Question about Brother MFC-8440 All-In-One Laser Printer
Error message "paper jam"
I've tried to print from paper, excel, docs, etc... but i keep getting paper jam error. I have looked through the printer and cannot locate and paper that is jammed. I've tried making copies but that isnt working either. I have already unplugged and plugged in the printer.
What can i do to fix this?
  • promocon Jun 25, 2008
    same problem here, but we found the paper jammed in the back roller, inside the fuser cover. However, I cannot access the paper, as it's all scrunched against this roller (your paper could be here as well). I'm searching for a way to release this roller from the fuser unit and NEED some help, as this is our only printer/fax machine!
    PLEASE help us out - Thanks,
    Robert
    Champion:
  • 320 Answers
U need to remove the fuser and remove the paper in it, put fuser back in the reverse
Posted on Jan 14, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Paper Jam error
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure thatyou have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
May 17, 2008 | Olympus P-440 Thermal Photo Printer
My paper keep getting jam and will not go into print
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persists and you see no paper that is stuck in the printer it
May 14, 2011 | Office Equipment & Supplies
Keeps showing 900.57 firmware error and the paper gets stuck
Power the printer OFF and ON. Send the same file to the printer, if file has not been released from the print queue then delete all pending print jobs out of print queue.
Disconnect all data cables and power the printer OFF and ON. If the printer returns to READY, Reconnect the data cable and try printing again. If you are getting a paper jam error, please take not the error code and locate the jam. For further assistance, please contact Lexmark Technical Support.
Apr 06, 2011 | Lexmark T652DN MONO LASER PRINTER...
Error 241.1 Paper Jam. I have reseated the tray
Brand New T652n lexmark printer get a paper jam every time! just opened and haven't been able to print one paper. Doesn't matter if you print from tray one or tray two. It gets stuck right after the rollers pick it up and try to send it to the toner. Any suggestions? I've tried to reseat the toner, plain paper, sized the paper correctly, I've tried just about everything I can think of! I can feed paper manually through the top tray, and it will print. But, just using the manual tray defeats the purpose of the other two trays. Anyone else having this issue?
May 26, 2010 | Dell 5310n Laser Printer
Paper Jam message on every print job.
I have the same printer without the doc feeder. Check the paper trail thru the printer for the paper sensor lever hanging up. It gets pushed up by the paper and can stick, making the printer think it still has paper in it. Pulling the cart unsticks it till you print again.
Jul 03, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Error light keeps on flashing blue light at the
These are your possibilities based on your error.
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document. See
Solving print problems on page 97.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document. See
Jun 14, 2009 | Brother HL-2170W Laser Printer
My hp laserjet 4 plus printer cannot print excel files
wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
Sep 23, 2008 | HP LaserJet 4 plus Printer
Real Basic Question
Unfortunately, that top light isn't very helpful as it's an indicator for several problems (IE: Front door open, out of paper, incorrect/improperly installed print cartridge, etc.), so really, the only things you can do since you've already eliminated the 'out of paper' scheme is make sure the front door's 'button pusher' is still attached and pressing the internal button in the printer, and re-seating the print cartridge. All the help I can offer, I'm afraid.
Manual: http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/bpl04109/bpl04109.pdf
-Backu
Jan 19, 2008 | HP LaserJet 5L Printer
I was wrong...
This is a common issue if you are using generic or remanufactured toner cartridges. However, if you are using authentic Samsung cartridges, then check that the paper size is correctly defined in the application you are printing from (i.e. Word, Excel, etc.). If both issues are ok, then my last guide is to take the unit to an Authorized Service Center and have the paper path senors replaced.
Oct 30, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Brother MFC-8440 All-In-One Laser Printer Logo
504 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
