Question about Admiral AW22 Top Load Washer
Admiral Mega 22 Plus-Heavy Duty-2 speed Washing Machine
My Admiral top loading washing machine, Model # AW20N2V will not spin. It will fill with water and agitate for the wash cycle but will not spin the water out. What do you think the problem is and can we fix it ourselves?
  • 1 more comment
  • janeiltoo Jun 21, 2008
    have the same problem....need to at least empty the washer and spin
  • rdeveaux Jan 07, 2009
    I have the same problem, and while it agitates there is aloud noise, and sometimes a burning rubber smell.
  • dweatsweet75 Jan 20, 2009
    e manual
After spinning it does not release the water
Posted on Aug 04, 2010
    New Friend:
Mine did the same, it was the latch on the side that keeps lid locked in spin mode, it was broken, mine actually stopped doing anything and we thought it was done but then we noticed the latch was broken and my husband put a screwdriver in the slot moved it around and now my washer works perfect? Maybe this is your problem?
Posted on Jun 03, 2013
    New Friend:
Ours is doing the same thing. The repairman came to look at it and said that the timer is out. He is going to charge us over $200 for parts and labor, I think we can find the part cheaper and replace it ourselves.
Posted on Jul 15, 2013
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Admiral washing machine no cold water
HI, this is a faulty inlet valve assembly. you should replace this failing component asap if possible.This will fix the issue.
Jun 22, 2009 | Admiral Washing Machines
The lid on my top loading admiral mega 22 plus washing machion is
These are plastic and will need to be replaced with new.
Once you have sourced new hinges then the machine top needs to be opened,
Electrically Isolate the machine, then at the joint between the machine front panel and top insert a flat blade 4" from each side to release the lid catches, tilt back the top to access the screws on the hinges and replace with new.
Mar 03, 2009 | Admiral AW22 Top Load Washer
Admiral mega 22 plus heavy duty 2 speed washing machine
I think my set i just got today used is a 3 speed.Seems to be alright for now.There is a thing i was told called a harmonic balance it might be off or messed up.Tina.A(nc)
Feb 23, 2008 | Washing Machines
Admiral AW22 Top Load Washer Logo
2,621 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
