Question about Lexmark Wheelwriter 5 Series II Typewriter
Print Solonoid Hmmm, okay so what is the print solonoid and where is it located?
  • Lexmark Master
  • 3,594 Answers
Remove thr ribbon below the ribbon deck just inside the l. printer side frame is the print solenoid it's roubd and about 1.5 inchs in diameter.
Posted on Jun 06, 2008
Where is the torque converter solonoid and the shift solonoid located on a 1998 chevy k2500 4x4
They are located on the valve body inside the transmission. Do a search for the valve body location.
Good Luck!
Oct 22, 2013 | Cars & Trucks
Where is the solonoid located?
all water solonoids appear to be behind the water filter inthat housing. good luck getting to them.
Nov 27, 2012 | Amana Refrigerators
I got a code p1747 electronic pressure control solonoid short circuit where is this located and will that cause my truck to throw all the shift solonoid codes
The solenoids are inside the transmission, if you are getting more than one code you may have a problem with the wiring harness going into the trans.
Oct 12, 2012 | 2001 Ford Ranger Regular Cab
Have a P0757 DTC in a 2007 fusion . reader says that solonoid B is stuck on. need to know how to trouble shoot solonoid ,wiring and connectors all the way to the PCM.
Real Simple
You fail to realize that the Black Fluid is the result of the
former owner not changing the fluid & it was black from
over heating as a result
You are in denile & fail to realize that the clutches have
burned up & that is why the fluid is black
I did once own a trans repair business,so your only option
is to pull the unit & rebuild it
Your Ford Tech had a good idea but didn't want to help you
or hurt your feelings,asumming he knew anything at all about
I could have told you all this without opening the hood,before you
got the car.
No fluid changes every 3 years,the unit comes out
Jun 06, 2012 | Cars & Trucks
Water wont come in
Eliminate the obvious. Water turned on to machine .Door shut all the way.Next check fill solonoid usually located at bottom front behind kick plate.Be careful ,120 volts should be available at solonoid at some point during cycle use volt meter with caution. you may want to call a tech .If no voltage then it is either bad overflow switch or control or timer or door switch.If there is voltage then solonoid is shot
good luck
Jul 27, 2011 | Admiral Dishwashers
Print unable 32 messege
If no paper or label has been found after thoroughly following the troubleshooting steps, it is most likely a mechanical problem. In my case, it was the solonoid. I phoned Brother customer support and they referred me to my local authorized Brother repair shop who replaced the solonoid in less than 24 hours for $98.
Jan 02, 2011 | Brother DCP-9040CN Laser Printer
I assume you are talking about the print solenoid. It is located under the ribbon deck, just inside the L. printer side frame, it's about an inch and a half in dia. and an inch thick to remove it you must take the printer out of the T/W. If you think it's gummy spray some WD40 down the back of the solenoid.
More than likely the plastic cap is broken. We sell them with instructions and shipping for 20.00.
Cleveland Business Machines
Feb 25, 2010 | IBM Wheelwriter 30 Typewriter
Typewriter Print Wheel
Depending on which printer you have there should be a red or black lever beside the print solonoid, push to the rear and the P/W should lock into position.
Jul 13, 2009 | Swintec 7040 Typewriter
Wheelwriter 5 series
You probably have either a gummy print solonoid or the plastic cap on the solonoid olunger is broken these are available for about 15.00 but are a little tricky to install.
Jan 08, 2008 | Lexmark Wheelwriter 5 Series II Typewriter
Lexmark Wheelwriter 5 Series II Typewriter Logo
41 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
