Question about Bosch WFMC 3200 Front Load Washer
E:4 Not draining completely.
Clothes are wet  E:4 message. The drain is not blocked going into the drain tube. Is there another spot to,check under or in back of washer?
    Genius:
  • 1,554 Answers
Open the bottom access panel . 3 screws on bottom
in the center is the large filter access
be ready for some spillage
clean and check the pump impellers for easy turning .
Posted on Jun 04, 2008
Amana front load washer has wet clothes after the complete wash cycle finishes
From the information you have supplied, I suspect that the machine is not draining the water away,
1] Check that the drain pump is working (it would be easier to hear it running, before the machine starts the spin cycle, or if your machine has a "drain down" feature)
2] If the pump is running, stop the machine and unplug it from the mains power. Remove the machine drain tube from the point where it is plumbed into the household waste pipe, and lay it down into a bucket, or large pan and allow the water to drain down [ you should expect to get up to 2 gallons (10 Litres) of water from the machine]
Allow the water to drain down completely by holding the drain hose as low as possible into the bucket.
3] once the water has drained completely, remove the drain hose from the pump and check that the drain hose is not blocked.
4] If the hose was clear, and the pump was running (in tests [1] & [2] ), it will be necessary to check that the drain pump, and the main hose from the tub to the pump are clear of obstructions.
Remove any foreign objects, and re-assemble the hoses to the pump to the machine, and the drain hose to the domestic plumbing.
Plug the machine into the mains power, and and set the machine to run on the "last rinse" and "spin" cycles and test to see if the problem has been rectified.
I hope this helps cure your problem.
Oct 13, 2016 | Amana Washing Machines
My Samsung Model#WA5451ANW/XAA washer keeps repeating the rinse and spin cycle over and over and my clothes are still wet because spin cycle is not spinning clothes fast enough.
Oct 13, 2016 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
Clean out sunroof drain tubes
Drop the head liner & see if all the drain tubes are in place
Then blow them out with your air hose,assuming you own a compressor,if not, your not going to be doing much in the way
of vehicle or home repairs
Check the bottom of all the doors for a clogged drain holes
Lift up the carpet & put a couple blocks of wood under them for
a few months to dry it out
Sep 21, 2014 | 2005 Chrysler 300
Lsw9750pw3 clothes still wet
If there is water remaining after the drain then the drain pump must be checked. Also check the TILT of the washer and must be inclined to the drain side.
If the clothes are wet then the SPIN RPM is insufficient or the program cycle time is not adequate. Please try with another cycle or check the motor, belt, capacitor as the RPM is low.
Jun 28, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
My Roper washer spins, but does not drain completely. Clothes are still very wet. Help please!!!!!
Not draining completely can only mean that the drain hose is (partially) blocked or kinked. Or that the pump is blocked or faulty. Front load machines should have a small door near floor level to allow you tp unscrew the filter 'plug' and inspect. Check for coins in the impeller. ...Good luck....Nomess
Apr 20, 2010 | Washing Machines
My washer won't complete the final spin cycle. It goes through the wash and drain OK but won't spin, clothes are soaking wet. I removed the drain pipe and made sure it was not blocked, also removed and...
Hello, problem here is the spin control board is bad. Remove panel under the door and you can locate the spin control at the rear right of the machine screwed to the floor. Replace it and you will be all set. Mike
Nov 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Wet spot on passenger floor board and its not antifreeze could it be condensate
sounds like it check the a/c fluid drain for any restriction, or leaks
Oct 07, 2009 | 2002 Pontiac Grand Am
What would cause the carpet under the passenger seat to be sopping wet in a 2007 Dodge Stratus?
Either your drain tube is clogged, or you have a leak in your evaporator housing. More probably it is the drain. Take a hanger and crawl up under the pass side of the car. Be sure to put your parking brake on and block your tires. Look for a rubber tube coming out of the firewall ant the back of the engine compartment on the pass side. push the hanger up into the hole. if you have an air hose, use air pressure, but don't blast it, use a light stream of air.
Aug 16, 2009 | 2006 Dodge Stratus
Leaves clothes very wet and soapy
Your pump is clogged. This stops the machine from spinning out or rinsing. You have to locate the thing, (comes under the tub, lower end of big black tube) take the clamps out to clear the muck. Refit as you have dismantled. First try to drain out the water completely or you will flood your room.
Mar 02, 2009 | Maytag Performa PAV3200
Water in floor
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Mar 26, 2008 | Refrigerators
Bosch WFMC 3200 Front Load Washer Logo
89 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
