Question about Carrier Heating & Cooling
Carrier Weather Maker not blowing anything
When i manually turn thermostat to a/c..carrier outside starts up but no air of any kind comes thru vent; after about 3-5 minutes, unit shuts off..does it matter if my thermo is set to fan or auto..do i have major problems?..no sign of icing because i haven't used ac in about a week..
    Genius:
  • 1,554 Answers
If you turn on just the fan at thermostat does it run.
if not then the fan motor / belt / relay / start capacitor is the issue.
if your not familiar with ac then you will need help to diagnose the air handler.
belt is easy.
just take a look by opening the side access panel
Posted on Jun 04, 2008
Carrier Gas Furnace runs fine randomly stops blowing LEDs flash
That blinking light may be the diagnostic light. Count the blinks next time it fails. Carrier units will have two different blinks depicting the error code such as one blink followed by a pause than 3 blinks giving you an error code of 13. Then look at the wiring diagram, it will have an error code chart telling you where to start with your diagnosis. You already know that if you remove the cover it erases the error code, so look thru the small window first.
Nov 30, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Cool air from Carrier unit barely blows out vents,unit stays on
undersized is just that...you and I got taken to the cleaners.but i did put an adjustable vent in the cod air return vent duct next to the floor...it helped mine but i say some installers should.....well you know
Aug 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Turned air on but outside unit will not come on at all
when you say a little air could the filter be plugged up or the coil iced up is the outside unit running
Jun 20, 2009 | Carrier 38CKC036 Air Conditioner
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
My Carrier AC fan will not turn, only blows out warm air.
Breaker has popped either at breaker box or at the safety shut off switch. Fuses are blown or the sending unit has popped.
Apr 30, 2009 | Carrier BCA101R Air Conditioner
My ducted heating continually blows cold air thru
Well, if need be, turn the breaker off. Turn it on when you need heat. Sounds like the fan relay is sticking or something if that sort. Is the tstat fan selector on auto?
Jun 17, 2017 | Heating & Cooling
Blower Turns off if ac unit comes on. No air coming through vents
This only could 1--2 things, a bad circuit board fan relay or bad thermostat. To check for bad thermostat, take off the front cover to reveal the 4-wire terminial and jump the red-wire (power)-cool,(yellow -y or blue)--- green--fan white-(heat)..........red to yellow-or y=cool. Thank-you-very-much!
Aug 25, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Caerrier weather maker 8000
Your cooling coil may be frozen. Turn the fan on and the cooling to off so air will circulate to defrost the coil. After air circulation is re-established in about 90 minutes turn the cooling back on. Operate the system with the fan on when in the cooling mode should eliminate the freezing problem.
May 26, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
128 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
