Question about Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 5600
This is just a follow up on the solution that you posted for my laptop.
When I plug in the AC adapter with or without the battery, I can hear some sort of whistling from the AC adapter even though the light on it is still on.
If you think it's still the power jack after I told you this I would not hesitate to tear the laptop up to change the power jack.
  • 458 Answers
You still need to test the AC cord better.. Wiggling it in different areas to see if there is a break in the wires.... That is why i said watch for the Power light (when I say Power Light, not the one on the ac adapter cord... the power light on your laptop...)to see if it flickers or turns off at any point while you're testing the cord... If you have a Solid Lighted Power Light the whole time youre testing the AC cord (bending & wiggling it) then it is probably not the cord itself and i would then lean towards the DC jack...
Posted on Jun 04, 2008
AC adapter 4750z
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
If you need to buy a new laptop charger, the following to adapters are for your reference:
Replacement Acer Aspire 4750 AC Adapter 65Watt 19V 3.42A
Replacement Acer Aspire 4750 AC Adapter 90Watt 19V 4.74A
Nov 15, 2012 | Acer Pwr Ac Adapter For Travelmate 4750...
2 ac adaptors have stopped working on acer laptop
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.
If it still can't work, perhaps the charger you bought is a dead one, just contact the seller to get a replacement one after all you have used it for about a few minutes. If you don't believe in that seller, just contact them for the refund and go to other vendor for a new adapter. I recommend the following one for you:
http://www.chargerbuy.com/replacement-acer-aspire-5739g-ac-adapter-19v-4-74a.html
http://www.chargerbuy.com/replacement-acer-aspire-5738-ac-adapter-19v-3-42a.html
Oct 26, 2012 | Lifetime Acer Aspire 5738PG Replacement...
I have an acer aspire one aand even though I plug it up it says (plugged in, not charging.) How do I make it charge?
Welcome to FixYa!
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Jul 17, 2011 | Acer Aspire One PC Notebook
Acer Aspire 7741Z - 4643 that is only 2 month old. It is plugged in, and recognizes that it is plugged in, but does NOT charge the battery. Please let me know what to do. Thanks, Not charging
Hope this will help...Your response is very much appreciated...
Feb 06, 2011 | Acer Aspire One PC Notebook
Ummm, hi. i was wondering how many watt my Acer Aspire 5600 runs?
Power
subsystem
ACPI 2.0 CPU power management standard: supports
Standby and Hibernation power-saving modes
71 W 8-cell or 44.4 W 6-cell Li-ion battery pack
Acer QuicCharge™ technology
(for Aspire 5600 Series):
• 80% charge in 1 hour
• 2-hour rapid charge system-off
• 2.5-hour charge-in-use
90/65 W AC adapter
Oct 14, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Battery
Nothing to worry about mostly all the laptops do this,
Sep 10, 2008 | Acer Aspire 3680 Laptop
Wireless not working when ac adapter plugged in
It looks like you've changed the settings to turn off the wireless when AC adapter is preset. Try going into Acer Power Management and make sure Wireless Lan is selected on your Power Plan.
-Aaron
Aug 06, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Battery
If you've replaced the battery and the AC Adapter, the only thing left is the motherboard.
A couple companies advertise MB repair for this model
http://search.ebay.com/search/search.dll?sofocus=bs&sbrftog=1&dfsp=32&from=R40&satitle=acer+5600+motherboard&sacat=-1%26catref%3DC6&sargn=-1%26saslc%3D2&sadis=200&fpos=ZIP%2FPostal&sabfmts=1&saobfmts=insif&ftrt=1&ftrv=1&saprclo=&saprchi=&fsop=32%26fsoo%3D2
Jul 22, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Laptop was working fine, but doesn't turn on anymore...
a5e3d98.jpg You might have a Loose DC Power Jack.. Or.. if you're using the same AC Power cord for both laptops that you tested, you apparently have a break(short) in the Power charging cord which is quite common...
To Test the cord..take the battery out and try to boot with just the AC power cord plugged in, If it does'nt power up, try turning and slightly twisting the plug into the port.. LOOK to see if the power light is on or flickers...
Jun 04, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 5600 Series 5630-6951 Laptop Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
