Question about Epson Stylus CX3200 All-In-One InkJet Printer
Error light comes on. Displays printer error , see your documentation and call service if necessary
  • 31 Answers
Tried to isolate the printer. Turn it off and unplug the usb and the power cable. Open the cover and quickly check for any obstruction. Connect the printer directly and if possible use another power outlet. Also, tried pressing the copy button to see if the unit responds. If you still have the same error, the printer might need service and you need to contact Epson.
Posted on Jun 04, 2008
Wat is an LSU error on a phaser 3200 MFP
Change the toner cartridge , i have many units phaser3200 and this is one of the problem , but only if the toner cartridge is very old and many time refilled , if not , change the Laser unit .
  1. Remove a misfed document if the copier displays a message reading "Document Jam." Lift up the document feeder cover and turn the roller to remove an Exit Misfed document. Lower the document feeder back into place and feed the document through again. If the document is jammed on the Input side, open the cover and gently pull the misfed document to the right and out of the feeder.
  2. Pull out the paper tray and lift the tray to release it from the copier if the copier displays a message reading "Paper Jam O." Remove the jammed document, and open and close the side panel of the copier to clear the error message.
  3. Unplug the power cord and plug it back in again if the copier displays a message reading "Fuser Error, Open Heat Error, Heating Error and Overheat." If the problem persists, call for a service.
  4. Remove the toner cartridge and shake it from side to side if the copier displays a message reading "No Developer Cartridge." If this does not do the trick, you may need to replace the cartridge. Pull the release latch to open the side cover, and open the front cover. Twist the cartridge locking-lever upwards and remove the toner cartridge. Insert the new cartridge and lock the lever into place. Shut the front cover and the side cover.
  5. Power off the unit and power it on again if the copier displays a message reading "LSU Error." A problem has occurred with the Laser Scanning Unit. If the problem persists, call for a service.
Jan 04, 2011 | Xerox Phaser 3200MFP/N Laser Printer
When I turn on my Epson stylus CX6400, it has the message "error-Printer error-See your documentation and call service if necessary." The only thing the documentation manual says about this error is to...
Do you have any other indicators such as flashing lights or similar?
My guess is that it MIGHT be a "service required" error meaning the waste pads are full in which case this guide may help..
There's a reset sequence you can follow near the end of the article which I'd try... If that solves it then you'll need to deal with the waste pads.. If not, you'll know it's something else and can report back..
Feb 23, 2010 | Epson Stylus CX6400 All-In-One InkJet...
Printer error
This means see the document you are printing or install it again
Nov 19, 2009 | Epson Stylus RX580 InkJet Photo Printer
It reads Printer Error - see your documentation
this means your printer waste pads are full and the printer needs to be reset for it to work again or it can just be reset
Sep 25, 2009 | Epson Stylus Photo RX500 Printer
When turning the power on to my Epson CX6400, the following error message comes up: "Error: Printer Error -> SEE YOUR DOCUMENTATION AND CALL SERVICE IF NECESSARY." The little "!" exclamation point...
Sounds like the ink counters need resetting (it happens with other printers as well)
Go here for more info as the prog supports your printer
http://www.ssclg.com/epsone.shtml
Jul 17, 2009 | Epson Stylus CX6400 All-In-One InkJet...
C510 printer displays "994 Service Engine Error". How do you addr
Here you go, courtsey of Lexmark's Knowlwdgebase.
Don
994 Service Engine Error on a Lexmark C510 ID: ENUS21233 If your printer is unable to move the photodeveloper belt to the correct position during printing, a 994 error will occur. However, it may simply be the case that the photodeveloper is either contaminated with excess toner or improperly installed. To test for and resolve this issue, please do the following:
  1. Power the printer off and remove the photodeveloper cartridge.
  2. Rotate the green metallic photodeveloper belt by manually turning the white drive gear on the bottom of the cartridge until the black positioning markers are visible.
  3. If necessary, carefully wipe any excess toner powder from the positioning markers using a soft, lint-free cloth or tissue.
  4. While the top cover of the printer is still open, inspect the sensor that is used to locate the positioning markers on the belt. CAUTION! The photodeveloper is very sensitive to light. Cover the green metallic surface of the photodeveloper with a piece of paper while it is outside the printer.
    • Refer to this image, this image, and this image to identify the location of the sensor.
    • Verify that the sensor has not come loose from its housing and that it is not contaminated with excess toner powder. If necessary, clean the sensor with a soft, lint-free cloth or tissue.
  5. Re-install the photodeveloper cartridge and power the printer back on.
  6. If the error remains, it is likely that a service call will be necessary to resolve this issue. Please contact Lexmark Technical Support, having first obtained the serial number of your printer. NOTE: If practicable, attempt to order another photodeveloper and replace it first to avoid the inconvenience of a potentially unnecessary service call.
Jun 22, 2009 | Lexmark C510n Laser Printer
Initial Charge message not seen
Sounds as though the printer is defective.
Call or email Epson Tech Support.
Feb 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
80 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
