I wired my subwoofers wrong from amp and blew a fuse and put bigger fuse in it.it has power but no sound
    Genius:
  • 1,550 Answers
Maybe your audio amplifiers IC's are damaged because of your mistake,never put a bigger fuse on your device.
Posted on Jun 05, 2008
What fuses have constant power supply in a 2005 Chevy equinox? I'm trying to get power to a pioneer under seat subwoofer.
ALL subwoofers need a minimum 10 gauge wire power source.Run a 10 gauge wire to a relay then to the battery with a fuse or circuit breaker inline which matches the subs amp power needs.
Use a switched power source to the relay from any accessory fuse.
If you try and feed power to a sub from existing wiring a voltage drop may result and the sub amp will not only sound bad but have a short life.
Capacitors are added to bigger systems just for this reason as sub amps can be VERY power hungry.
May 01, 2017 | Seat Cars & Trucks
Pioneer diagrams
It seems that P151 is the "hot" wire to the transformer which powers just about everything, so that won't tell you anything. Most likely, the wrong speakers were put on the stereo which blew the amplifier circuit. Check the amplifier assembly which is the big block with a fan inside of it.
Jan 26, 2014 | Car Audio & Video
Teac AG-V7700 keeps bowing fuses
I hate to say it but it sounds like one of the audio chips that drives the speakers shorted out! The high powered outputs (more than 7 watts) need both speaker wires to be ungrounded. You will need to find someone to replace the defective chip or else get a new unit.
Nov 25, 2013 | Teac Audio Players & Recorders
Old Amp blew, got a new one. Power light came on but speakers didnt work. Unhooked the amp, hooked it back up and no power. Any ideas?
Are the speakers still working? When the old amp blew it might have blown the speakers too. Are any of the wires grounding out besides the ground? I would check the remote wire too. I also suggest replacing it with a bigger (smaller #) gauge wire, its not as sensitive to interference and gives your amp a boost in actual power to the speakers. Check any fuses to see if they are blown. Make sure all the connections are tight. If no power after this all checks out then amp is blown again and you might want to get smaller speakers or a bigger amp (or better).
Aug 11, 2010 | Car Audio & Video
My subwoofer atarted making deep humming sound,
Some kind of semi-conductor in either the power supply section or the main amp has failed and acting like a piece of wire, which is why the fuse is blowing. You might want to look around for damage or burning. If it's a transistor or diode that has gone an Ohm Meter will show it up well. For when you put the test probes on the terminals of the suspect part, it will be like you had touched the probes together!
May 09, 2010 | Polk Audio PSW150 Speaker
I have the same problem as described by Fufanuer. I have no power to S12 Subwoofer as it keeps blewing fuses. As I replace the fuse 4a 250V with new one it blew right away. Can anyone help? Hal
I too am looking for the solution, I'm hoping I have the wrong power cord which is sending too much power to the sub, my next attempt will be to just up the AMP on the fuse b.c hey it's broken anyway
Nov 20, 2009 | Proficient S12 Subwoofer
My amp is flashing in and out of protect
you must likey just fryed the wires, try putting in bigger fuses, and unhooking everything and re hooking it up
Jun 13, 2009 | Power Acoustik GOTHIC OV2-1800 Car Amp
No sub when listening to a cd
you're using the wrong remote output wire. You have it hooked to the power ANTenna wire (blue) which turns off when not using the tuner. You need to use the REM OUT wire (blue w/ white stripe).
Oct 14, 2007 | Sony CDX-M630 CD Player
37 people viewed this question
 Grubhead
Grubhead
