Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Ws65613 recently got a new sat rec and was running with dvi connections to tv. after about 2 months now, suddenly picture goes out and in. tried different inputs picture fine on svideo, component with sat rec and other inputs- fine pic, but on dvi input off and on pic. heard from very reliable repairman that might be software upgrade might be available from Mits? anyone else seeing this? thanks,
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
How much you pay for the solution?? login and find out!
Posted on Jun 12, 2008
I have no sound on DVI
dvi does not support audio extra audio connection required
Jan 07, 2010 | Televison & Video
Recently my TV2 connection has become an issue: I get the Press Select to watch TV on the screen, but the remote will not work. (This is a UHF remote) I've even replaced the remote - and yes it's a Dish...
Check your UHF antanae on the back of the reciver to make sure it is standing straight up. you can also see if the tv 2 remote works at the tv 1 location to check for interference. if you have a dvr check to make sure shared view is disabled by pressing menu option 6 then option 2 and the disable. if this option is greyed out, put your reciever into single mode by pressing the mode button and try again. if none of this works, If your tv 2 remote still does not work at tv 1 ( ie: changes chan at tv 2 location at rec but not at tv 2. then readdress your remote by pressing menu, opt 6, opt 1 and opt 3, this will be system info. do this at tv 1 location, then with tv 2 rem in hand, press the sat key till all buttons light up at top, then release, enter any number 1-15 that is different from rem 1 add. then press pound. then press record 3 times to see if number changes for rem add. 2. if not then you have a defective rec. call 1-800-333-3474 for technical assistance.
Nov 10, 2009 | DISH Network IR Remote Control
LG32LZ55 TV GOING INTO DPM MODE
Hi Ben,
Did you ever resolve? I have the same issue.
Jun 18, 2009 | LG Televison & Video
Picture and sound go out and remote isn't working properly
Take the original Mitsubishi remote and remove the batteries. Install new fresh batteries and then try to operate the set. Do not try to use any of the inputs that are active. Just check menu funtions with the mits remote. All kinda irrational stuff happens when multiple and universal remotes get involved. If this a model remote that has a selector switch at the top for choosing tv/sat/vcr, etc make sure it's on tv.
May 28, 2009 | Mitsubishi WS-55515 55" Rear Projection...
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
Samsung hlr4667 dlp \ no hdmi connectivity
No, when I bought my new plazma tv, and unhooked my old DVR box, I had to go to my cable provider and inform them. they sent a signal and WHAM I was back in Biz.
Nov 10, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
No sound
A DVI cable does not have an audio connection, along with the DVI you still have to run an audio line from the device (DVD player, cable box, satellite receiver) to the TV. HDMI contains both audio and video.
Sep 30, 2008 | Hitachi 57F500 57" Rear Projection...
Hdmi and dvi
No sir, there is not such switch in menu to change input from S video to HDMI or something. Here is one suggestion, Use 3 RCA pins cable (Audio L/R & Video) to connect both unit and check/ remember TV input and same should be selected in TV menu.
Jul 29, 2008 | Hitachi 51F500 51" Rear Projection...
HDMI to DVI cable connection picture problem
You are Just trusting on Monster Cable, thats what your doing wrong. HDMI and DVI are not same formates.
Poor picture quality and sound problems on Lite-on LVW 5115GHC
have you tryed replaceing scart leads plus check if there in a priority order 2 like going form dvd 2 tv then tv 2 sat recever try going via sat recever then dvd then you tv if that dose not seem 2 solve you problen it might seen you might have dry solder point inside you dvd unit if so take bk where you buy it from and explane to then wat is happening hope helped
Aug 05, 2007 | Lite On LVW-5115GHC+ DVD Recorder
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
43 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
