Question about Sub-Zero 661/F Side by Side Refrigerator
Loud humming noise as fridge is running
My Samsung fridge is not yet a year old. It has started this loud humming noise while it is running. it varies how long this noise will go on, sometimes a few minutes other times a half hour. I flip the breaker to make it stop but ultimately it starts again. This happens many times in a day. I have opened the doors to see if the noise is loud inside the fridge and it seems to be coming from behind. There is a protective cover on the back so I can't see what is going on while the noise is present. Any suggestions? I have sub-zero fridge about 18 years old. It has started this loud humming noise while it is running. it varies how long this noise will go on, sometimes a few minutes other times a half hour. This happens many times, on and off during the day and night. I also have ice built up to approximately 60% of the coils, at the rear. Would appreciate a solution. Thanks.
  • Anonymous Mar 12, 2014
    Kenmore elite 72053 model. Ice not being made. check line and switch and temp.
    Genius:
  • 1,554 Answers
If you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Posted on Jun 04, 2008
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that...
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Jun 06, 2012 | Refrigerators
I have a samsung french door refrigerator that is only 20 months old and it just started making a very loud humming noise that is coming from the back/top of the fridge. It stops when you open the fridge...
Hi David,
There's a big chance that the evaporators fan touching ice and that's why you hear that noise, if you have an ice build up you gonna have to defrost the fridge and test components to see which one has failed.
Thanks
samedayappliancerepair.ca
Jul 07, 2017 | Samsung RFG237AAWP Bottom Freezer French...
Samsung rf265 series refridge is making a loud humming noise--only 1 year old
It is a well known defect.
the ice is builing up until it interferes with the fan.
The samsung people will not help you. You are screwed.
A&E appliance repair(Sears) told us to take all the food out and leave the doors open for 24 hours.
This happens at least once a month.
We cannot ever buy a fridge from Samsung again or from Lowes.
They ****** us hard. Good luck
Mar 21, 2011 | Refrigerators
My set started humming recently. Not real loud,
Hi, sounds like a bad color wheel, a technical repair that should be done be a trained repairman, cost around $250-275 installed
Aug 17, 2009 | Samsung HL-S5087W DLP TV
Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Feb 12, 2008 | Refrigerators
Hey everyone-
I recently fixed a similar problem with my freezer. I searched first and found this and a few other sites which listed this and wanted to provide input for anyone in the future.
I have a GE GSH25JSRF SS. It is about 3 years old. Several months ago I noticed when the evaporator fan in the back of the freezer turned on it would make an awful howling or whistling sound. Basically sounded like what you would hear from the window of an older house if the wind outside was blowing real strong. It was loud enough to hear on the other end of the house.
I was convinced that it HAD to be the air blowing over the venting or a gap that created that sound. But I read different solutions on the internet and decided to take a chance on simply replacing the evaporator motor and attached fan blade. That solution worked and my house is quiet again, thank god.
I ordered the parts from a supplier on the internet. Keep in mind, though, if you're not real handy it may be more than you bargain for. Might be easier to have a service guy come out.
I'm still not sure exactly what aspect of these parts caused the howling sound. It could be a bearing within the motor or perhaps the fan blade slipping due to wear. Either way, it's fixed now. Just wanted to share. Thanks.
Oct 04, 2006 | Samsung RS2630WW Side by Side Refrigerator
Sub-Zero 661/F Side by Side Refrigerator Logo
1,109 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
