Question about Kenmore 73952 Gas Dryer
74842400 TAKES 2 HOURS TO DRY NORMALLY 50 MIN
    Genius:
  • 1,028 Answers
Ck air flow out back of dryer then reconnect and ck to outside probably blocked somewhere
Posted on Jun 06, 2008
How long does it take in a full cycle of wash to dry
Depends on several things. How big the drum is eg 6 kg or 7kg .the spin speed... The material ie. cotton drys faster than woollen items.is it a washer dryer or do you have a separate dryer.normal full load 6kg on a 1200 rpm spin of mixed fibres takes 1 hours 30 mins at 40 c then the dry time can take roughly 1 hour to 90 mins.
Dec 23, 2014 | Washing Machines
Taking to long to dry clothes
How long does it take you to dry your clothes? Normally, it takes 50 minutes (1 cycle) to 1.5 hours to completely dry clothes. However, if it's taking you at least 3 cycles (probably 2.5 to 3 hours) to dry a single batch of clothes, then, there might be a problem with your dryer's igniter.
Jan 09, 2014 | Speed Queen AGS17AWF Gas Dryer
Samsung DV218 AEW works fine in time dry but not in normal dry. Jumps from 50 min to 1 and shuts off.
Sounds like you have a bad controller./timer. It i fairly easy to replace if you want to. I would turn timer to max time and know that it will stop at 50 minutes.
Mar 11, 2013 | Samsung DV218AEW Electric Dryer
Dishwasher takes hours to run through wash and dry cycle. what should normal cycle time be?
2 to 6 hours is possible. The newer machines have a water heat cycle that will raise the water temperature. lets say your incoming water is 90 degrees. The machine want to see 140 -165 depending on the cycle so that cycle will take 75 minutes to reach 165 (1 min per degree temp rise). multiply that by the number of wash and rinse cycles and it can run a very long time. Water should enter the washer at 120 degrees minimum. let it fill and measure the temp you will be surprised. Eric
Sep 13, 2009 | Kenmore Dishwashers
My dryer seems to be hot, however it takes forever to dry a load. Is 3 -4 hours normal to dry towels?
Your heater coil has burned into 2 parts. Find a friend WHO IS KNOWLEGABLE about dryers, Call a repair man or find a good used dryer. I understand this isn't what you wanted to hear, but this involves lint and 220 voltage. NOT to be taken lightly. The coil will cost around $50 and the repair men will be a minium of $75; Look in the paper and buy another one....
Aug 25, 2009 | Dryers
Back & top of dryer get hot, clothes take long time to dry.
First thing to check for is blocked airflow. Check the dryer as well as the venting from the back of the dryer to the outside of the house good airflow is neccessary. You could remove the venting from the back of the dryer and run a load to see if that helps. Do not leave it off as it is exhausting lint and if a gas dryer spent fuel.
Jan 08, 2009 | Maytag MDE2600 Electric Dryer
Whirpool Dryer......
GAS or Elect. does not make a diffrence 95% of drying too long problems are from a clogged vent try to run a normal load with the vent off the the back letting the hot air into the house if it drys normal then you need to clean out the venting going to the outside If you are worried about the lint blowing inside you can put an old pantiehose over the vent to catch the lint dust
Jan 21, 2008 | Whirlpool GGQ8831L Gas Dryer
Kenmore 73952 Gas Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
