Question about Bose & Wave& Music System
Cd stuck my cd will not eject. keeps reading disk error Wave music system did not automatically draw the disk in. I gave it a nudge and now it won't play or eject the disk
    Genius:
  • 3,422 Answers
HI,
It is jammed and it will not come out of it. You have to open the cover and manually eject the CD from it. There is no other way you can take it out.
The best solution is to get it serviced.I hope it is still under warranty.
Goodluck..
Posted on Jun 04, 2008
  • Priya darshan Jun 04, 2008
    Please don't forget to rate the solution
    Brigadier General:
  • 3,614 Answers
May i know the model of your unit.. and some more info.
`micro
  • micromaster
    micromaster Jun 04, 2008
    - have you try to open the unit, there could be a mecchanical problem,..
  • micromaster
    Look for the fuse that controls the CD player and pull the fuse out for a minute (or more), then replace it, the fuse acts as a reset button.
    Try to disconnect the negative battery cable, If you cannot find the fuse,
    Master:
  • 555 Answers
Did you try resetting it?
A CD is stuck in my bose system How do I get it out?
From an other web site
If you have a cd or two stuck in your Bose wave radio, here's how to remove it and save yourself $99. This procedure is for the radio (model AWRCC1 or similar) with a single front loading cd slot.
PART I
1. First unplug the power, wait a minute, and then replug power, watching the front display.
2. The display will read "Ejecting". If the cd ejects, then you're done and can skip Part II. If it doesn't eject and/or it displays "Disk error" then you'll need to do the Part II steps.
PART II
1. Unplug the power cord.
2. Turn the radio upside down with the front facing you.
3. Remove the 5 screws from the bottom plate.
4. Hinge the front of the bottom plate up no more than 2". Don't overdo this or you'll damage various ribbon cables inside. Use extra hands or a prop to keep it open this amount.
5. Reach inside and tilt-up the front of cd player's metal housing just enough to access the rims of the cd(s) within the space created in step 4.
6. Pinch the rim(s) of the cd(s) and gently pull it/them out.
7. Reverse these steps to reassemble your radio.
Enjoy your cd player again!
Oct 09, 2014 | Bose & Wave& Music System
Disc error
Check the Disk opener tray Belt if it is not opening...
Nov 17, 2013 | Bose Wave music system Multi-CD Changer...
All 3 CDs will not eject
When Turned on Hardrive keeps reading BOOTING UP but never ends
also cannot load
Can anyone HELP
Jul 05, 2009 | Bose Wave Music System CD Shelf System
Can't get a dvd to eject from from a Lexus cd player
basically just carefully insert another CD into the slot, but only about 1 to 2 inches of the disk and keep jiggling the disk around and pressing the eject button.
This was a suggestion for the lexus owners club wed site.
give it a try and if it doesnt work let me know and I will try to find something that does.
Jan 10, 2009 | Bose & Wave& Music System
Bose acoustic wave music system
I have the same problem: ready to throw it out and get a new one
Aug 18, 2008 | Bose Acoustic Wave music system II -...
CD stuck in BOSE 3 disk stack player
I had the same problem and went to the Bose Tech Support site and found this solution. It allowed me to eject the stuck CD. The same problem happened again when I tried to enter another CD but after repeating the process below the CD ejected again and after that it worked fine.
Hope it works for you.
  • Try performing a reset with your Wave® music system upside down:
    1. Unplug the system, flip it upside down, place it on a firm, level surface, then plug it back in again
    2. If the CD ejects when you do this, the system may need to be serviced. Contact Bose® Technical Support or call 1-800-278-1281
  • Jun 06, 2008 | Bose Wave music system Multi-CD Changer...
    Cd stuck
    if you are good at opening the player then just follow this steps...
    1.take of the screws
    2.remove the cover
    3.take off the rubber belt connecting the dc motor
    4. now you can take the door out by sliding one white coloured clip
    5.now clean the obstacles in the door way and every where
    use dry clothes..
    6.clean the lens also by using the white petrol or spirit....
    then reassemble just put the cd and play...
    90% it will work
    if you are not good at opening then contact the technician........
    Feb 08, 2008 | Bose & Wave& Music System
    Cd stuck
    unplug the unit and as you plug it back in start pressing the eject button in one second intervals as it powers up. This should command it to eject before it tries to read the disc.
    Sep 21, 2007 | Bose Lifestyle 30 System
    Bose & Wave& Music System Logo
    478 people viewed this question
    Top Bose Audio Players & Recorders Experts
    jjcicala
    Level 1 Expert
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
