Question about Refrigerators
Freezer water leaks into refrigerator - Whirlpool
Model #ET8CHMXKB0 2
Ice builds up in the bottom of the freezer and when defrost kicks on water flows through two holes in the bottom on the freezer and into the refrigerator.
With a $140 technician visit, Whirlpool's Diamond Service diagnosed this leaking problem as a thermostat issue. For another $40, a new thermostat was installed. When the problem returned close to 30 days later -- takes time for ice to build back up -- Diamond Service said they'd have to charge another technician fee for a return visit and new diagnosis because it was past 30 days from installation...not to mention the likely charge of another part. Again it takes it about 30 days to know if a solution will work in this case, so this service philosophy might have us paying Diamond Service over and over.   Sorry to vent, but this is nuts. It brings new meaning to the Whirlpool tagline -- The inside advantage. We're close to $200 in with nothing to show for it but a wet fridge. Any ideas on what I can do to avoid the Diamond Service scheme.
Thanks in advance for your insight.
  • 4 more comments
  • Anonymous Jun 06, 2008
    I have the same problem as DWhitakers freezer water leaks into the refrigerator. my model no. is ET22RKXGW03 whirlpool. I took the back of the freezer panel off and found the drain tube where the water drains when the defrost kicks in frozen solid. when the defrost kicks in now the water leaks into the refrigerator. I pored hot water down the tube and cleared it and the fridge worked fine for about a 30 days and the tube froze again and water started leaking again. I believe the switch that turns the defrost on is not turning on correctly for the right length of time or some thing like that. I need to know also what to change to correct the problem with out calling a repair man out.
  • bcurtis91 Aug 17, 2008
    I have been having this problem for quite wsome time now, every few months I take apart the freezer and use a blow dryer and hot water to clear the frozen drain. HOWEVER, this month it is different - lots of water but the drain pipe is not obstruced at all, water freely flows down the the drip pan under the fridge, did you find any solution to your problem?
  • Anonymous Sep 15, 2008
    I have Whirlpool model #ET1NHMXKT02 with ice-maker on left in the freezer. Every so often there is a noise (a hiss and drip if that makes sense), that is very subtle. Usually this happens after I shut the fridge.
    The Problem:
    I see there is water clearly leaking from the bottom of the freezer into the fridge, right where the thermostat is. There seems to be a plate possibly missing, (but not sure) that could be the solution. Either way, there is sitting water on all shelves and even in the crisper bins and sitting in the bottom of the fridge, under the crisper bins. There seems to be no drain, save for the one that is way uphill from the bottom of the crispers.
  • Anonymous Apr 19, 2009
    SAme problem here anyone resolve their issue?
  • Anonymous Apr 27, 2009
    Seems as if I have the same problem. Water dripping from the freezer down the back of the fridge and ending up in and below the crisper. I noticed ice build up around the area where I assume the defrost would be draining down to the pan. Yuck!!
  • scohun May 06, 2009
    Water dripping from the freezer down the back of the fridge and ending up on all the shevles. I noticed ice build up around the area. I need to know also what to change to correct the problem with out calling a repair man out.
I have the same problem and have taken the inside back panel of the freezer off to view the freezer coil twice. Both times (months apart) the freezer coil is frozen over and the drain and drain plate are clogged with ice. I defrosted with a blow dryer, cleared the drain and reassembled. All takes about an hour to an hour and a half. I did this to see if it would repeat and now it has again. It is actually a very common problem in freezers and is most likely either the fan (mine is running fine) or the defrost timer. The timer is a classic failure, so I plan to replace mine. They are usually mounted in the lower back compartment where the compressor is and should cost under $50.00.
Posted on Jun 22, 2009
  • temp_name Apr 27, 2011
    I had the same problem with this POS. If you DO NOT FILL THE FREEZER, no water will drip down the back and collect in the bottom. It is already a small freezer, so not filling it makes it practically worthless. My ultimate solution was to buy a Maytag, and use this Whirlpool POS as my garage soda and beer fridge.
WHY IS MY SIDE BY SIDE WHIRLPOOL leaking water onto floor?
normally caused by a clogged drain in back of freezer . check to see if you have ice build up on bottom of freezer..... gently chip away ice in freezer and turkey baste hot water into drain hole until water flows freely
Aug 27, 2014 | Whirlpool Refrigerators
Tdc18paaaww leaking ice buildup
Is this auto-defrost model? Usually, heating element that defrosts the ice in back of freezer can go bad. How old is the model?
Dec 29, 2013 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Whirlpool refrigerator #ER2CHMXPL02 I think I have two separate problems. 1st one is a water leak that fills the bottom bins daily! The freezer does not seem to be defrosting, everything in there looks...
Could be that the freezer is too full with foodstuff and there is no air circulation, therefor, some places in the freezer build ice. The defroster is working and melting the ice that drips to the bottom bins.
I suggest you remove everything from the freezer. unplug the frigde. Let all ice build ups melt. Remove ice from the foodstuff and put back in. Make sure that vents in the freezer and fridge are not blocked.
Oct 18, 2013 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Whirlpool gold refrigerator is not cooling ice build up in freezer. Water on bottom of refrigerator.
Too much build of ice in freezer will not cooled the refrigerator side, you need to defrost the fridge. Set it to proper temp setting, just enough to have ice on the freezer and also remove water on the bottom.
Thanks for asking.
Jun 24, 2011 | Whirlpool Refrigerators
Water on the top shelf of the refrigerator
Your defrost drain is clogged and now the defrost drain trough has filled with ice causing the water from your defrost cycles to flow into the fresh food section. You will need to clear all ice form thr drain area and this is done thru the freezer wall and some models also have a removable bottom panel in the freezer that has to come out also to get to the drain. You can do this it will just take a little time. About an hour for a first timer with little experience. Good luck and hope this helps
Feb 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a whirlpool Gold Model GR2SHKXKS01. My problem is ice build up under the bottom tray of freezer and when fridge defrost the tube is frozen solid and creates this build up. After cleaning all the ice...
I have Ice build up under the tray in the freezer which makes water run into my refig and makes a mess what would cause this is the evavorator motor out?
Jun 03, 2009 | Refrigerators
My bottom freezer is making ice but not keeping the food frozen
The flow tubes are blocked.You will need to defrost the unit,unplug and pull off as much ice as possible.You can put pans of hot water in the freezer.
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Ice build up under the freezer drawer
drain is blocked. remove back panel inside freezer and melt the ice off at the bottom with a hairdryer then follow up with hot water till drain flows freely. if fault reoccurs, then you may have a fault with the defrost system
Jul 06, 2008 | Whirlpool GB2SHKXL Bottom Freezer...
Cannot open the bottom freezer door anymore; it seems stuck
sounds as though the defrost system has failed or the freezer defrost drain is blocked. take off the back panel of the freezer and see if excess ice build up. if so, defrost carefully with a hairdryer. at bottom is a drain. check if blocked with ice and if so melt off with hot water till water flows away freely. if i'm right, appliance will start to work. if fault re-occure then defrost system is at fault
May 06, 2007 | Sub-Zero 611 / O Bottom Freezer...
Refrigerators Logo
7,639 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
