Nikon D60 Digital Camera Logo
Posted on Oct 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My shutter is working fine, but it takes an extremely long time to load a picture after is had been taken (up to a minute). is it a battery problem, or something worse?
Anonymous
Level 2:
Scholar:
  • Expert 175 Answers
  • Posted on Oct 24, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
175
Questions
0
Helped
36084
Points
225
How large are the picturres your taking? THere may be a lag from shutter release to writing because there is a lot of information and not enough camera buffer space. try smaller images, say instead of Raw images try jpeg or change from jpeg fine to jpeg normal, etc. Try a different memory card. Believe it or not, memory cards come in different speeds also. Try one of the fastest you can afford and go to Nikon web site and research on Nikon approved memory cards. Hope this helps.
5helpful
2answers
Black pictures in Canon G10
To fix that problem, they have a specific service package at this place: www.camerasandparts.com They just specialize in servicing the Canons and that's where a lot of people go for help with these. Through them, it's $89 for the repair with parts, and they service up the camera at the same time. The best part, they do exceptional work on the Powershots, that's where a lot of people go for help with these models. Best of luck with it.
15helpful
4answers
When i take picture,the picture is white n some time become very very bright, but if take video is ok.
this can be usually associated with your white balance in still camera mode.
Check to see your white balance is set correctly or just set it to auto. Also make sure the mode you are in it set. (ie. indoor, outdoor, auto, speed)
My camera shakes (vibrates) very bad every time that i turn it on. it stops if i am looking at my already taken pictures but im not able to take any new ones because of it. how do i fix it?
It is possible that your shutter is not working and there are issues with the servo of the camera. When it is switched on the motor of the lens cover is vibrating as it is having a fault maybe a friction to move .
So a possible cleaning/service might rectify the fault , releasing a jammed shutter.
remove battery and replace after 30 minutes with a fully charged battery , while switching On tap the lens cover on your palm several times, might help sometimes.
Sep 26, 2010 • Cameras
4helpful
2answers
I am not getting an image either through the viewfinder or on the LCD monitor. The display is clear and bright and the batteries appear to be fine.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Sony DSC H-5 Camera slow response time
There is a diaphram between the shutter button and the shutter that does the focus. Pushing the button half way down pre-focuses and then the picture is instantanious. If the diaphram is broken it take a while before the shutter takes the picture. One of the AA batteries may be defective so try another set and see if that is better. There is also a slight possibility that the secondary battery (hidden within the camera) has gone bad.
Menu and display buttons do not function
One quick question. Is the camera taking photos?? when you try to transfer the photos to computer , are the photos fine or there are some Black photos??
Regard's
Manoj Goyal, INDIA
+91-9214988557
1helpful
2answers
My camera seems to short out and there are horizontal lines in the pictures.
get new batteries, if recharging your current batteries does not work (to stop it shorting out).
reduce your shutter exposure, by changing to Manual Mode (M), selecting +/-, and then the left button (flash) around the Menu OK button. Mine works fine at 1s shutter speed, but was showing horizontal lines before that ...
FujiFilm FinePix A500 screen turns off when trying to take a picture
I had the same problem with a fujifilm finepix... It didn't take pictures with 2 sony batteries, just turned off after pressing the shutter. Then I tried 2 panasonic batteries and it worked fine....
My solution: try panasonic rechargeable.
Lines through Photos
I had a similar problem with a Casio and they directed me thru some exercises and the one that worked was removing the battery and holding down the "on" or maybe it was the "shutter" button for one FULL minute. Worked fine after reinserting the battery and taking some pictures.
2answers
No picture is taken when shutter release button is pressed
Are those NiMH batteries? Have you tried resetting the camera? If no standard way, just take out batteries for a few minutes, the more the merrier, let the tension build, and replace them. Try tapping on the lens area, it might loose something up. Best I can do, know it aint much ;] Good luck!
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
