Loss of two to three inches of vision on plasma tv as line running from top to bottom of tv
    Sergeant:
  • 458 Answers
This is a place for computer questions.
Posted on Jun 04, 2008
40 inch Philips tv has a brown line in the middle of the screen, can it be fixed???
is this an lcd or plasma tv?. then does the line stay in one area or it was moving while the tv is working?. can you give this some detailed which can help out solve the problem.
Oct 16, 2012 | Televison & Video
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
Best picture settings for samsung ps50a457p1d
my 50 inch samsung is 4 years old. a black line has appeared just off centre screen. the line is approx.an inch wide and runs from top to bottom. can it be repaired?
Mar 08, 2012 | Samsung PS50A457 50 in. Plasma TV
About two months ago my flat panel plasma tv
Most like likely, this is a panel issue and it will be too cost to fix.
Other things you can try, reseating the ribbon cables on the buffer boards located running across either the top or bottom or both. If that doesn't do it, replace those boards and still no luck. Panel is bad.
Feb 16, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Philips 42pf9946/12
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Dec 31, 2007 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
JVC AV-48WP30 has vertical lines every inch or so...
This may not be the problem but its worth a try:
Sep 24, 2007 | JVC AV-48WP30 48" Rear Projection...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
