Question about DeLonghi DSM7 Stand Mixer
Need to find part for DeLonghi Mixer
Need to find gear in mixing head.Live in Hampton Va
Ask at the following link, I found there most of parts for DSM7 mixer.
http://www.forumappliances.com/
Good Luck
Posted on Nov 02, 2008
Hi there, I was doing cake mixing and turn off
If you can hear the motor spinning and the beater does not spin, the worm gear has probably failed. These fail frequently, specially after using them beyond there designed limits. The motor heats up and the gear, which is a type of plastic or nylon, melts.
Feb 18, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Do th gears in a kitchenaid mixer need oil
Hi SHIRLAFINK, you do not need to 'oil' the transmission gears on a KA mixer. Your KA mixer comes with enough grease to 'last a lifetime' - whatever that means?
Depending on the age of your mixer and how heavily you use it, there may be a time when you might want to replace the grease, but that period is usually measured in years of useage.
Of course if one of the gears strips or breaks, you will need to replace all the grease when you replace the broken gear. Attempting to use salvaged grease jeopardized the remaining gears if pieces of metal or plastic debris are suspended in the old grease.
I hope this helps - hslincoln, Burke, VA
If this solution has been helpful, please rate it, thanks! hslincoln
Mar 14, 2010 | KitchenAid K5SS Heavy Duty Commercial...
When kneeding dough by the time the last of the flour is added the mixer does not have enough power to kneed it. A year ago it did but has gradually lost power. I have taken the gear head apart and...
HI KEN9486, from the way you describe your mixer’s malaise, the apparent lack of power during the dough mixing process does not appear to be to be a mechanical issue, but electrically induced. You’ve already put your fingers on the culprit – the brushes! Anytime your mixer’s brushes have been worn down as much as you indicated, they should be replaced.
Be sure you have the Parts List manual on hand to order the correct brushes. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) but check to verify this matches your mixer model.
On Pages 6 and 7, you will find the brush & spring assembly (Illus. No. 29) and Part No. 9706416 that you need to order. Replace them both.
Here are five potential online vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). Prices can vary widely between vendors, so do some comparison shopping.
I think you’ll find new ‘life’ in your mixer after you’ve replaced the brushes and it should be able to handle dough mixing without further problems. Good luck, I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Feb 25, 2010 | KitchenAid K5SS Heavy Duty Commercial...
After sitting since last use I found about a tablespoon of clear yellowish oil in the bottom of the mixing bowl- couldn[t see any on the machine itself. Is there a transmission with oil in it? I have the...
jack440 - When was the last time you used your mixer? To answer your question, yes, you KA mixer has internal transmission and planetary gears which convert the electric motor's rotation into the mixer's rotation. The internal gears are factory packed with enough grease to last a 'lifetime' (whatever that means). Depending on the age of your mixer, where it was stored (high temp possibly?) and how long it's been idle; these conditions may have let some of less viscous grease seep beyond the gasket, down the agitator shaft into your mixing bowl. What can you do? First clean your bowl and agitator shaft with detergent and hot water. If your mixer is not under warranty you can troubleshoot it yourself. Be sure you have the Parts List manual on hand. If you're lacking one, you can download it from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number (in your case, try K45SSW select Parts List (1) and then check to see it this matches your mixer model). You can check on page 4 & 5 for the disassembly and reassembly of your mixer, along with all the parts. It can be messy but gratifyingl. You might want to reorder the gasket for starters. Once apart you can check for any other unseemly wear and tear on the gears, etc. Good hunting... I hope this helps - Howard, Burke, VA
Nov 04, 2009 | KitchenAid K5SS Heavy Duty Commercial...
I have an almost 12 year old mixer, and in the last year it seems the head (for lack of a more technical term), is a little lower so that the paddle attachment grinds on the bottom of the bowl. The...
Tegan, sorry to hear you tilt mixer head is drooping and causing rubbing problems with the mixing bowl. This should be pretty easy to fix, if you?ve got a small blade screw driver and a small hex driver (or jewelers screw driver). First, do you still have the K45SS Parts List? If not, you can download a PDF version from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number (in your case, use KSM90P) and select one of the files that appear under Parts List. Turn to page 4 - Case, Gearing and Planetary unit, which shows the exploded view diagram and locate Illus. Nos. 29 & 30. Page 5 lists the parts as Adjusting Screw and Set Screw respectively. What?s probably happened is that over 12 years of operation, the vibrations from your mixer has caused the set screw to loosen and drop, hence the lower mixer head. Both screws will need to be ?adjusted? to move the head back to its original position. Now the problem is removing the head from its pedestal. Turn to page 8 and gently remove Illus. No. 7, Hinge Pin, with a hammer and pin driver. With the hinge pin removed the mixer head and pedestal can be separated and you should have access to adjusting and set screws. I would inspect them for wear and tear, and replace them, if you deem appropriate. It may take a few trial reassemblies to get the mixer head back to the original factory position, but once there, everything should be OK. I hope this helps! Howard, Burke, VA
Nov 02, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Leaking fluid, oil I think around the kitchen aid ring
Bucksmom, Sorry to hear you mixer is 'leaking'... I hate it when that happens. You don't mention how old or what model your KA mixer is? I assume you mean the band around your mixer with the Kitchenaid logo, when you say 'kitchen aid ring.
Your mixer does have an internal gear mechanism (transmission if you will) which converts the electric motors rotation into the mixer rotation and those gears are located within the mixer. The gears were lubricated at the factory, but depending on the age of your mixer and how it is used, it is possible that the grease has leaked beyond the gasket and that is what you are seeing now.
It is possible to disassemble the mixer to determine where the grease is coming from and troubleshoot if anything else might be wrong within the transmission.
Hopefully the leakage is not getting into your food being mixed. Kitchenaid Grease should be 'food grade' grease, but you still don't want to ingest it.
I hope this helps... Howard, Burke, VA
Nov 01, 2009 | KitchenAid Food Mixers
Mixing blades detach while being used
type delonghi in the search bar. Pick a site and yell at them. Kidding, tell them your problem and they should work with you. Get a phone number and call them, get the salesmans name and a time frame you can expect repacements.
Oct 26, 2009 | DeLonghi DSM7 Stand Mixer
Hobart D300 Mixer: Has no torque and no speed in any gear
You have a gear with broken teeth or one sliding out of place because the brass shims are eaten up. Hobarts have what is called a planetary, round head where the grease caps are, and there are no clutches for this planetary. These units are not made to change gears while unit is running (#1 problem of gear failure) (#2 is overloading the bowl) Hobarts need a really stiff GREASE, not oil. If you decide to take the planetary apart, get all the syrup out and replace with a stiff axel grease. It is a very difficult job replacing a gear & ALL the shims. The round head where the grease caps are can easily be removed to do this.
Jun 17, 2009 | Hobart D300 Stand Mixer
Mixer turns on but the beater doesn't rotate
Remove the metalic ring around the mixing head. Push down on it with a flat head screwdriver...
Remove the pin from the mix shaft.
Pull down on the mixer head. Inspect the gears.
If nothing wrong here, disassemble completely and inspect drive gears. Something is broke and needs replaced. You need to find it first, then take that broken part to the dealer to get a new one. Good luck
Feb 24, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Taking the top off my kitchenaid mixer
Remove the back housing by removing one screw and liftingand pulling rearward.
Remove two screws holding the metalic edge trim. This uncovers the seam. Screws are on the back.
Remove four visible screws from the bottom of the head around and near the pillar.
Now gently using a screw driver, push the metallic ring on the mixing head down and off.
This uncovers five more screws about the mixing head. Remove them.
Using a very small screw driver or punch, puch the pin out of the mixing head shaft.
Remove the mixing head housing.
Lift up on the motor housing to remove it.
The motor/gear housing is the top protion of the mixer. Its loaded with grease so do this over a covered countertop or some place easy to clean. The grease won't run, but it can fall out in gobs.
Make sure all sealing surfaces are clean, especially the gasket around the gears. This will insure a good seal. No gear grease in your famous cookies!
Reinstall in reverse.
Feb 03, 2009 | KitchenAid KSM150PS Artisan Series Stand...
DeLonghi DSM7 Stand Mixer Logo
387 people viewed this question
Top DeLonghi Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a DeLonghi Food Mixer Expert? Answer questions, earn points and help others
