Question about Philips MCD288/37 DVD Micro Theater System Theater System
DVD WON"T EJECT! - PHILLIPS MCD 288 - Micro Theater
I have had this happen twice now. The first time, after a few days I got the DVD out (can't exactly remember how). But now it's happening again. The player does not recognize the DVD (says No Disc) and will not eject it.
Does anyone know how I can get it out? I don't see a forced eject pin hole but I assume there must be right?
  • jan_willem_m Sep 04, 2008
    I have just the same problems. The second time as well, and that in just 2 months after I bought the system!
  • campo_samuel Apr 11, 2009
    the dvd does not come out from the device. Big problem for me...
SS PAI
  • 55 Answers
SOURCE: lost remote control
Please contact the manufactures. If lucky enough u mit get a remote for free.
Hope this helped
Posted on Jan 06, 2010
I have a Digital Home Theater HT-DS400 Samsung. I have problems in reading a music CD or a DVD. You can read the message "Loading.." for a while and then stops and reads "NO DISC". ...
  • Make sure you have a non home made DVD. Some DVD players will not play DVD'S in certain formats.
  • If you have a normal DVD in the DVD player and are getting "NO Disk" then there is a real good possibility the lens is just so dirty that it is not recognizing your DVD at all. This happens a lot to all disk players that are neglected from the cleaning process. Get a disk player cleaner and run it through a few times until the disk is read again. Sometimes the lens is so dirty you have to try a few times just to get the cleaner disk itself to play just to do the actual cleaning. Make sure to run that cleaner disk through once a week. These disk cleaners "sweep" the lens and work well. You can get one at your local Best Buy for $8usd.
  • The last thing it could be is that somehow the lens has come out of alignment. Just a millimeter out of alignment is all it takes to not be able to read a disk and DVD players get bumped and knocked off the shelf easy. So this can happen often especially with the more smaller travel DVD player.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 23, 2011 | Samsung HT-DS400 System
I have made several attempts to play a disc on my JVC TH-V70. IT reads 'reading' on the dvd unit then after a few second the disc ejects. Why is this happening?
Hi Adrienne - If it only happens to the one DVD it is most likely a problem with the DVD being damaged or dirty.
If it's happening with all your DVDs your player laser lens is probably dirty or it might be damaged. If no discs are being read get yourself a CD/DVD cleaning disc and run it a couple of times (following the directions). Of this doesn't work you will have to decide if the player is worth the price of a repair (unless it's still under warranty). Most aren't as you can buy decent players for less than $50. Any repair will cost at least that.
If it is the one disc I suggest you take a clean soft cloth and wet it slightly with plain water and the give it a few strokes across the disc (not in circles), let it try dry for a few minutes and try it again. Also examine the disc (bottom) for any obvious scratches or stuck on gunk.
Good Luck and thanks for using Fix Ya.
Mikeywaf
Apr 28, 2011 | JVC TH-V70 System
RCA RTD315 Theater System The DVD Player recently
My identical system has exactly the same problem as the one described by dipaola, above. When I insert a DVD, the DVD carriage pops back open after a few seconds. In fact, mine won't stay closed even without a DVD in it, as long as the system is set to play a DVD. I'd like an answer to the big Q - Is there anything I can do about this, or should I just find another DVD player to hook into the system?
Nov 05, 2010 | RCA RTD315 Theater System
Cd music is skipping on bose 321 system and one channel of dvd audio will stop playing. Disk player has also started making loud vibration noise after loading dvd or cd. This didn't used to happen. On CD...
The Bose® 3·2·1 GSX Series III DVD home entertainment system puts you at the center of exciting home theater with just two visible Gemstone® speaker arrays and a hideaway Acoustimass® module. Setup is simple because, unlike traditional five-speaker surround systems, there are no center or rear speakers. An elegant media center features a progressive scan DVD/CD player with an HDMI output and AM/FM tuner. You'll enjoy vivid detail in your movies and sports with video resolution up to 1080p over HDMI.
Apr 04, 2010 | Bose 3 2 1 GSX System
Dvd problems
The issue might be that you have to send the LHT854 Back to the manufacturers and have the playback feature replaced. The playback feature is controlled by a device that is internal and very important to the overall function of the unit.
Mar 28, 2009 | LG LHT854 Theater System
Phillips hts3410d no sound VERY dim led
Have you had any thunderstorms recently in your area? if so, this could be a pulse sent threw your system form an electrical storm. this happens often during dangerous thunderstorm activity. Also, your electrical wiring in your home can produce this as well due to a faulty circuit breaker box or lose ceiling fan hook ups. the best scenario could be a defective product. this way, you can get a full refund or a replacement set up.
Jan 28, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
I have a DVD player, VCR player, TV all attached to an RCA RT2250 audio/video receiver. All was just fine until 2 days ago when the DVD player would no longer give sound and icons of the speaker system...
It's possibly only needs soldering of the voltage regulators. they are on the main circuit board heat sink (middle of the receiver and can be accessed by the bottom panel.
JohnW
Dec 21, 2008 | RCA RT2250 System
Sony DAV S500
The protect indication is because of a fault detected in the amplifier section. If this appeared occasionally before and cleared itself, it suggests bad connections. If you know how to solder, open up the unit and resolder any connections that appear grainy or have rings. That may solve the problem.
Dan
Jan 24, 2008 | Sony DAV-S500 System
Rca rt2600 OVERLOAD PROBLEM
Your receiver has blown out you need to buy a NEW Receiver and sub-woofer (the sub isnt compatable with better receivers)
Jan 06, 2008 | RCA RT2600 System
Dvr 50
Hi I have jamo Dvr50 system and it has been frozen since yesterday. I have power down few times but nothing is happening. It comes on and panel lights up but that is all.
Nov 08, 2007 | Jamo DVR-50 System
Philips MCD288/37 DVD Micro Theater System Theater System Logo
355 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
