Question about Nokia N95 Cellular Phone
NOKIA BARCODE READER
MY NOKIA N95 1 GB PHONE'S BARCODE READER IS NOT ABLE TO UNCODE THE CODES.HOW CAN I FIX THE PROBLEM?
  • Anonymous Jun 04, 2008
    Problem Solver:
  • 9 Answers
HI, I HAD THE SAME PROB WITH MY NOKIA N95 1 GB, I DID A FIRMWARE UPDATE. http://www.nokia.com/ INSTALL THE (NokiaSoftwareUpdater), RUN THE NokiaSoftwareUpdater FROM YOUR NOKIA PC SUITE. NB!!!!!! REMOVE MEMORY CARD, BACKUP ALL UR DATA THAT YOU DONT WANT TO LOOSE!!!!! RUN BARCODE READER, LINE THE CODE UP, BETWEEN THE 2 RED LINES, AND WHALA!!!!
Posted on Jun 04, 2008
Phone doesn't boot when SIM is inserted
The Nokia C7 have several issues with the factory installed SIM card reader. Problem can be solved by replacing SIM card reader. Either find your nearest cell phone repair store or buy your own online and replace it yourself.
Jul 28, 2013 | Nokia C7 (8 GB) Smartphone
Uncode ti nokia 16612
you may try some default codes..........
Oct 20, 2010 | Nokia 1661 Cell Phone
Solve Your ''nokia mobile 6300 uncode'' Problem Now!
Hi..
Follow the steps..
1. Start your phone without your new SIM or any SIM card in it
2. Now hit *#06# on your cell phone. When you do it, your IMEI number, a unique global serial number for your cell phone shows up. Your IMEI number should be 15 digits.
There are also different online services that will calculate the unlock code for your IMEI number.
I can recommend this one (cheap and reliable).
Click here to unlock your Nokia 6300
3. Now, choose the model of your Cell phone. If you don’t know your cell phone model number, you can always find out by removing the cell/battery of your phone. The model number along with the IMEI of the phone should be present.
4. Now, select the country and the operator the phone is locked to. For example “USA- T-Mobile”
5. You are now given the unlock codes for your cell phone. A lot of people have a problem punching in the alphabet p and w while entering the unlock codes.
To enter the codes,
here is a visual guide below as well as the step by step procedure
a. Push #
b. Push * 3 times in a second. (p will show)
c. Push * 4 times in a second.(w will show)
d. Push * 2 times in a second(+ will show)
e. Enter the code from below.
f. Push * 2 times in a second.(+ will show)
g. Enter the code number
h.Push #
Good LucK:-)
Jul 08, 2010 | Nokia Lands Phones
E51. when switched on, only shows Noika on white background, and will not respond. there is nothing else on the screen
This generally happens if you are using a hign volume SD card such as a 4 GB one and have a lot of files there. Then nokia when booted may try to scan all those files and takes a lot of time.
Remove your SD card and move most of insignificant data onto your computer using a card reader or the nokia usb cable. Then put the elmost-emptied SD card in your cel phone and try to reboot the phone.
Hope this helps.
Otherwise visit a authorized nokia service centre, they will upgrade the nokia's system.software and will fix application problems if any.
Nov 05, 2009 | Nokia E51 Cellular Phone
METROLOGIC BARCODE READER WAS WORKING NOW NOT WORKING
USB CABLE PLUG IS DAMAGED. HOW DO I REPLACE IT OR FIX IT. ITS VITAL TO OUR BAR CODES. CHARLES FRAZIER TEXAS FARM BUREAU 254-751-2580 THANKS
Apr 18, 2009 | Microsoft Metrologic MS3780 Fusion Barcode...
Ms9535 bt not reading barcodes.
I'm using the same Barcode reader, the Metrologic MS9535 VoyagerBT.
The brief humming noize is called a "Rasbery tone" in the manual. It means that the barcode reader is not configured to read that kind of barcode, a barcode Code if you will.
There are many types of barcodes so you have to go to the Metrologic Website and get the Barcode Configuration tool to configure your barcode reader to read the type of codes you will be using.
Alternatively there is a book with configuration barcodes you can scan to configure your barcode reader manually.
Sep 28, 2008 | Metrologic Instruments MS9535 VoyagerBT...
My nokia phone have problem
hi you need to check your imei number it should be 15 numbers long so check it i can get you the master security code but check your imei number ok
Jan 30, 2008 | Lands Phones
Nokia N95 Cellular Phone Logo
151 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
