Nec tv codes for comcast universal temote
Trying to program nec tv with comcast universal reomte tries all codes and code search nothing workin any codes available other than ones in comcast user manual
unsivilaudio
  • 25 Answers
SOURCE: Need remote code for Bresnan Cable 5-1 remote for Sharp 32" LCD
Apparently I didn't read the directions for code search closely enough (as it does work for my tv). So I will post them here, just to be sure people don't make the same mistake I did.
With the Device on;
1) Press "TV" on the remote control
2) Press and Hold the "Setup" button until the light blinks twice
3) Enter "9" "9" "1" to enter code search mode on the remote
4) Press the the "CH+" slowly until your TV turns off (if you accidently go to far your can press "CH-" to go back a code or two)
5) Press the "Setup" key to lock in the code, the light should blink twice if done correctly
Your device is now programmed, enjoy!
Posted on Dec 31, 2008
SOURCE: Need Comcast Remote Code for Samsung LN32A330 TV
I contacted Comcast and here are your codes for the three way remote with DVR Samsung 10812, 10766, 10814. I have the same TV Samsung LN32A330 and it was the very first code for my TV! Hope this cuts down your frustration!
Posted on Feb 04, 2009
SOURCE: comcast remote code for 42in sharp aquos lcd
I had the same problem... and was lucky enough to stumble upon this. Here is the screenshot.
Posted on Feb 11, 2009
  • 3 Answers
SOURCE: I need the dynex tv code for a comcast remote control
Try 10463, or the Emerson tv code.
Posted on Apr 09, 2009
SOURCE: Universal Remote Codes
I just programmed my comcast remote today and the codes in the manual work fine. I was lucky, the first one as the one I needed. Good luck.
11454, 10054, 10030, 10706, 10187, 10386,10802,11198,11254,11963,11990.
Posted on Jun 06, 2009
Code for programming to a LG 4K tv?
  1. LG UHD 4K Television - LG.com‎
    Adwww.lg.com/UltraHD4KTVRatings:Reliability 9.5/10 - Picture quality 9.5/10 - Features 9.5/10
Search Results
    Find Your Comcast Remote Control Programming Code
    customer.xfinity.com/...tv/finding-your-remote-control-programming-co...
    Learn Comcast remote codes and more information on how to program your remote control. ... To Watch On Demand Programming with XFINITY TV:.
    DIRECTV - Remote Control Code Lookup
Jan 01, 2016 | LG Televison & Video
What is the universal remote code for viano tv?
Use code search on your One For All remote control to find something that works. If a search through all codes stored in the remote control fails, you may have to try a different universal remote control. all universal remote controls do not contain all possible codes.
May 05, 2014 | Televison & Video
AKAI 27"LCD SN:60683669 Have HDMI connect o
Universal remote controls (like the one for your comcast cable box in which it allows you to control other devices) have "the most popular" IR codes programmed inside of it. When you type in the numbers "10812,10702, etc" you are telling the remote to use that particular IR code within its "database"
The key thing to know is that universal remotes do not have every code, just the most popular. If you have tried all of the codes listed in the manual for you model TV there's not much you can do.
  • Try searching for a code. Some brand names, such as "Akai" may have other manufacturers parts inside of it, Searching usually is done by going through certain key-presses on the remote to try all of the codes available.
  • Buy another Universal remote, not all remotes are created equal as some have mode IR codes built in than others, if you have an odd brand TV, it may be more difficult to come across one that works.
  • Buy a learning universal remote, although usually more expensive these remotes will allow you to "learn" the IR codes from your old remote to the universal remote.
I hope this helps.
Mar 06, 2011 | Akai LCT2721AD 27 in. LCD Television
Can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
Oct 02, 2009 | Hannspree HT09 28 in. LCD TV
Comcast remote cannot operate Funai/Sylvania LC225SSX tv. Tried all codes, even for all televisions made by Funai. Code search did not work. Comcast tech could not get Comcast remote to work on the Funai...
Currently there are no remotes nor any codes for them that will operate virtually any sylvania tv's. sorry, it's like the only model we have no resource for as of yet. -Comcast Tech
Jul 31, 2009 | Sylvania LC-225SL9 22 in. LCD TV
Akai Reomte has stopped working, Universal Remotes will not
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Jun 25, 2009 | Akai LCT3201TD 32 in. LCD Television
Comcast remote code for 42in sharp aquos lcd
Jan 10, 2009 | Sharp LC46SB54U 46 in. LCD TV
Comcst remote control code not working
look on the label on the back of your Emerson TV. Read the small print and see if there is a possible different manufacturer that actually made the Emerson TV. Just because it says emerson doesn't mean emerson made it. Also if no luck there try the UL listing code and search that code to the UL listing website. That may help also.
C-Dog
Feb 12, 2008 | Emerson EWF2703 27" TV
I need a Universal Remote code for this model.
I got it to work with code 12002. I have the Comcast DVR Remote.
Dec 04, 2006 | RCA 20F510TD 20 in. TV/DVD Combo
comcast dvr3 remote code for jensen sc2050j is 0150 gil_hodges@bellsouth.net
Jul 27, 2006 | Jensen TS2050J 20" TV
Televison & Video Logo
411 people viewed this question
Top Televison & Video Experts
Electro Med Services...
