Question about Acer Aspire 4315 Notebook
Black display i had used the screen of aspire 4315 on my 2420 acer it had worked well: but when I put it back to the 4315 it showed a black display without the lights. Please help out.
  • elijah19 Jul 24, 2008
    screen becomes darker not like before. how to adjust the screen brightness to its original display?
  • xCAUSALITYx
    xCAUSALITYx May 11, 2010
    When you first switch it on does the bios have a pink hue or pink look about it, also when its booted do you here sound as windows starts up, also if you press the lid soft button up and down lots of times (Usually in top right hand corner of laptop base) does the screen light up. Also if look close up to the screen can you see your background image?
    Cheers
My screen is flickering after a month when i newly bought it, 2months later, i send it back to repair for a week, and after i took it back for me to use , it started to cause the same problem agin and it becomes worst, anyone can help?
Posted on Jul 24, 2008
    Novelist:
  • 119 Answers
Start your computer then press f8 to go to advance boot menu then select enable vga to boot. when you get to log in and get your screen try to reinstall the video driver
Posted on Jun 26, 2008
Get black screen after upgrade Acer 3680
might be that the ram you got was the wrong ram for that laptop.not all ram work in all laptops.
May 23, 2014 | Acer Aspire 3680 Laptop
Acer Aspire Black Screen
You are describing too different types of problems, difficulty in seeing the screen and now it is gone black. The LCD screen will need to be replaced, I'am hoping the built in display light has failed and not the inverter board because you could end up changing the screen and the inverter board adding to the expence. Go to www.ebay.com type make and model of laptop, refine search to screen and inverterboard.
Jun 01, 2012 | Computers & Internet
Acer Aspire 4930 not starting.... only black screen
Hook a spare monitor to the video output, usually on the back, if picture okay! the LCD screen on the laptop has a bad inverter board or the backlight behind the screen has failed. But if both show the same symptom the Video Graphics Card is bad usually built into the motherboard.
Mar 21, 2012 | Acer Aspire 4930-6862 Laptop
Does not start up
open the cover laptop then find the memory then make a clean or replace a new memory.
Jun 25, 2009 | Acer Aspire One PC Notebook
Acer aspire 9300 black screen (display adapter)
I have been fixing computers that has long beeps and short ones. It is usually attributed to memory problem connection. Open the memory compartment at the back of the PC then detach the memory card. Clean with cloth softly enough not to destroy the circuit board or a pencil eraser to clean-up dust that caused the connection blockade. Reconnect after cleaning.
Jun 21, 2009 | Acer Aspire 9300 Notebook
Need help for Acer Aspire ONE MODEL # ZG5 screen does not work?My Acer Aspire ONE MODEL # ZG5 notebook is show that the power is on, but the screen is black. I can hear the computer running, but there is...
If you are sure the computer is running then connect an external monitor to the laptop. You will have to select the external using your Function keys FN + F7 or F8. If you can now see your machine on the external monitor then you know it's the screen portion of your laptop that is faulty. If this does not work then the sounds you are hereing are probably just the fan and the hard drive spinning. These are not an indication that the computer is working. All in all, I would say that the laptop needs to see a pro.
Mar 26, 2009 | Acer Aspire One PC Notebook
Acer Aspire 3690 remove the screen
There screws all around the lcd that are hidden by black rubber / plastic.
Examine the plastic and you'll see them. Pop them off with a straight blade screwdriver.
Then just unscrew all the screws. Most use only 4-6 screws.
Once they are all out. Carefully pull the plastic housing off with your hands. You shouldn't have to use much force so try to be gentle.
Afterwards you should be able to take it from there. There will be brackets holding the lcd in place.
Take those out and then remove the lcd cable from the back of the screen and the inverter from the bottom portion of the lcd.
Swap the lcds and put everything back together.
That should do the trick.
Let me know if you get stuck.
Feb 24, 2009 | Acer Aspire 3690-2196 Notebook
My Acer Aspire 1710 failed to boot and no Acer logo
use my acer aspire daily, went to put a memory stick in and it just died, no power at all but power light on charger still showing green
Feb 01, 2009 | Acer Aspire 1710 Notebook
Screen does not work
Hi DB75,
Please try the solution #2 presented in the 'Black Black Screen...' issue. Solved my problem I mentioned here. Try it. :)
ni2ts
Jan 20, 2009 | Acer Aspire One PC Notebook
Acer Aspire 4315 Notebook Logo
181 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
