Question about Dryers
Hotpoint electric dryer
Hmms when i turn start knob
  • Anonymous Sep 17, 2008
    how do u replace the belt on the TDC32
    Genius:
  • 1,554 Answers
Belt may have broken if the tumbler is not turning.
Posted on Jun 04, 2008
I have a hotpoint Aquarius 1000 Washer/Dryer model number wd23w had it about 15 i used the dryer for first time and now everytime i put on a wash as soon as it is finished it goes straight on to dryer
Hi
you will prob find the knob for the dryer has broken
so you turn the knob but it doesn't turn the switch
remove the knob which just pushes on and pulls off
and look at the shaft of the knob you may see it has cracked
if you do just replace the knob and you should be fine
Jul 01, 2016 | Hotpoint Washing Machines
Our electric hotpoint dryer stopped spining & got hot & it smelled hot now we can't even get it to turn on
Let's start with the easy stuff.
Check the belt
Thermal fuses
door switch
Do you know where they are?
Dec 12, 2012 | Hotpoint Dryers
I need to replace the dryer knob on my Hotpoint TDC32 Dryer and I cant find anywhere in Dublin that sells them. Do you know of anyone that sells these in the area
If you are internet savy, you can probably find it for cheaper. There are many websites devoted to appliance repair out there.
Feb 05, 2011 | Hotpoint TDC32 Electric Dryer
I have a hotpoint dryer model nbxr453evoww. when turn the knob to start it, it wont stay on.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | Hotpoint NBXR463EBWW Electric Dryer
When you turn the start knob it makes a noise and does not start a cycle.
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 06, 2010 | Hotpoint NVL333EY Electric Dryer
My dryer is getting electrical power. But when I turn the power knob onto ON, nothing happens.
it may be the door switch, but if you hear a click when you push the start button then the motor reset button tripped. You should be able to set the dryer on its front side and see the motor reset buttons as there are two one trips one resets, push the reset in it should click and then plug it in and see if that helped. Hope this helps if not feel free to ask more info as I am more then willing to help Tim
Oct 16, 2010 | Hotpoint NWSR483EBWW Electric Dryer
Turned knob and got a buzz. turned knob again and no sound. Just finished a load and was starting on the next.
Hi. im assuming the buzz came from the timer knob(behind the knob). if so, this will confirm timer failure and, you will need to replace this timer control module in order to restore proper function to your unit.
If the buzz was located behind the start switch, replace as well.
May 21, 2009 | Hotpoint Dryers
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
It wont turn over
if you can do repairs, take off the front cover and remove the belt off the motor then try starting it. if the motor spins then the problem is the rear drum bearing or the felt "bearings" on the door. if the motor does not start even with the belt off, the start wining on the motor is burned up. replacing the motor costs around $150.00
Sep 22, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Dryers Logo
77 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
