FixYa.com
Tags:
Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Bissell Proheat Clearview 1669
posted by Puyallupllm on Jun 04, 2008
I need to get to the heater in the handle since everything has been checked and I still do not get any fluids to come out. They do come out through the accessory hose. I read that since everything has been checked and cleaned (filters, etc.) that I need to clean debris from heater but I can't seem to get to the heater. I removed all the screws in the handled but still was unable to see heater. can you help?
Thanks so much!!!
Linda
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 17, 2008
FixYa! (100)
reddevil6
Rank:Guru Guru
Rating: 88%, 1055 votes
Take off the 2 long screws and remove the top part of the handle. Then from the back, just undr the hose and cord wrap asm, there are 2 screws set deep in the holes to remove. Don't remove the cord and hose wrap. Then lay the handle back, at the top, in the center, there is a catch to push in, then the top half will come off and you can get to the heater. Remove the hoses, one of the hose ports maybe clogged, clean them out, sometimes stuff in them gets pretty hard and hard to clean out.
After you may want to run a mix of vinegar and water thru the system to clean it all out.(not on your carpet tho)
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Vacuums problems?
Vacuums
HOW DO i change from
how do i change from vacuum to... Answer This...
Vacuums
How do you a change
How do you a change the belt on... Answer This...
Vacuums
need instructions on shampooing
need instructions on shampooing Answer This...
Vacuums
tristar vacuum reset button
Hey there, We currently have... Answer This...
Vacuums
Was vacumning watershut off...
ShopVac QPS series,Quiet... Answer This...
Repair Service
Find Vacuum Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
