Question about Sega Dreamcast Console
DC stops and starts games periodically
I have a DC that I bought right at the end of production to replace a broken one and it has problem which could be motor related.
It will boot up and load a game, play for a random amount of time and then the disk will stop spinning and it returns to the main menu, then the game will load up again almost immediately and play for another random amount of time. It will repeat this over and over. Sometimes a game will run for 5 minutes before restarting and sometimes it will go for an hour or more. the interval between restarts seems to get longer if the machine has been on for a while.
  • mothman Jun 14, 2008
    Thanks, it seems to work if it is turned upside down even though I didn't think it would. I've tried piling books on the lid, and putting a tight elastic band around the DC and the games still restart as if the lid has been opened.
    However I flipped the console over and played Skies of Arcadia for an hour without a restart so I think it may be a solution even if it does look silly. It's better than having to buy another one.
  • mothman Jun 26, 2008
    aargh,
    After successfully playing without stopping and restarting the game in three or 4 tries it has now begun stopping and restarting even when it is turned over. I'd been playing Skies for about 3 hours and then the disc stopped reading and returned to the menu where it checked the disc again and then reloaded. I'm wondering if it could be the motor.
~Open up the dreamcast
~remove the Powerboard (located to the left houses power supply)
~get baby wipes or facial wipes and clean the pins
~dry with toilet paper
~put it all back together
That will fix it ^_^. i had this problem as well and didn't play my DC for years then i stumbled on a youtube video and now it works great never restarts. have fun playing old games again.
Posted on Apr 28, 2009
Is there any where that any one can fix it?
Posted on Jul 31, 2008
  • 22 Answers
This may be because of s problem with the thing that holds the lid down because if you open the lid the game stops.
you may need to get something to hold it down
i had this problem once. i just put th DC upside down and it was fine. for a while.
i just used a new power lead and its fine now
Posted on Jun 13, 2008
  • Quicksilver Quicksilver
    I think the motor may be the problem because dreamcast motors are generally weak.
    a new power lead may help
    you can probably find them around the house in radios and stuff.
  • 36 Answers
Its the lid contact, if you take the top case off the dreamcast (4 screws, one is under the modem), you can see this microswitch on the top right. The problem seems to be that it works OK but the contact becomes dodgy, pushed in too far it loses contact. Shaving a bit off the top of this switch could work so that it contacts a bit lower on a "good" bit of track, but your mileage may vary. alternatively you could short the switch and you'd have to use the power button to change disks. Not ideal for multi disk games!
Posted on Oct 07, 2008
I bought a Malibu 300W low voltage landscape transformer to replace a 200W unit that stopped working. It worked for 1 week, then stopped .. the reset **** doen't work. The LED works, I do see a...
I don't know if it burned out, but something is not right.
Malibu products come with 1-5 year warranty.
New product that stopped working should be exchanged for full replacement at place of purchase, except possibly the auction sites.
New Malibu product should work for many years.
Be sure to match bulb voltage with transformer voltage to avoid possible problems.
Mismatched bulb and transformer wattage should not affect a timer in short period such as 1 week.
Another thing to check is outlet polarity. Use circuit analyzer from home center to check outlet.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Jul 20, 2011 | Intermatic Malibu 300W Power Pack...
Tip
All Cars ABS light on
For those of you that have abs brakes if the brake light comes on what happens Is it goes into standard brake mode. This means that the brakes lock up as if they had no abs system so if you jam the brake pedal down the wheels will stop spinning. If you are in wet weather or on ice it could cause a skid and cause you not to turn while slamming on the brakes. So if you have the ABS light on you need to have them checked but does not mean you have to take it to the shop right then it can be later, be aware that extended use without the ABS being serviced could cause damage to the ABS system. Most ABS lights are caused by a dirty magnetic ring on one wheel, on rear wheel drive cars it could be the one on the end of the transmission or the front of the differential. These put out 2.5 volts dc to test use Digital meter put it on 5 volts dc and spin the wheel with the connector disconnected probe the ring connector to see if yo have 2.5 volts if not it has a broken ring or wire, if the magnetic ring is broken it will have to be replaced. Most models have to have the rotor replaced on the front end and the sensor on the rear end.
on Dec 03, 2009 | Chevrolet 2500 Cars & Trucks
I need my product key to start MS Publisher
The 25-character product key is found either:
* on the packaging if you purchased the software at a retail store,
* in your E-mail, if you made an online purchase.
If you recently bought a new computer, it could have had a "trial" version of MS Publisher installed. After the end of the trial-period, usually 30 to 60 days, you must either stop using the software, or follow the on-screen instructions to make an online purchase of a license-key.
Oct 19, 2010 | Microsoft Office Professional 2007 Full...
I just bought a new battery charger cable called (Sealed Lead-Acid Charger) to replace an older (Lead Acid battery charger). The New Battery charger will charge for about 2 to 5 minutes and then stop...
ismail the charger you bought should do the job. By stop charging do you mean the light on the charger turns from yellow to green? Your scooter has small batteries 12/12 and don't require along period of charging. Now the scooter has a heat sensor for the batteries and will cut off charging when temp of the batteries gets too high. The older charger could have overcharged your batteries and made them weaker instead of stronger. I would suggest you replace the batteries (2 12/12AH) and charge them with the new charger. Remember to reinstall the heat sensors on each battery when replacing. If you have a digital voltmeter set it to 200 v dc and put the leads into the 2 outer plugs in the charger port on the battery pack. You should read 24-26 volts dc when the batteries are fully charged anything less would mean weak batteries. Hope this helps you
Oct 03, 2010 | Pride Mobility Products Go-Go Elite...
Every time i open a document in Microsoft Office Home and Student it asks me for a product key, but i was never given one when i bought the computer. Where can i find one?
When you purchased the computer, a "trial" version of the software was pre-loaded. After the end of the trial-period, typically 30 days, you either have to stop using the software, or buy a product-key, either from your local computer-store, or by using your credit-card on Microsoft's E-commerce web-site, to authorize further usage of the software.
Sep 22, 2010 | Computers & Internet
Whammy bar stopped working on wii guitar also unsure of warranty period for this product
First call the place you bought it say what they say about a replacement. If no luck goto nintendo.com and goto there support section they will have a number for you to call. This is something needing replacement. Nintendo's usual pretty good at doing replacements.
Apr 01, 2009 | Nintendo Guitar Hero Wireless Guitar - Wii...
Broken Leap Frog Leapster Learning Game System
I purchased a Leapfrog Leapster in end of June sales last year for my daughter's birthday in October 2008. When she first turned it on it froze but after restarting played fine for 2 hrs then died and refused to work again. Fortunately I had kept my receipt (Target) but was still worried about it having been 4 months prior. They ended up giving me a store credit as they no more in stock at that store and I picked one up from another Target without having to pay the difference between my original sale price. I know you don't have the receipt but you could contact the place of purchase and ask them even if they are able to send off for repairs or put you in contact with the right people. Hope it helps a little ...
Nov 16, 2008 | Toys
DC adapter issues
make sure the dc adapter is the same voltage and everything if it isnt DONT PUT IT IN it could wreck the system
Oct 04, 2008 | YOBO Fc Twin Console
ImageRUNNER 1600 E100 System Error
if a little part of drum is broken the door of laser is closed. J am sorry for my english .
Mario. (Rome-Italy)
Nov 26, 2007 | Canon ImageRunner 1600 Copier
BROKEN ANTENNA BROKEN AC/DC ADAPTER
I just started to put some stuff on ebay and I have new one ac/dc adapter Model # ae9512
Good Luck!
silverrockny (my ID on ebay)
Store nameon ebay: The right Stuff Store
Oct 27, 2007 | Emerson iP100 Clock Radio
Sega Dreamcast Console Logo
506 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Josh Whitehead
Josh Whitehead
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
