Question about JVC Car Audio & Video
When i plug my JVC radio, the speakers dosen't work, after that i plugged my original radio my speakers work what'S the problem
  • 70 Answers
Maybe some of the terminals are messed up
Posted on Jun 12, 2008
Radio pro 4 wiring
You should purchase a radio harness for your car, and it's wires will connect to wires of the same color from your JVC radio harness. Join the two harnesses together (solder, crimp caps, barrel connectors, etc.) and then one end plugs into your JVC, the other end plugs into the factory harness that the original radio was connected to. If for some reason, your factory harness plug has been cut, you'll have to hardwire the JVC harness. I've included a link to the wiring diagram for your car. The steering wheel controls are moot; they will not work unless you've got some aftermarket adapter that allows them to interface with the JVC radio.
2004 pontiac grand prix speaker wiring diagram Google Search
Nov 13, 2017 | Car Audio & Video
After Market Radio Installation
Hey man, you have an amplified system. use a 70-1858 wiring harness and jump the blue/white wire from the aftermarket radio to the pink wire on the second plug. this will power on the factory amp with the aftermarket radio.
Chris-
May 04, 2013 | 2000 GMC Yukon XL
I'm attempting to install a pioneer stereo into my son's 74 Chevy pickup.
it plugs in to the the plugs you unpluged from the original radio if there are no plugs then your going to have to wire it all up from scratch new power wires new speaker wires and just alot of work so I hope you didn't cut the plug off the old radio
Mar 21, 2013 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
I have a jvc kd-s27 i am very familliar with hooking up stereos,i have tripple checked everything and i am still getting no sound from the speakers i can plug in the original stereo and sound works...
Its because u probably u have factor amps like my car that has infinity sound system I used the wire harness adapter that plugs into the factory harness u need to plug the wire that is alone and not in the factory plug into the power antenna/remote wire sould fix that issue
Feb 18, 2011 | Car Audio & Video
Hi im putting in a JVC cd/radio in a 1997 ford escort TD,Ive removed factory fitted Ford radio cassette,leaving 5 wires connected to a yellow plug,I have 3 wires coming out of JVC marked yellow memory back...
hi...well i know this might not be of any help, but you can buy a connector that plugs straight into the ford plug, and then you plug the jvc plug/s into that, not cutting wires no messing up the original connector just incase you want to sell the car with original system in it... http://productfinder.autoleads.co.uk/productinfo.aspx?&m=FORD&f=ESCORT&id=463&pID=6889
thats the link for it...if you tell me what colours are on the ford plug i could tell you what goes where...thanks
Feb 04, 2011 | 1995 Ford Escort
2003 E250 Would like to replace original basic stereo radio (only two speakers in front doors at present) with JVC radio (that can connect to 4 speakers). Need radio removal directions and type of speaker...
There are 2 holes on each side of the face of the factory radio. Special U-shaped rods slide into the holes to unlock the clips and pull it out. You can buy them from a parts store for a few bucks or use a metal coat hanger and make them yourself (all they do is push straight in the holes). To install a (JVC) radio, you can buy an adapter plug from a car stereo shop or best-buy that connects to the factory harness.
Jan 25, 2011 | 2003 Ford E250
I have a 92 ford probe and im trying to install a
Have you removed the original connector from you original stereo? If you still have the original connector in place you can get a new connector from the Ford dealer that will plug into your existing wiring and into your new deck. Ford connections are unique to Ford and you need to adapt them for this application.
Take the car and deck to the dealer and tell them what you need. Everything just plugs in and your original amp and speakers in the car will work.
Having said that there was an adapter available at Wal Mart of all places that did work. You may want to check there.
If you have removed the original connector then you need a wiring diagram.
1992 Ford Probe Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Red
Radio Switched 12V+ Wire: Blue/White
Radio Ground Wire: Chassis
Radio Illumination Wire: Light Green/Black
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: White
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Orange
Left Front Speaker Wire (-): Blue/Black
Right Front Speaker Wire (+): Blue
Right Front Speaker Wire (-): Blue/Green
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Green/Orange
Left Rear Speaker Wire (-): Green/Red
Right Rear Speaker Wire (+): Green/Blue
Right Rear Speaker Wire (-): Green
The amp is located under the rear passenger side window. You need to remove the plastic side wall to expose it if you need access there. You can trace the wiring if needed.
Under the front bottom edge of the rear seat are clips holding the seat in place. Open the clips and the seat lifts off. You can then get to the amp as needed.
Mar 12, 2010 | 1992 Ford Probe
What color is what when installing a car stereo in a 91 Grand Marquis?
you can go to your nearst car audio shop and buy a harness that will plug into your factory plug, which will allow you to wire directly into it with your aftermarket radio harness which is color coded to match. the reason i recommend this is b/c some of the marquis are factory amplified. although i have included some wiring info for your car, be sure to test all wires with a digital meter first.
Battery BLUE/YELLOW (+) RADIO HARNESS Accesory GRAY (+) RADIO HARNESS Ground BROWN (-) RADIO HARNESS Illumination GREEN (+) RADIO HARNESS Power Antenna BLACK/RED (+) RADIO HARNESS LF Speaker (+) PINK LF Speaker (-) VIOLET RF Speaker (+) LIGHT GREEN RF Speaker (-) BLUE LR Speaker (+) BLACK LR Speaker (-) YELLOW RR Speaker (+) RED RR Speaker (-) WHITE
Sep 15, 2009 | JVC AM FM CD DET FACE CAR STEREO
Sound/Ground problem
bad connection in one of the speaker wire.
Apr 02, 2009 | JVC AM FM CD DET FACE CAR STEREO
Cant get jvc car stereo to work a sony cd changer
Does your sony cd changer have a separate controller and rf modulator interface? It's a wire from the cd changer with a little box close to the end and an antenna plug at the tip? If you do just plug it into the back of your radio where the antenna goes in, then plug the car antenna jack into the other side of the little box and turn your radio to the marked setting on the box. IF NOT , you can not interface the din plug from a sony into a jvc radio because the sony radio that has a md controller built in will control all of the functions of the matching cd change.
I hope this helps...
Oct 15, 2008 | JVC Car Audio & Video
Car Audio & Video Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
