paper in
automatic duplex
printing (lines or
streaks
perpendicular to
the paper feed
direction)
- Automatic duplex
printing (Photo Paper
Plus Double Sided,
postcards, plain paper)
On the rib(s) inside the
sheet feed unit used for
duplex printing, ink
mist may accumulate,
smearing paper.
Temporary operational
solution:
Cancel automatic duplex
printing, and manually
print each side of paper.
Cleaning by user:
cleaning (from the
3 times*1.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
- Even after Bottom
plate cleaning
was performed,
and the platen
ribs were cleaned
with cotton swab,
paper gets
smeared.
2-10
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
HP PSC 2355 All-in-One Operating Problem
Introduction When the all-in-one detects a paper jam, the display will read, " Paper jam: Press OK to continue ." The computer might display the following message: " There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. " This document will assist in correcting paper feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. Clearing paper jams CAUTION: All paper jams must be removed from the back of the all-in-one through the rear access door. Pulling the paper from the front of the unit rotates the paper feed roller in the wrong direction and can cause damage to the all-in-one.
  1. Turn off the all-in-one and unplug the power cord.
  2. Turn the all-in-one around so the back of the unit is facing out.
  3. Open the rear access door:
    1. Locate the tab on the left side of the door and press it toward the right. The door will shift slightly to the right.
    2. As the door shifts to the right, pull the door out slightly to release.
    3. When the door is released, gently remove the door by sliding the door out and to the left.
    Figure 1: Removing the rear access door c00212276.jpg
  4. Inspect the pressure rollers on the access door. They should be clean and rotate easily. If needed, clean the rollers with a soft lint-free cloth lightly moistened with water (distilled water preferred). If the rollers do not rotate easily, they may need to be replaced.
  5. From the access door opening, gently remove the jammed paper.
  6. Remove the paper stack from the paper supply tray. Discard any paper damaged or bent.
  7. Re-stack the reload the paper into the paper supply tray. Push the stack into the tray until it stops.
  8. Re-seat the rear access door:
    1. Insert the two posts on the right of the door into the holes on the right side of the opening (as shown in the figure below).
    2. Press the tab on the left side of the door toward the right. The door will shift slightly to the right.
    3. As the door shifts to the right, push in the left side of the door to lock it into position.
    Figure 2: Rear access door posts c00212277.jpg
  9. Reconnect the power cord and turn on the unit.
Causes of recurring paper feed problems If paper feed problems occur repeatedly, one of the following might be the cause:
  • Something is obstructing the paper or print cartridge path. Open the cover of the all-in-one and check for obstructions.
  • The rear access door is unlocked or improperly seated. Follow the steps above to remove and re-seat the access door.
  • The paper width guide is not positioned against the paper. Adjust the paper width guide against the edge of the paper.
  • The paper is not supported. Paper should be flat and smooth with no folded, torn, or rough edges. Some glossy and/or coated papers, or reused paper (already printed on one side) can experience a higher incident of paper feed issues.
  • The paper tray is not fully extended.
  • The paper feed rollers need cleaning. Over time paper fibers and dust will stick to the rollers and should be removed. See instructions for cleaning the rollers below.
Paper jam message displays but no paper is jammed The print carriage might be jammed. Follow these steps to correct the problem:
  1. With the power on, lift the print cartridge access door. The print carriage should move to the access area located on the right. If the print carriage stays all the way left, reset the unit by unplugging the then plugging in the power cord. If the carriage still does not move to the right, continue with the steps below.
  2. Disconnect the power cord from the all-in-one.
  3. Remove both print cartridges.
  4. Push the print carriage slightly to the left and then to the right to verify that the print carriage is not jammed. If the print carriage will not move, check for obstructions under and around the carriage.
  5. Close the print cartridge access door.
  6. Plug in the power cord.
  7. When the " Insert Print Cartridges " message displays, open the print cartridge access door and insert the print cartridges. Verify that both cartridges are seated correctly and lock into position.
  8. If the error recurs, contact HP for assistance.
Envelopes The envelope flap can move with the grip of the rollers and cause paper feed problems. Use envelopes with a rectangular flap and/or tuck the flap inside the envelope when printing. The print is skewed or crooked A small amount of skewing is not unusual with printers. When there is too much skewing, the following steps can help reduce the amount.
  1. Adjust the paper width guide to fit against the edges of the paper stack.
  2. Verify that the rear access door is properly seated and locked into position.
  3. Remove the rear access door and clean the paper feed rollers (see the instructions at the bottom of this document).
More than one sheet of paper feeds in at the same time Several paper caused problems can result in more than one page feeding into the unit. Check the list below:
  • Reused paper (paper already printed on one side)
  • Torn or folded paper
  • Textured or coated paper
  • Unsupported specialty paper
To determine if the paper is causing problems, try using clean, undamaged sheets of plain white 70 - 90 g/m2 (20 - 24 pound) inkjet paper, such as HP Multipurpose or Bright White paper. If this paper feeds correctly, the problem is probably with the other paper. Cleaning the paper feed rollers Over time dust and paper fibers will accumulate on the paper feed rollers. This can cause paper feed problems. Follow the steps below to clean the rollers: Figure 3: Paper feed rollers c00212278.jpg
  2. Remove the rear access door (as describe above in this document).
  3. Clean each roller using a clean lint-free cloth lightly moistened with water (distilled water preferred). Rotate the rollers to clean the entire surface.
  4. Verify that the paper feed rollers on the rear access door are clean and rotate easily.
  5. Re-seat the rear access door.
  6. Plug in the power cord and turn on the all-in-one.
Jun 29, 2008 | HP PSC 2355 All-In-One InkJet Printer
Canon ip 4300
Google "canon ip4300". The canon.com entry near the top has a support tab. and enter "paper skew", you'll get a roller cleaning procedure.
As a matter of fact, it didn't solve my problem. The alternative, of having the machine repaired, is, of course, silly vs. buying a new machine. But in the meantime, the lower paper feed still works, albeit slightly less convenient.
Apr 22, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
359 people viewed this question
old marine
old marine
