Question about Acer Aspire™ T180 PC Desktop
Compatability of Memory Upgrade
I had the Memory stick that came with my Acer Aspire T-180 dekstop computer of 512 DDR2 5300 (555mhz) 240 Pin DIMM in the first slot.
I added a 1GB stick of Kybte brand 5300/4200/3200 PC2-667/533/400 240 PIN DIMM (no problems - computer worked fine)
Then I added a generic 1GB stick of PC2-4200 DDR2(533mhz) 240 Pin DIMM (Computer seemed fine for about a month)
Then had the following problems:
1) computer shuts itself off and on quickly at random and slows down considerably to point cannot open word. I replaced my motherboard.
2) When I put the computer back together I had the generic 1GB PC2-4200 stick in first memory slot, the kybte 1GB (5300/4200/3200) stick in the second slot and the factory 512mb (5300) stick in third slot.
Computer seemed to work for a bit and then kept crashing. Reformated entire computer to default factory settings about 5 times then sent back for servicing.
My question: Is it the memory configuration causing my problems or it is a faulty (lemon) computer. I've only had it a few months.
    Problem Solver:
  • 4 Answers
One or both of your RAMs have developed a fault. Change both RAM. After changing RAM pl format again and than try. Do not insert those faulty RAM again. Get your RAM tested by a software which is available on Microsoft site for free.
Thanks
Bhaskar
Posted on Jun 04, 2008
2 Suggested Answers
worldvet
  • 859 Answers
SOURCE: Compatability of Memory Upgrade
DDR RAM needs to be installed in pairs, as in if you have two 1GB sticks these would, in a four slot board, be inserted in slots 1 and 3 or 2 and 4. The other odd 512MB stick could go in any other slot theoretically speaking. But, you would be better off leaving it out. The SPD chips on the two 1GB sticks should match themselves to time at the slowest common or fastest common denominator.
There is a chance that by having the odd bank population that you said worked for awhile installed as you had, that the MB RAM slots were put under unusual voltage stess. There is a pretty good chance you can remove the 512MB stick, leave the two 1GB sticks in slots 1 and 3 or 2 and 4. But, this is VERY important: consult your board manual or access it online and read what the population requirments are for the slots as in some cases, the two matched sticks go in 1 and 2 or 3 and 4. This little oddity is found from time to time.
Consult your manual or download it and read how the slots need to be populated and stick with the two 1GB sticks.
There are memory testing programs you can find for free at majorgeeks dot com and test your RAM once you have it populated correctly.
In the future, I'd suggest you purchase RAM from Kingston or Corsair directly online as they usually offer a lifetime warranty and this RAM right now for you board is dirt cheap.
Hope this FIXED, as in ANSWERED you question and was more than helpful. Should you feel compelled to rate this solution after reading, either rate it FIXED or not at all. I know its helpful by default, that's what we do here. But only a thorough answer can FIX your situation. You should be fine if you follow my instructions. But, please consult you manual.
Regards,
Worldvet
Posted on Nov 20, 2008
Memory stick upgrade 2 512, 2 1GB what order do I put them in
On the motherboard they should be labeled as to which slot is Dimm 1, Dimm 2, Dimm 3 and Dimm 4. Put the larger ones (1GB) in Dimm 1 and Dimm 2. The smaller ones (512MB) in Dimm 3 and Dimm 4.
May 06, 2012 | Sony PCV-RS620G PC Desktop
Installed additional RAM on HP P6531p desktop, computer freezes on start-up. Using Kingston DDR3 SDRAM DIMM PC3 10600 @ 1333mHz 2GB. Computer starts and runs fine with 2 sticks installed, but freezes with...
You may have tried to put too much memory (RAM) onto it.
That models maximum spec is:
Memory upgrade information:
  • Four DDR3 DIMM (240-pin) sockets
  • Supports 1 GB, 2 GB, and 4 GB DDR3 DIMMs per socket
  • Supports Dual channel memory architecture
  • Supported speeds
    • PC3-10600 @ 1333 MHz*
    • PC3-8500 @ 1066 MHz
      *DDR3-1333 modules run at 1066 MHz if three or more modules are installed.
  • Non-ECC memory only, unbuffered
  • Supports up to 16 GB on 64-bit PCs (DIMMs run at DDR3-1066)
  • Supports up to 4 GB on 32-bit PCs
You can find the specs and troubleshooting help files here
Jul 20, 2011 | HEWLETT-PACKARD Pavilion p6531p-b...
Just bought 2 1GB PNY dual Chanel memory modules for my Computer Make: HP Pavilion 061 Computer Model: RJ181AA-ABA a1600n Currently has Memory: 4 slots: 512 MB, 512 MB, empty, empty QUESTION: which slots...
Start off by putting the first memory module in DIMM slot 0 this is the slot nearest the processor. DIMM slot 1 is the slost after DIMM 0.
Regards.
Jun 28, 2010 | HP Computers & Internet
Iwant to install an extra 1GbRAM-what specs/Pt Nos do i req; For Acer Veriton 5100
Hello
Thank you for using
FixYa for your problem
Sorry but on there website max is 512MB of ram
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | Acer Veriton 5100 PC Desktop
I intend to install more 1 mega of memory, but motherboard not recognized it (one dimm 1gb pc3200 cl3 184-pin dimm). Of origin the PC it has been installing 2 dimms of 512 and I intend to add +1 dimm of...
The memory may not be compatible depending on the speed. Try taking out all the memory and just installing the 1Gig stick.. does it work?
If it does then the 1Gig stick is fine, but your PC probably doesn't like you mixing different types and speeds of memory.
If it doesn't work, the 1gig memory module might not be the correct speed your PC wants.
Sep 08, 2009 | Computers & Internet
Pc beeps five times when swtched on
PC beeps are usually memory-related problems. make sure you are using the right memory for your computer. the specs should be a DDR2 DIMM 240 pin PC2-3200. what specs do you have?
also do you have two 1G memory sticks or just one 2G memory stick? it may be that your computer doesn't accept a 2G memory stick but rather 1G memory sticks. good luck.
Dec 26, 2008 | HP CTO HP Workstation XW6200 Base...
Regards,
Worldvet
Nov 20, 2008 | Computers & Internet
Acer Aspire T-180 Memory Upgrade question
Hello, You might be able to add 2GB more. 1GB per slot. You need to get the model # off your motherboard and verify what the maximum amount of memory it will support. 1GB per slot would be 4GB total but some Operating systems will only support 3GB. So some might be wasted if that is the case. You would need to use the same memory type. So if existing is PC2-4300, use the same. Hope this helps.
Mar 05, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
262 people viewed this question
Brian Sullivan
Brian Sullivan
