Question about Philips Magnavox 27MS343S 27" TV
Magnavox: 37MF231D/331D/321D Haven't even had this TV for 2 yrs. When it gets turned off it will not turn back on. Keeps turning itself off. In the past have been able to play with for an hour or so to get it back on but now will not come back on. Green blinks for a while then goes off.
  • 8 more comments
  • whip480vac Jul 05, 2008
    Like Kellijack our magnavox: 37MF231D/331D/321D suffers from the same problem. When the set is turned off and left off for a long period of time we press the power on button and wait while the green power light flickers and acts as if the tv is looking for a signal and finally the light goes out. We then hit the power on button again and the period of time that the green light flickers is only 5 to 10 seconds as conpared to the initial power on flicker being upwards of 10 minutes. After the third or fourth time pressing the power on button the tv comes on and plays just fine. If we turn the TV off and then back on it comes on without problem. The problem only seems to occur when the TV is left off for extended periods of time.
  • Anonymous Jul 08, 2008
    Exact same issue...takes minimum 3 hits of power button to keep green light on and start playing. TV less than 18 months old. Seems to be a flaw in this model, maybe others too.
  • cindyechols Jul 13, 2008
    I have the same problem of the TV shutting off about 2 seconds after being turned on .
  • Todd Johnson Nov 02, 2008
    I have a 37MF231D same problem. needing to turn it on and off at least 4 times before it comes on
  • Anonymous Feb 03, 2009
    I have the same problem - if the tv is turned off for a long period of time it takes a couple presses of the button before the green light stays on and the tv turns on.
  • mvscag Feb 21, 2009
    Well folks, I hate to break it to you, but that's just the beginning...pretty soon it will take 45 minutes to an hour to turn on...then it won't turn on at all...not sure what to do, except use any and all Magnavox items as kindling!!!! Just another terribly unreliable product I feel suckered into buying!!!! Good Luck!
  • brianandjill Mar 21, 2009
    Typical junk from China and no customer support, or service solutions, except find and replace the bad capacitor on the power supply board. What cap and which board is it? Bought the tv August 06 and of course the extra warranty, so it takes a dump 6 months after it expires. $1700 bucks and now it's junk? Hate to say it guys but this is the way China makes money with dumb Americans like us. Buy it cheap every two years instead of once every 10 for a few bucks more. I see thousands of posts stating the same problem with power up on the 37 inch tv's yet Philips wont acknowledge the massive problem or help the service center guys by not sending the $4 part! BTW, the repair is $300 plus.
  • dcmm115 Mar 26, 2009
    Same thing, and as time goes on the warm up time gets longer-we are up to 35 minutes.
    Very frustrating!
  • woodallthoma Apr 17, 2009
    Guys, same problem here. Mine is about 18 mos old. Occasionally, I get nothing. Have to unplug and replug until the green light will do anything. Then, if I'm lucky, the screen flashes on and off. Eventually, after I am ready to throw the thing in the trash, it starts working and performs flawlessly until the next time I turn it off. For me, doesn't matter if it's off for a long period of time or not, it still struggles to turn on. I hate the thing and will never buy Magnavox again. My fault for trying to save a buck.
  • d_tisdal May 01, 2009
    I have the same problem! Lucky for me it just started to manifest itself last week. Turn it off and it takes forever to turn back on! Would it be worth the hassle and expense to pay $300 plus to get it fixed? It has a beautiful picture when it's working. How about the idea of leaving this thing on 2-4-7 until it finally quits? Thanks Magnavox...thats the last buck you'll get from me!
  • Philips Master
  • 1,213 Answers
Calm down Calm down. The problem is quite simple. You need to change one maybe two capacitors. Upon removing back cover. Look to the left, after removing foil tape, remove screws and flipover the board. The first cap to go down may have abulge on top or black tar oozing out the top. It is a 25volt 2200mf cap gone bad. Replace it. Second, sometimes and just sometimes next to thatone is 35volt 1200mf cap goes bad......remember just sometimes. You may have to replace it as well.
Posted on Jun 30, 2009
  • matt martin
    matt martin Jun 30, 2009
    Let me remind you. If you do decide to repair and replace your capacitor or capacitors use the 105 degree temperture cap. They are great under a load and most important be sure the polarity is correct before installing. Long lead is positive the short lead is negative. Get some popcorn and a bottle of pop and enjoy the movie.!!!!!!!!!!!!!
  • Rebekah Kaminski
    Rebekah Kaminski Nov 02, 2010
    I have no idea what you are talking about and I wish I did because this is driving me crazy on my TV. What does a capacitor look like? What tools would I need? Where do I get a capacitor?
I just went and bought 2 1000mf 35v caps to replace the 2 that were bulging next to the 2200mf 25v that had popped it's top, oozing the black ****. I went everywhere looking for the replacement. I couldn't find one so I went up to a 3300mf 35v. (never go lower... EVER).
I just buttoned the set up, plugged in everything and Im back in business!!!!
WOOT!!!!!
SOLUTION #2 was the ticket and saved me God knows how much money. The cost to fix my set using solution #2 was $5.28 including tax.
Thank you!
Posted on Dec 17, 2009
I've had this LCD panel for over two years and fortunately have not had any trouble, but I found a software / firmware update on Magnavox's web site and upgraded using that. This is something new to many people, since the old style CRT TVs did not require this. You can use a USB flash drive to perform the update.
Also make sure all lines (Cable, Power) are protected with a high-end surge protector.
Posted on Jun 13, 2009
Replaced the 2074 with 35v 2200uf and the tv is back it is only 4.49 from radio shack while the tv repair shop wants $180.00 + $60.00 inspection fee.
Posted on May 20, 2010
Solution #2 worked for me on my power supply, the only capacitor that I had to replace was the 25 v 2200mf one. It was obvious because the top of it was separated open with black showing.
The capacitors have a thick soild line on the - negative teminal side. Thanks maatmartin7 for the fix.
Posted on Dec 01, 2009
    Problem Solver:
Want to sell your broken-as-is 37mf231d to me? call or text 9797092849 ill pay for shipping as well
Posted on Dec 08, 2009
On my Magnavox 37mf231d tv when I turn it on, the backlights turn on for about 3-4 seconds, then turns off. There is no blinking green light, there is no green light at all. It seems like it is trying
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Aug 23, 2014 | Toymax Magnavox 37MF231D 37 in. LCD TV
Per magnavox 37mf231d I switched tcon board, and put an older main board that I had laying around, now the tv tries to turn on, there is a background light for about 5 seconds and then it shuts off.
Hello, I think it either had a bad back light board or one of the florescent tubes in the display has gone bad. As these sets get older, I see more of the florescent tubes going bad. I think there are 9 in that set, and all it takes is one of them to go out to cause the set to shut down. You may also look for a bad connection on the transformers on the back light board.....thanks, let me know
Aug 07, 2014 | Toymax Magnavox 37MF231D 37 in. LCD TV
Magnavox 37mf231d will not turn on, only have steady flashing led light-continuous
I just fixed mine that had a very similar symptom to this and it was a bad part on the main board. I made a video showing what part and how to replace it. I also added a link below to the part I ordered. L5973D STMicroelectronics Mouser
Magnavox 37" model 37mf231d-37 wont tun on when i hit power button the screen lights up for a secongd and turns right back to black and the power button green light comes on and right back off I found
Your power supply is weak. If you think you can repair this I will tell you how. If you cannot do this,find someone who works electronics and share this repair. Two capacitors are bad. When pulling the back cover off, you may see one or two capacitors bulged. Even if they look good....replace these capacitors. The locations are numbered and, the capacitor having a value and temperature of 105 degrees.. Location of the first capacitor is 2074, value 25volts @ 2200 mf @ 105 degrees and will most certainly be bulged. The next capacitor may look fine....replace it. That capacitor location is 2066, value is 35 volts @ 1200mf @ 105 degrees. When you replace these, please be sure to get the polarity (positive leg and negative leg) of these capacitors seated correctly...this is a must. This will correct your TV. You will save lots of money, because you asked. Thanks for listening ..good luck...we will be here for your next repair.
Jan 02, 2013 | Toymax Magnavox 37MF231D 37 in. LCD TV
Magnavox 37MF231D/331D LCD Troubleshooting Tips
Google for this repair help site "Electro-help" It have all details
Jun 13, 2012 | Philips Magnavox 27MS343S 27" TV
Magnavox lcd tv not turning on
Also changed swollen C2074 and C2081 and it now works perfectly! a bit daunting for a novice like myself but with a steady hand and decent 'put it back the way you took it apart' skills, all went well!
Mar 22, 2009 | Toymax Magnavox 37MF231D 37 in. LCD TV
37mf231d power light flashes on and off will turn on after you keep trying
set the time on your tv and turn off the timer, sleep and wake funtions.
Jun 26, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox # 37MF231D
that depends on the value of the television and the cost of replacing the power supply and connections.
Most likely you have a short in your power supply or other connections causing the tv to protect itself by shutting down. You can check with our Repair Service lookup icon for a repair service near you.
Before you call them you may try unplugging your unit for 30 minutes or so and plugging it back in.
Clock setup in new TV.
Dear Customer,
Yes you can ,
but you have to do installed some cicuites & programmed chips that startes up you showing times & dates as you strtes up your TV
THNX
May 18, 2008 | Televison & Video
Philips Magnavox 27MS343S 27" TV Logo
3,133 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
