Question about Anvil NEW 12in Gas Flat Top Griddle Grill
Peter wright england anvils
When did he start making anvils? How can I tell how old one is? Is he still makeing anvils? Thank you
Dan
How do you craft an anvil
You don't! for an anvil to be any good it should be made of carbon steel and be tempered. the process requires a very good workshop with some heavy kit and a group of people who know what they are at. Having said that an anvil is just something hard and big to bash on, go to your local scrap yard and get a big lump of steel off a digger or something and custom the shape to what you want, make sure it has a flat side to bash on and set it into somethin very solid. A post anvil is easiest, a very big old sledge hammer head set into a steel pipe and in a hole full of concrete is a very serviceable tool, but since you can buy an old anvil for less than £100 you could save a lot of work, the cheaper ones usually need the top re-grinding to flat, dont worry about it lkosing it's temper, a grinder will not heat it up enough.
Jun 28, 2014 | Tools & Hardware - Others
I'm in the market for an anvil and have read about cast iron ones from China. I am tempted to buy once because of the great price. Would you recommend them?
I wouldn't buy a cast iron anvil personally. They tend to be junk. They are brittle and chip very easily and definitely aren't suitable for normal use.
Sep 10, 2013 | Tools & Hardware - Others
Having problem with the timing gear setting
Hi on the camshaft and crank sprockets you should find dotted marks to align with the cover at the back side of the sprockets.I would give you the advise to hand turn the engine to make sure that the timing is wright,failing to do so might damage the engine.hope this will help.
Peter
Nov 15, 2010 | Kia Cadenza Cars & Trucks
I had to sell my first copy of Elder Scrolls IV Game of the Year Edition. Now I recently repurchased it but now I can't play the Shvering Isles or the Knights of the Nine Quest Lines. I have already...
Have you loaded Shivering Isles to the hard drive? The Knights of the Nine quest requires you to stay out of Anvil for a few moments. If your game save is in Anvil, leave the town, fast travel to a new town, and talk to any NPC, Attack in Anvil should be a conversation option. Select this and follow to end. Return to Anvil and head for the Chapel, you should hear some guy ranting about the Chapel being attacked and so forth. Talk to him and quest will be started. Shivering Isles pops up the second your game loads as a mysterious door has opened in Niben Bay. Swim to the island and enter the portal.
Oct 19, 2010 | Bethesda Softworks The Elder Scrolls IV:...
Hi, my tayota 1997 Rav4 does not start and the mecanic stated that it is the electric box. How the electric box got damage and how much is the part. Please help me the mecanic said that the part alone...
THANKYOU...give him a wide berth and get someone ELSE to explain EXACTLY what is needed, then get back to us, or tell him to tell us whats needed.....sounds better.if he hesitates or makes some excuse, you still have your money .
GOD BLESS
GEOFF
ENGLAND.
Sep 16, 2010 | 1997 Toyota RAV4
Why peter cannot answer me?
PeterAnswer.com is a simple program. if you don't know how it works then it will never answer your. that is not a magic that is trick to make people fool.
i am telling you how peter answer.com works to make fun.
type question on question box
Peter. please answer and type your answer
it will show you that you are typing question
when you press the enter button the answer will reflect on answer box
Apr 13, 2010 | Computers & Internet
What printer driver do i install to get my printer,
you need to determine first what is your operating system say, Vista or XP first, then you can download the required driver to lexmark.com
Jul 19, 2009 | Lexmark X2600 InkJet Printer
Is there any maintenance I can do on a Kango 950 Jack hammer
Ureythn GE00 is madr by Fuchs in Germany - see their website.
Darina is made by Shell - see internet for comparable grease
Apr 21, 2009 | Hammering
New ram for quinny buzz
Be sure it is the gas ram and not the cast aluminium anvil which the gas ram pushes against. The symtoms are similar
This 'L' shaped casting snapped in half on our Quinny Buzz and I managed to repair it by taking the whole centre hinge apart, drilling out the pin which holds one half of the aluminium anvil in place and removing this striaght piece of the anvil.
To repair I first glued the two parts together with araldite then held them in the vice whilst drilling through both pieces to a depth of about an inch with a 4mm tapping size drill. Then seperate the two parts, tap the shank out 4mm and drill the right angled bit 4mm clearance. Reconnect the two parts using a 4mm steel screw and some 'locktight'. Replace the anvil in its slot and replace the holding pin securing with araldite.
Reassemble the whole shooting match and it works ( well ours did....and still does!)
This seems to be a common problem but I could not find any spares. Also the holding pin for the anvil is not made to come out hence having to drill it out. So I doubt if any spares are available anyway.
Not easy and you need a few engineering tools to do the job. But much cheaper than a new frame assembly.
Jan 08, 2009 | Quinny Buzz Jogger
Anvil NEW 12in Gas Flat Top Griddle Grill Logo
324 people viewed this question
Top Anvil Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Anvil Kitchen Appliances - Other Expert? Answer questions, earn points and help others
