Question about Acer Aspire 5315 Notebook
Cd/dvd drive problem
Inserted blank disc and drive will not recognize actual disc in drive after burning a few already. Laptop brand new! Device manager says everything working properly. Help! Trying to backup files before extended use.
  • Jim Walker May 11, 2010
    Is the drive letter showing up in My Computer?
Have an acer aspire 5315 and the hard drice crashed. hard drive was replaced but need to locate recovery disk to reload the system.
Posted on Dec 27, 2008
    Problem Solver:
  • 13 Answers
It's the **** drive acer installs...
use SONY disks and the problems go away
Posted on Jul 12, 2008
Try with another brand of disk; the Matsushita UJ870 drive of our 5315 burn my Sony CD's but not my Philips CD's (my Compaq V2617LA with an older Matsushita UJ840 drive has burned Phillips CD's in the last two monts)... Remember: CD and DVD lassers are different. I think because of that, i haven't see problems with Sony, Philips and Samsung DVD's... only with CD's...
Posted on Jul 07, 2008
DVD drive read/burn problem
From the description the new DVD driver is defective and should be returned if still under warranty. The only concern that I have is the replacement you got is identical to the original and that it is not a aftermarket product, because they don't have the same specifications as the original.
Apr 05, 2012 | Lenovo 3000 Y410 Laptop
The laptop burned a disc, then ejected as usual. Another disc was place in the tray, inserted as normal but this time a cd was unable to be burned because the laptop did not recognize the disc or any other...
The automatic ejection takes place when the burn process has completed successfully. Have your tried another writable CD or DVD? If your laptop is not recognizing any more writable CDs/DVDs, then the problem might be a failed CD/DVD drive. Otherwise, it is probably a bad CD or DVD.
Hope this helps.
May 26, 2011 | Computers & Internet
Will not recognize a blank cd or dvd inserted into the e drive. will read a data disc inserted into the same drive.
Hello
Are you using windows media player or roxio or any burning software?
You will need burning software for blank disc to be recognized.
Hope this helps.
Jan 23, 2010 | HP Pavilion a1210n (ED895AA) PC Desktop
Dvd drive not recognizing blank disc
Follow the filter fix steps in the Microsoft knowledge base article below.
http://support.microsoft.com/default.aspx/kb/314060
Sep 15, 2009 | Acer Aspire 3680 Laptop
Lite-on DVD R/W combo LH-20A1L BLO5 Blank discs not recognized
Have you checked device manager to see if you have a yellow checkmark on your DVD./CD drives? if ok, sounds to me like the maker of the LH-20A1l BLO5 either needs to fix your problem or replace it. The Nero 7 should enable it to work correctly.
Feb 14, 2008 | Computers & Internet
Dvd burner is not recognized by windows XP sp2 when blank media inserted to burn a movie.
well u need to check for the latest software available for your dvd drive try and find the latest software on net according to your company,and check wether the software ur using comaptible with ur windows
Jan 23, 2008 | Computers & Internet
LG LS50 DVD/CD-RW DRIVE won't recognize blank dvd-r
Yes does not read DVD-R because if your LS50 Labeled like this (DVD/CD-RW) means that can read only all DVD Disc and cannot write on DVD blank only CD blank.
You can burn only on the blank CD-RW or any blank CD.
Jan 17, 2008 | LG X-Note LM50 Notebook
Cd burner
You may want to double-check the "error" message. Normally, when you insert a blank CD-R or CD-R/W you'll see a pop-up message that says something like, "you've inserted a blank CD. What program do you want to use to put something on it?" And then it will give a list of programs like Windows Media Player, Nero Burning ROM, Roxio, MyDVD, etc. The last two choices are "Open a writeable folder" and "Do nothing." The next to last, the open folder, option is the CD recording option for Windows. Once you've put copies of that data into the new window click on the "burn these files to disc" link on the left side or located under the File menu at the top of the window.
Now, if it truly is telling you that you have to insert a blank CD, then you may have one of two problems. Either the CD you're putting in is NOT actually blank or the drive is having problems recognizing the media. To test the first scenario, try the disc on another computer. If it's truly blank, then try uninstalling the CD burner from your Device Manager located in the Windows control panel. Double-click on the System icon > Hardware tab > Device Manager > click on the (+) symbol next to DVD/CD-ROM drives and then highlight your Sony CD burner > right-click and in the menu choose Uninstall. Reboot your system and let Windows redetect the drive and reinstall the drivers (You may want to have any install discs handy, just in case Windows asks for them, but not likely).
I hope that helps!
Nov 08, 2007 | Computers & Internet
DVD-RW Name Changes When Blank DVD Inserted
p3, Did you try burning the DVD and it failed? You should try upgrading the firmware on DVD drive. http://www.samsung.com/support/productsupport/download/Model_Select.aspx?type=ODD+Products&typecode=300400&subtype=DVD+Writer&subtypecode=300405&model=TS-H552U&filetype=FM&language= Or, your just interested why Windows is calling your expensive DVD burner a measley CD Drive? Your Burner is an all-in-one.(I think) It plays(and burns) cd's and dvd's. Whatever program you use to burn has not informed Windows of its true intentions yet...Which is to burn a dvd or a cd. It doesn't know what you are burning until something tells it to. Let me know what happens. Good Luck, Tim
Mar 06, 2007 | Samsung 16x (TS-H552U/BEWN) DUAL LAYER...
Acer Aspire 5315 Notebook Logo
379 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
