Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Changing belt how do you change the belt on the power steamer there is nothing on bissells webiste i need to change the one on the sie not the rollers
  • moose7777 Sep 02, 2008
    putting the brush back the two plaste pieces on the side of brush hoe to snap in place
  • 65 Answers
Take the water and solution tank out of the machine. turn it over an on the left hand side you will see a red clip with a screw in it. take out that screw. flip the unit back over and take off the belt access cover by sticking a straight screw driver down into the slots and popping the clips to release the cover. tilt the machine to the side and using your finger wiggle the red plastic piece down out of the way. the beater bar on that side should be free. make sure both belts are in good shape because the belts run the beater bar and the second belt runs the water pump.
Posted on Dec 02, 2008
Bissell power steamer brushes will not turn
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller is not turning. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jun 25, 2016 | Bissell Power Steamer Shaft w/ Head Hose
How can determine when it's time to replace the drive belt on my Bissel Power Steamer? Is there a certain number of hours of usage that I need to keep track of or does the belt replacement depend on the...
Usually, replacement is needed when the brush no longer runs or is intermittent. Check the brush bearings and for debris build-up whenever the belt is changed. Good luck!
Jun 12, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
HOW DO I CHANGE THE BELTS ON A BISSELL STEAM CLEANER
on your housing you will see a plastic cover adout 4 inches long remove this piece and you should see where your pump belt goes. flip your steamer over and remove the little red retainer that sits by the belt you have located. at this point you can take your brushroll out and slip the pump belt over the pump and onto your motor. then reassemble.
Sep 08, 2008 | Bissell 1699 ProHeat Clear View Upright...
Roller and belt changing need schematics
How to change the belt on the Bissell Clearview?
Sep 02, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
118 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
