Question about Plantronics 510 Voyager Headset - PLN-510 Headset
People complain they can not hear me when using headset
I have had my 510 Voyager for about 6 months and people complain they can not hear me when I using my bluetooth. Any suggestions?
  • 1 more comment
  • Anonymous Jun 06, 2008
    People cannot hear me tho I can hear them fine. I checked all settings on Skype and my Powerbook settings all are correct. Have had this problem before. I reset the plantronics 510 bluetooth Voyager headset and it worked again. Cannot remember how to reset it and cannot find this instruction in the manuals. Don't know for sure if this is the problem but was before. How do I reset or what else could it be.
  • Anonymous Jul 02, 2008
    same problem. how do you reset it.
  • schilr Sep 16, 2008
    i can hear fine, but people cant hear me
    Problem Solver:
  • 7 Answers
Aparently over time the oils off of your face get to the microphone cover which is a sort of grey hardened foam, & it starts to decompose the material effectively "stoping up" the mic. You may be able to scrape off the outer layers, or just snip a little off of the very end. Be sure not to take off too much or you risk the possibility of cutting into the mic itself!
Posted on Sep 13, 2009
How do i connect my plantronics 510 voyager headset to my blackberry
Once you make your BlackBerry discoverable, then put the Plantronics Voyager 510 into pairing mode by holding the call control and volume up buttons at the same time until the headset flashes red and blue. Here is the link below for the 510 pairing instructions.
Plantronics Voyager 510 Pairing Instructions
Good luck from Headsets Direct!
Oct 19, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Syncing it to my 3g I-phone without a manual
This link should help you pair your voyager 510 to your iPhone:
http://www.headsetsdirect.com/plantronics-voyager-510-bluetooth-pairing-instructions
Good luck from Headsets Direct - 800-914-7996.
Aug 22, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Can't hear my pc to head set..can u help
Hearing a Plantronics Voyager 510 headset through a computer:
To use a Plantronics Voyager 510 headset through your computer, you either need a USB Bluetooth adapter or you must have Bluetooth built in to your computer. Once the Voyager 510 headset is "connected" to your pc (by one of the mentioned ways), you may need to go into the control panel on the computer or the specific software program being used to set the Plantronics Voyager 510 headset as the "default device". Keep in mind that the headset has to be powered on and to also have to activate the headset to connect to the Bluetooth adapter or computer.
Aug 20, 2011 | Plantronics 510 Voyager Headset - PLN-510...
How do I put the unit in discover mode
Putting the Plantronics Voyager 510 into pairing mode:
With headset on, press and hold the call button and the volume up simultaneously until the headset begins to flash red and blue.
Select the Plantronics 510 headset in your phone when prompted and enter 0000 (4 zeros) as the PIN/passcode if prompted. When paired, the Voyager 510 headset should now have a continuous blinking blue light. Here is a link below for the step by step pairing instructions.
Aug 12, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Wife complains of echoing when listening to me on headset. Love the headset cause I'm hearing impaired.
Plantronics Voyager 510 echoing:
If the Plantronics Voyager 510 headset is being used with the base on a regular telephone, you can adjust the microphone volume on the bottom of the base unit.
If the Voyager 510 headset is being used with just a cell phone... unfortunately there aren't many adjustments. You may want to un-pair and delete the headset from the cell phone totally, and then re-pair it to the phone just to make sure that it has a strong link or connection.
Also just as a side note about Bluetooth headsets and cell phones. Typically the simpler the cell phone, the better the Bluetooth connection and quality.
Aug 03, 2011 | Plantronics 510 Voyager Headset - PLN-510...
While the headset works frequently, it will suddenly stop. Nothing I do will allow it to connect again. I hear nothing through the headset after the initial beep that indicates headset mode was enabled. ...
It sounds like the battery is no longer holding a good charge. There is no replacement battery for this headset. If you are using the original 510 headset you can replace it or pair a different bluetooth headset up to the 500A base. Just keep in mind if you decide on a different style of headset you will not be able to charge it in your base. I have included the link for the 510 replacement headset below.
Plantronics Voyager 510 Replacement Headset
Jul 14, 2011 | Plantronics Voyager 500A Deskphone Adapter...
How do I put it into discovery mode, so that my laptop will find it?
Most blue tooth manufactures use holding the power on for 6 to 10 seconds when turning on your bt device to put it in discovery mode i hope this helps
Feb 20, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics 510
maybe that is why this product is discontinued
Mar 31, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics Voyager 510 & Blackberry Curve
 Plantronics Support Phone Number: 1-800-544-4660
Do not use the power button to sync.
To sync device, Press + button (volume) and Silver button (on boom) at simultaneously. LED Light will blink RED & BLUE.  Device ID should appear on your screen.
Jan 14, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Mic does not work on new 510 headset
sounds like a defective unit the mic doesnt mute
Dec 29, 2007 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics 510 Voyager Headset - PLN-510 Headset Logo
251 people viewed this question
Top Plantronics Radio Communications Experts
Ed Nelson
Ed Nelson
waldofrog
Level 1 Expert
sonic boom...
sonic boom...
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
