Question about Maytag Legacy Series Top Load Washer
Legacy leaked on floor and subsequently ruined gararge ceiling. I put a wash in yesterday, filled it shut it off and left it soaking. I returned home from my errands three hours later to an 3/4 empty SS wash tub and a water damaged garage ceiling, double layered dry wall. How to I verify cause of leak? ???Wash tub seal? Hoses or pumps? I have heard the usual stories of too soft a floor for the unbalanced spin walking. My house has 2x12 floor joists 16 in on center, My Maytag will be four years old this october! So much for durable goods these days.
  • 1 more comment
  • AML1958 Jun 08, 2008
    Thank you for the tip. I experimented with a small wash load with repair panel removed and a flood light. I found out it was not a main seal! The drain hose had some slack in it and had rubbed up against the rear auto level bar (sharp metal bar!) and a small perforation developed. I repaired the hose and the leak. To prevent the same thing from happening to the replaccement hose I cut the old hose and created a shroud for the new hose near the sharp metal points. Many thanks to everyone at Fixya for your help.
  • azad14 Jul 28, 2008
    The leak was severe and on removing the hose from the drum to the pump there was a perforation of the tube caused by rubbing of the plastic tube on the metal sub frame. I will try the "shroud solution but maybe Maytag would enlarge the sub-frame perforation to prevent this problem.
  • sudhirshah0 Oct 08, 2008
    My Maytag legacy 8600 washer is leaking from top when we try to fill it up. what can be th e problem?
    sudhir shah
  • 3,037 Answers
Its most likely the tub seal at the bottom, check and see if the area inside is wet in the middle. You will need to remove the outer panels to do this. It doesn't sound like anything else if the water was left to sit so a replacement of the seals around the center shaft should fix this problem. Let me know if you have any questions about doing this and I would be happy to help.
Posted on Jun 04, 2008
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    sounds good, glad to be some help, Please rate this solution for further feedback if you wish and have a good day
Why would washer leak water
My wife developed a new idea about filling her toploader; first fill with water, then put the dirty washing in. No surprise, the dirties displaced the water which then spilled out on the floor. If you put the dirties in first it works the way it should. If this is not your problem you need to look for the water level sensor which is basically a tube sticking down into the water, most often in the back left corner. This could be blocked at the bottom with detritus from washables or, not very likely, scale. You may also have a defective sensor and need to replace it.
Good luck.
Oct 24, 2014 | Whirlpool WET3300XQ White Washer/Dryer...
My air conditioner's bucket is overflowing with water and leaking all through the ceiling onto our floor, ruining the paint on the walls. Any solutions?
I assume you have a unit in the attic as described condensate leaking from ceiling and down the walls etc.
What is not normal is a bucket to contain the condensate, there should be 2 lines a primary from the evap coil and a secondary preferably from a secondary drain pan resting underneath your unit. A bucket will never work in this capacity.
Oct 09, 2013 | Heating & Cooling
1990 subaru legacy- overheats, I"ve
Most likely you put the thesmostat in upsid down. Good luck
Aug 17, 2011 | 1990 Subaru Legacy
My washer is keaking water on the front left side. I think when its draining. i had the new style top put on that stops water from spilling on to the floor when filling
check that your drain hose is tight pull machine away from wall and see if it leaks there during drain cycle if it is leaking here tighten connection/Also check that it is tight at the faucets as well
Jan 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer leaks when filling,fill by pail no leak
Pat it sounds like you pressure switch or hose to it is bad.your washer isnt leaking its overflowing the tub right?I dont understand the rest of your question so ill leave it alone..
Nov 15, 2009 | Washing Machines
My machine is not aggetating it just keeps filling with water
if the water is not over flowing on the floor.make sure your washer is off,then pull the drain hose up to the level of the back control panel you should here water flowing out once this stops.keep the hose up for aminute and restart your waher and it should fill up to the proper level and shut off and start washing
Sep 26, 2009 | Maytag Legacy Series Top Load Washer
Whirlpool duet washer fills with water when not running
one of the control valves (hot or cold) is not closing the water supply, most likely leaking so the electronics are good. one of the valves needs replacing, but if you dont want to spend the money just shut the water supply off at the water supply taps.
Jul 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Rocking and VIbrating
As long as you have it on the second floor there really isnt anything you can do to fix it anything you do will probably make it worse there is only one washer i know of that is front load and acts decent on the second story and thats the new samsung with the roller bearings. Sorry to tell you but u will probably end up moving it to the basement
Jul 14, 2007 | Kenmore 43142 Front Load Washer
Washing Machines Logo
137 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
