Question about Kitchen Ranges
How to turn down pilot light in Crosley Model C31100SA gas oven?
Our pilot light is too high, how do we turn it down? Any help appreciated.
    Genius:
  • 1,554 Answers
Must be an old stove,
there should be a small screw below the pilot thermocouple
in some cases they are behind the center knob
Posted on Jun 04, 2008
There is gas to the burners on my old Hardwick range, but not to the oven.
perhaps you need to call someone to have the gas line cleaned going to the oven .have heard that spider webs can stop gas flow .it doesn't take much
Jul 22, 2014 | Maytag Crosley Hardwick Caloric Kenmore 8"...
Pilot lights will not stay lit on stove top or oven. Can light burners with match. Crosley c3100paw
You need to clean thermocoupling off it what the pilot lit uses to stay lit. you canuse sand paper or brush May need to replace, clean gas tubes on pilot also could be that
Dec 12, 2011 | Crosley Kitchen Ranges
When i turn on oven all i smell is gas i cleaned with a wire brush still nothing. also is the pilot light always have to be on and can you see it when oven is off
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
Jul 17, 2011 | Ovens
I have an early 70's Magic Chef series VI oven/stove. The stove works fine. The oven takes about 30 minutes to light. When oven knob is turned pilot works fine. There is no gas odor before the oven lights.
My model is a UA119A-2W and I cannot find a place to light the oven pilot. Nor can I find a copy of the owner's manual anywhere online. Any suggestions would be appreciated.
Apr 05, 2010 | Magic Chef 31000 Gas Kitchen Range
How do you start the oven on a Hardwick propane range?
The bottom part of the stove in the front has a drawer you pull out which has a broiler tray located there. You should be able to fold the door down and use a flash light to look inside . You will find a pilot light set-up there.
The stove I have has the pilot gas on all the time, so as soon as you turn on the gas to the range, the pilot gas is open to atmosphere.
I just light a match and reach in to where the gas piping can be seen and the pilot flame will light.
There is only a small amount of gas coming from the pilot orifice, so there isn't any danger lighting it when the gas is first turned on at the tank.
In fact you may have to wait a few minutes for it to light at first because the propane line maybe full of air. I usually light the top burners of the stove first and by that time the pilot gas for the oven is ok to light.
Jan 05, 2010 | Kitchen Ranges
Oven gas turns off
If your Wolf has pilot light, most cases dirty pilot light (flame looks yellow, normal flame looks blue), you have to disassemble the pilot light to clean it, thermocouple connection is loose, bad thermocouple or bad oven safety valve. you can try change the thermocouple first, if it did not solve the problem, then it will be bad oven safety valve. You can buy thermocouple thru Hardware store. Have fun.
Dec 17, 2008 | Wolf Range CHR-10-229-FT11 Kitchen Range
Gas oven dosnt work
the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
Dec 14, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Crosley gas oven will not heat up
That's my mom!!! Go Sheila!!! Hehe.. -RET-
Aug 08, 2007 | Maytag CWG3100A Gas Single Oven
Kitchen Ranges Logo
654 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
